JetPack 5.1.3 - Boot error with all security enabled
Hi, I get the same error after udate the Jetson_Xavier_NX_QSPI_35.1.tbz2 from a running jetson-nx-jp461-sd-card-image. I could not correct this error with new jetson-nx image with sd card only. Maybe there is a way with JTAG, but I did’nt now how.
I get the message :
Ubuntu 20.04.6 LTS linux ttyTCU0
linux login: [ 1072.821436] Trying to unregister non-registered hwtime source
[ 1076.307582] nvgpu: 17000000.gv11b nvgpu_timeout_expired_msg_cpu:94 [ERR] Timeout detected @ gp10b_gr_init_wait_empty+0x168/0x2a0 [nvgpu]
after that the board may damaged:
0003.453] W> No board IDs available
[0003.456] E> Failed to get board id info!
[0003.460] E> Failed: Unknown device 6
[0003.468] I> Found 41 partitions in QSPI_FLASH (instance 0)
and then I could not recover from ASSERT [FvbNorFlashStandaloneMm]
