SecureBoot on Jetson Orin : Flash Successfull but uefi firmware error
Hello @cleng!
  1. Did you edit the script in order to match the OEMK1 that you burned?
  2. After generating the EKB image, did you replace it in the Linux_for_Tegra/bootloader/ directory?
This error seems to be related to the EKB image not being updated after the fuse burning process. Also, is important to replace the sym2_t234.key under the /Linux_for_Tegra/ path. At this topic you can found valuable information about updating ekb images, but give it a try and let me know if it helps.
Regards,
Salomon Ramirez
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
