I would like compile with emulation mode because I don’t have GPU with CUDA.
lite@lite-debian:~/NVIDIA_GPU_Computing_SDK/C$ make emu=1
make[1]: Wejście do katalogu `/home/lite/NVIDIA_GPU_Computing_SDK/C/common'
In file included from src/bank_checker.cpp:19:
./../common/inc/bank_checker.h:38: warning: type qualifiers ignored on function return type
./../common/inc/bank_checker.h:224: warning: type qualifiers ignored on function return type
src/bank_checker.cpp:61: warning: type qualifiers ignored on function return type
src/bank_checker.cpp:263: warning: type qualifiers ignored on function return type
In file included from ./../common/inc/stopwatch.h:22,
from src/cutil.cpp:37:
./../common/inc/stopwatch_base.h:60: warning: type qualifiers ignored on function return type
./../common/inc/stopwatch_base.h:64: warning: type qualifiers ignored on function return type
In file included from ./../common/inc/stopwatch_base.h:76,
./../common/inc/stopwatch_base.inl:67: warning: type qualifiers ignored on function return type
./../common/inc/stopwatch_base.inl:78: warning: type qualifiers ignored on function return type
In file included from ./../common/inc/stopwatch.h:29,
./../common/inc/stopwatch_linux.h:50: warning: type qualifiers ignored on function return type
./../common/inc/stopwatch_linux.h:54: warning: type qualifiers ignored on function return type
./../common/inc/stopwatch_linux.h:130: warning: type qualifiers ignored on function return type
./../common/inc/stopwatch_linux.h:147: warning: type qualifiers ignored on function return type
In file included from src/cutil.cpp:37:
./../common/inc/stopwatch.h:39: warning: type qualifiers ignored on function return type
In file included from src/cutil.cpp:38:
from src/stopwatch.cpp:21:
In file included from src/stopwatch.cpp:21:
src/stopwatch.cpp:75: warning: type qualifiers ignored on function return type
In file included from src/stopwatch_linux.cpp:19:
a - obj/x86_64/release/bank_checker.cpp.o
a - obj/x86_64/release/cmd_arg_reader.cpp.o
a - obj/x86_64/release/cutil.cpp.o
a - obj/x86_64/release/stopwatch.cpp.o
a - obj/x86_64/release/stopwatch_linux.cpp.o
a - obj/x86_64/release/multithreading.cpp.o
make[1]: Opuszczenie katalogu `/home/lite/NVIDIA_GPU_Computing_SDK/C/common'
make[1]: Wejście do katalogu `/home/lite/NVIDIA_GPU_Computing_SDK/shared'
make[1]: Opuszczenie katalogu `/home/lite/NVIDIA_GPU_Computing_SDK/shared'
make -C src/oceanFFT/
make[1]: Wejście do katalogu `/home/lite/NVIDIA_GPU_Computing_SDK/C/src/oceanFFT'
obj/x86_64/emurelease/oceanFFT.cpp.o: In function `cleanup()':
oceanFFT.cpp:(.text+0xb7c): undefined reference to `cudaGraphicsUnregisterResource'
oceanFFT.cpp:(.text+0xb8c): undefined reference to `cudaGraphicsUnregisterResource'
obj/x86_64/emurelease/oceanFFT.cpp.o: In function `runCuda()':
oceanFFT.cpp:(.text+0x15d1): undefined reference to `cudaGraphicsMapResources'
oceanFFT.cpp:(.text+0x15f2): undefined reference to `cudaGraphicsResourceGetMappedPointer'
oceanFFT.cpp:(.text+0x162c): undefined reference to `cudaGraphicsMapResources'
oceanFFT.cpp:(.text+0x1648): undefined reference to `cudaGraphicsResourceGetMappedPointer'
oceanFFT.cpp:(.text+0x167e): undefined reference to `cudaGraphicsUnmapResources'
oceanFFT.cpp:(.text+0x1697): undefined reference to `cudaGraphicsUnmapResources'
obj/x86_64/emurelease/oceanFFT.cpp.o: In function `runTest(int, char**)':
oceanFFT.cpp:(.text+0x1cd6): undefined reference to `cudaGraphicsGLRegisterBuffer'
oceanFFT.cpp:(.text+0x1d02): undefined reference to `cudaGraphicsGLRegisterBuffer'
collect2: ld returned 1 exit status
make[1]: *** [../../bin/linux/emurelease/oceanFFT] Błąd 1
make[1]: Opuszczenie katalogu `/home/lite/NVIDIA_GPU_Computing_SDK/C/src/oceanFFT'
make: *** [src/oceanFFT/Makefile.ph_build] Błąd 2
Any suggestions how to solve this? Help would be very appreciated!
obj/i386/emurelease/bicubicTexture.cpp.o: In function `runBenchmark(int)':
bicubicTexture.cpp:(.text+0x924): undefined reference to `cudaGraphicsMapResources'
bicubicTexture.cpp:(.text+0x947): undefined reference to `cudaGraphicsResourceGetMappedPointer'
bicubicTexture.cpp:(.text+0xa4b): undefined reference to `cudaGraphicsUnmapResources'
obj/i386/emurelease/bicubicTexture.cpp.o: In function `initGLBuffers()':
bicubicTexture.cpp:(.text+0xc0d): undefined reference to `cudaGraphicsGLRegisterBuffer'
bicubicTexture.cpp:(.text+0xd51): undefined reference to `cudaGraphicsUnregisterResource'
obj/i386/emurelease/bicubicTexture.cpp.o: In function `cleanup()':
bicubicTexture.cpp:(.text+0x1264): undefined reference to `cudaGraphicsUnregisterResource'
obj/i386/emurelease/bicubicTexture.cpp.o: In function `display()':
bicubicTexture.cpp:(.text+0x1486): undefined reference to `cudaGraphicsMapResources'
bicubicTexture.cpp:(.text+0x14a9): undefined reference to `cudaGraphicsResourceGetMappedPointer'
bicubicTexture.cpp:(.text+0x1556): undefined reference to `cudaGraphicsUnmapResources'
collect2: ld gab 1 als Ende-Status zurück
make[1]: *** [../../bin/linux/emurelease/bicubicTexture] Fehler 1
make[1]: Verlasse Verzeichnis '/home/beckerm/NVIDIA_GPU_Computing_SDK/C/src/bicubicTexture'
make: *** [src/bicubicTexture/Makefile.ph_build] Fehler 2
Try to disable compiling code examples. For instance on Gentoo you can set USE flag -examples for nvidia-cuda-sdk package and I was able to install SDK in emulation mode.
Problem “solved”. Deleting a lot of the examples that contained OpenCL to OpenGL calls did the trick. They seem to be incompatible with the emulation option.
