Hello ,
I followed these ( Install Jetson Software with SDK Manager :: NVIDIA SDK Manager Documentation) steps for using sdk manager.
==> sdk manger in NX Dev kit
Installed succesfully in my NX dev kit , Display connected to dev kit (hdmi) showed authentication (user id , password and other settings) steps. Hence everything was perfect.
==> sdk manager in NX SoM custom carrier board.
attached SD card (with bootable image in it) + activated recovery mode + connected display + used ethernet as well ,
but installation process after 34% , get stuck in (whereas download process is completed)
even the display (connected via hdmi) is also not working.
Logs in putty are:-
[0001.634] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0001.643] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0001.648] I> Boot-mode: Platform RCM
[0001.652] I> Chip revision : A02P
[0001.655] I> Bootrom patch version : 15 (correctly patched)
[0001.660] I> ATE fuse revision : 0x200
[0001.663] I> Ram repair fuse : 0x1
[0001.666] I> Ram Code : 0x0
[0001.669] I> rst_source : 0x0
[0001.672] I> rst_level : 0x0
[0001.675] I> USB configuration success
