compile with emulation mode
I’m trying to compile sdk, however I an error:
/usr/bin/ld: cannot find -lcutil
I’m using ubutu 7.04 with vmware.
That computer doesn’t have cuda capable gpu. Is there a way to compile it in emulation mode?
Update:
I tried to compile sdk with make emu=1 dbg=1
pmnox@pmnox-desktop:~/NVIDIA_CUDA_SDK$ make emu=1 dbg=1
make[1]: Entering directory `/home/pmnox/NVIDIA_CUDA_SDK/common’
a - obj/debug/bank_checker.cpp_o
a - obj/debug/cmd_arg_reader.cpp_o
a - obj/debug/cutil.cpp_o
a - obj/debug/stopwatch.cpp_o
a - obj/debug/stopwatch_linux.cpp_o
a - obj/debug/multithreading.cpp_o
make[1]: Leaving directory `/home/pmnox/NVIDIA_CUDA_SDK/common’
a - obj/debug/paramgl.cpp_o
a - obj/debug/param.cpp_o
make -C projects/clock/
make[1]: Entering directory `/home/pmnox/NVIDIA_CUDA_SDK/projects/clock’
make[1]: Leaving directory `/home/pmnox/NVIDIA_CUDA_SDK/projects/clock’
make -C projects/matrixMulDrv/
make[1]: Entering directory `/home/pmnox/NVIDIA_CUDA_SDK/projects/matrixMulDrv’
/usr/bin/ld: cannot find -lcuda
collect2: ld returned 1 exit status
make[1]: *** […/…/bin/linux/emudebug/matrixMulDrv] Error 1
make[1]: Leaving directory `/home/pmnox/NVIDIA_CUDA_SDK/projects/matrixMulDrv’
make: *** [projects/matrixMulDrv/Makefile.ph_build] Error 2
You can skip compiling the *Drv packages by renaming each Makefile to Makefile-old. There is no way to run a Driver API program in emulation mode. The rest of the samples should work fine.
thx… Problem solved :]
