I get SegFaults when running most of the OCL Nvidia SDK examples on cuda-gdb. I have:
cudatoolkit_3.2.16_linux_64_ubuntu10.04
SDK Version: gpucomputingsdk_3.2.16_linux
Driver: 260.19.36 on a GTX580
Executing e.g. oclVectorAdd works fine from console.
But in cuda-gdb I get:
NVIDIA (R) CUDA Debugger
3.2 release
Portions Copyright (C) 2008-2010 NVIDIA Corporation
GNU gdb 6.6
Copyright (C) 2006 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "x86_64-unknown-linux-gnu"...
(no debugging symbols found)
Using host libthread_db library "/lib/libthread_db.so.1".
(cuda-gdb) r
Starting program: /home/scratch/rdiehl/NVIDIA_GPU_Computing_SDK/OpenCL/bin/linux/release/oclVectorAdd
[Thread debugging using libthread_db enabled]
[New process 14355]
/home/scratch/rdiehl/NVIDIA_GPU_Computing_SDK/OpenCL/bin/linux/release/oclVectorAdd Starting...
# of float elements per Array = 11444777
Global Work Size = 11444992
Local Work Size = 256
# of Work Groups = 44707
Allocate and Init Host Mem...
[New Thread 139986343360288 (LWP 14355)]
clGetPlatformID...
clGetDeviceIDs...
[New Thread 139986114221824 (LWP 14359)]
[New Thread 139986105829120 (LWP 14360)]
clCreateContext...
clCreateCommandQueue...
clCreateBuffer...
oclLoadProgSource (VectorAdd.cl)...
clCreateProgramWithSource...
clBuildProgram...
clCreateKernel (VectorAdd)...
clSetKernelArg 0 - 3...
clEnqueueWriteBuffer (SrcA and SrcB)...
clEnqueueNDRangeKernel (VectorAdd)...
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 139986105829120 (LWP 14360)]
0x00007f510f89fa93 in ?? () from /usr/lib/libcuda.so
So, what’s the matter?
Greets
