root@vr-kat:~/NVIDIA_CUDA_SDK# make
make[1]: Entering directory `/root/NVIDIA_CUDA_SDK/common’
ar: creating ./…/lib/libcutil.a
a - obj/release/bank_checker.cpp_o
a - obj/release/cmd_arg_reader.cpp_o
a - obj/release/cutil.cpp_o
a - obj/release/stopwatch.cpp_o
a - obj/release/stopwatch_linux.cpp_o
a - obj/release/multithreading.cpp_o
make[1]: Leaving directory `/root/NVIDIA_CUDA_SDK/common’
a - obj/release/paramgl.cpp_o
a - obj/release/param.cpp_o
make -C projects/binomialOptions/
make[1]: Entering directory `/root/NVIDIA_CUDA_SDK/projects/binomialOptions’
“/usr/include/c++/4.2/i486-linux-gnu/bits/c++config.h”, line 149: error:
expected a “{”
namespace std attribute ((visibility (“default”))) {
“/usr/include/c++/4.2/bits/cpp_type_traits.h”, line 74: error: expected a “{”
namespace __gnu_cxx attribute ((visibility (“default”))) {
“/usr/include/c++/4.2/bits/cpp_type_traits.h”, line 81: error: expected a “{”
“/usr/include/c++/4.2/bits/cpp_type_traits.h”, line 313: error: name followed
by “::” must be a class or namespace name
struct __is_normal_iterator< __gnu_cxx::__normal_iterator<_Iterator,
“/usr/include/c++/4.2/bits/cpp_type_traits.h”, line 313: error: too many
arguments for class template “::__is_normal_iterator”
“/usr/include/c++/4.2/cstddef”, line 53: error: expected a “{”
“/usr/include/c++/4.2/bits/stl_relops.h”, line 74: error: expected a “{”
“/usr/include/c++/4.2/bits/stl_pair.h”, line 64: error: expected a “{”
“/usr/include/c++/4.2/ext/type_traits.h”, line 44: error: expected a “{”
“/usr/include/c++/4.2/ext/type_traits.h”, line 71: error: namespace “std” has
no member “__is_integer”
typedef __enable_if<std::__is_integer<_Tp>::__value, _Tp> __if_type;
“/usr/include/c++/4.2/ext/type_traits.h”, line 71: error: type name is not
allowed
“/usr/include/c++/4.2/ext/type_traits.h”, line 71: error: too few arguments
for class template “::__enable_if”
“/usr/include/c++/4.2/ext/type_traits.h”, line 71: error: explicit type is
missing (“int” assumed)
“/usr/include/c++/4.2/ext/type_traits.h”, line 71: error: template parameter
“_Tp” may not be redeclared in this scope
“/usr/include/c++/4.2/ext/type_traits.h”, line 71: error: expected a “;”
“/usr/include/c++/4.2/ext/type_traits.h”, line 74: error: name followed by
typedef typename __if_type::__type __type;
“/usr/include/c++/4.2/ext/type_traits.h”, line 114: error: namespace “std” has
“/usr/include/c++/4.2/ext/type_traits.h”, line 114: error: type name is not
allowed
“/usr/include/c++/4.2/ext/type_traits.h”, line 114: error: too few arguments
“/usr/include/c++/4.2/ext/type_traits.h”, line 114: error: explicit type is
“/usr/include/c++/4.2/ext/type_traits.h”, line 114: error: template parameter
“/usr/include/c++/4.2/ext/type_traits.h”, line 114: error: expected a “;”
“/usr/include/c++/4.2/ext/type_traits.h”, line 117: error: name followed by
“/usr/include/c++/4.2/cmath”, line 82: error: expected a “{”
“/usr/include/c++/4.2/cmath”, line 111: error: name followed by “::” must be a
inline typename __gnu_cxx::__enable_if<__is_integer<_Tp>::__value,
“/usr/include/c++/4.2/cmath”, line 127: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 143: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 159: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 176: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 192: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 208: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 224: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 240: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 256: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 282: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 298: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 314: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 330: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 387: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 403: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 419: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 435: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 451: error: name followed by “::” must be a
“/usr/include/c++/4.2/cmath”, line 456: error: expected a “;”
“/usr/include/c++/4.2/cmath”, line 464: error: expected a “{”
“/usr/include/c++/4.2/cmath”, line 535: error: expected a “{”
“/usr/include/c++/4.2/bits/cmath.tcc”, line 39: error: expected a “{”
“/usr/include/c++/4.2/cstdlib”, line 104: error: expected a “{”
“/usr/include/c++/4.2/cstdlib”, line 161: error: expected a “{”
“/usr/include/c++/4.2/cstdlib”, line 203: error: expected a “{”
“/usr/include/c++/4.2/cstdlib”, line 206: error: name followed by “::” must be
using ::__gnu_cxx::lldiv_t;
“/usr/include/c++/4.2/cstdlib”, line 208: error: name followed by “::” must be
using ::__gnu_cxx::_Exit;
“/usr/include/c++/4.2/cstdlib”, line 209: error: name followed by “::” must be
using ::__gnu_cxx::abs;
“/usr/include/c++/4.2/cstdlib”, line 211: error: name followed by “::” must be
using ::__gnu_cxx::llabs;
“/usr/include/c++/4.2/cstdlib”, line 212: error: name followed by “::” must be
using ::__gnu_cxx::div;
“/usr/include/c++/4.2/cstdlib”, line 213: error: name followed by “::” must be
using ::__gnu_cxx::lldiv;
“/usr/include/c++/4.2/cstdlib”, line 215: error: name followed by “::” must be
using ::__gnu_cxx::atoll;
“/usr/include/c++/4.2/cstdlib”, line 216: error: name followed by “::” must be
using ::__gnu_cxx::strtof;
“/usr/include/c++/4.2/cstdlib”, line 217: error: name followed by “::” must be
using ::__gnu_cxx::strtoll;
“/usr/include/c++/4.2/cstdlib”, line 218: error: name followed by “::” must be
using ::__gnu_cxx::strtoull;
“/usr/include/c++/4.2/cstdlib”, line 219: error: name followed by “::” must be
using ::__gnu_cxx::strtold;
86 errors detected in the compilation of “/tmp/tmpxft_00001ec4_00000000-2.ii”.
make[1]: *** [obj/release/binomialOptions.cu_o] Error 255
make[1]: Leaving directory `/root/NVIDIA_CUDA_SDK/projects/binomialOptions’
make: *** [projects/binomialOptions/Makefile.ph_build] Error 2
