SDK Manager 2.2.0.12021 fails installation on Jetson Orin NX 8Gb
I’m trying to install jetpack 6.1 on a Jetson ORIN NX with using the SDK Manager 2.2.0.12021, running on a Ubuntu 22.04 host machine.
The installation fails every time with an error message “target_image: First error. Cannot extract TAR file”. (See attached screenshot).
You can find the log files attached.
Thanks for any help.
Regards,
Lorenzo
SDKM_logs_JetPack_6.1_Linux_for_Jetson_Orin_NX_8GB_2024-11-14_11-11-26.zip (201.6 KB)
Hi lorenzo.podesta,
Is your Ubuntu 22.04 running on the vm or the physical machine?
Hi, Ubuntu 22.04 is running on the physical machine.
Hi
Based on the log provided.
{"partition":"/dev/sda2","type":"fuseblk","requiredMB":20830.207579078673,"freeMB":8226120.95703125}
It appears that your Ubuntu installation is on a partition with the fuseblk format. Please create a new partition formatted as ext4 and install the SDK on that partition.
I cannot change the partition, I’ll use another machine.
