Instalation of CUDA in Debian some hint or step by step to cuda instal
Hi, I’m having problems to install cuda in my debian etch, first I try to install the redhat toolkit, so I had error of float point exception when I try to run nvcc.
In the forum, there is a sugestion to use the suse toolkit, and whith this toolkit the nvcc seems to work fine.
I’m trying to compile some exemplas in SDK..
First I get the error:
make emu=1
/usr/bin/ld: cannot find -lGLU
I correct this error creating a link for libGL.so.1 to libGL.so
After that a received
make emu=1
/usr/bin/ld: cannot find -lcutil
collect2: ld returned 1 exit status
I dont know if I understand the requisities to CUDA but I install the new nvidia display driver version 100.14.
My vga is a gf 5200 but in the emu=1 mode, is possible to compile , or not ?
Yes, you should be able to compile in emulation mode.
You need to build cutil before building the examples.
Yes, thanks, now it’is ok, I find in the realise notes of SDK how compile the libcutil, just use make in the SDK file.
But now i’m getting
make
make[1]: Entrando no diretório `/home/maicon/NVIDIA_CUDA_SDK/common’
src/error_checker.cpp:51:20: GL/glu.h: Arquivo ou diretório não encontrado
src/error_checker.cpp: In static member function `static void ErrorChecker::checkErrorGL(const char*, int)':
src/error_checker.cpp:68: error: `gluErrorString’ was not declared in this scope
src/error_checker.cpp:68: warning: unused variable ‘gluErrorString’
make[1]: ** [obj/release/error_checker.cpp_o] Erro 1
make[1]: Saindo do diretório `/home/maicon/NVIDIA_CUDA_SDK/common’
make: ** [lib/libcutil.so] Erro 2
I will see if I find the solution.
If someone can help ?
Thanks a lot
