Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
Isaac Sim Version
V 5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
V Windows 10
GPU Information
- Model: RTX A4000
- Driver Version: 573.06
Topic Description
Detailed Description
Due to our company’s security policy, I have replaced the actual simulation data with a representative image.
I am running a simulation of a jig that consists of two interlinked 4-bar linkages, as shown in the image. The joint configuration is as follows:
Revolute Joints: #1, #2, #3, #5, #6, #7
Prismatic & Drive Joints: #4, #8
Fixed Joint: #9
Additionally, the “Exclude From Articulation” setting has been applied to joints #1 and #9.
During the simulation, I observed significant vibration in Part_2 and Part_6. I was able to resolve the vibration in Part_2 by increasing the stiffness of joint #4.
However, the vibration in Part_6 persists. Increasing the stiffness of joint #8 did not solve the issue. I also tried applying the “Exclude From Articulation” setting to joint #7, but the same symptom remains.
Could you please suggest any possible solutions to eliminate the vibration in Part_6?
For your reference, the “Exclude From Articulation” setting was intentionally not applied to joints #2, #3, #5, and #6 because their positions must remain precise for the mechanism’s accuracy.
Thank you for your assistance.
Error Messages
There are not Error Messages
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
