External Image I was going to wait for the FERMI found out it willn’t be available till early 2010
So I will settle for a used c1060 can’t afford a new one at this time miss the window for 50% off.
If you don’t need the 4 GB of RAM, you could go with a GTX 285 with 1 or 2 GB of RAM instead. Those are < $400 each and will have the same CUDA performance as the C1060 (except the RAM part).
