Hi, I’m having some issues re-flashing my Jetson. Error messages from Terminal as follows:
09:36:38 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
09:44:15 ERROR: File System and OS - target_image: /etc/kernel/postinst.d/apt-auto-removal:
09:44:15 ERROR: File System and OS - target_image: qemu: Unsupported syscall: 276
09:44:21 SUMMARY: File System and OS - target_image: Install completed successfully.
09:44:36 ERROR: Can not find matching device in recovery mode.
09:44:54 ERROR: Flash Jetson AGX Xavier - flash: — Parsing board ID (ERROR: calculated CRC8 0xfd != stored CRC8 0x8e) succeeded.
09:44:54 ERROR: Flash Jetson AGX Xavier - flash: — Parsing board version (ERROR: calculated CRC8 0xfd != stored CRC8 0x8e) succeeded.
09:44:54 ERROR: Flash Jetson AGX Xavier - flash: — Parsing board SKU (ERROR: calculated CRC8 0xfd != stored CRC8 0x8e) succeeded.
09:44:54 ERROR: Flash Jetson AGX Xavier - flash: — Parsing board REV (ERROR: calculated CRC8 0xfd != stored CRC8 0x8e) succeeded.
09:44:54 ERROR: Flash Jetson AGX Xavier - flash: Error: Target board not found.
09:44:54 ERROR: Flash Jetson AGX Xavier - flash: command terminated with error
09:44:54 SUMMARY: Flash Jetson AGX Xavier - flash: First Error: Installation failed.
09:44:54 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
09:44:54 SUMMARY: Multimedia API - target: Depends on failed component
09:44:54 SUMMARY: TensorRT on Target - target: Depends on failed component
09:44:54 SUMMARY: VPI on Target - target: Depends on failed component
09:44:54 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
09:44:54 SUMMARY: cuDNN on Target - target: Depends on failed component
09:44:54 SUMMARY: OpenCV - target: Depends on failed component
09:44:54 SUMMARY: DateTime Target Setup - target: Depends on failed component
I’ve checked using i2cdetect/get and found that CRC8 is indeed 0x8e. Not sure what this means, and if it’s safe to set this to 0xfd instead. Any help appriciated!
