A3000
• DeepStream Version
6.1
• TensorRT Version
8.2.5.1
510.73.05
Bug
It seems like I crashed at nvvideoconvert’s function when I repeatedly run a pipeline that links a x-raw video to nvv4l2decoder plugin, trying to convert the video to NVMM data format. The pipeline is linked like follows:
filesrc → qtdemux → h264parse → nvv4l2decoder → rest of pipeline…
It does not occur all the time. A segmentation fault is thrown after this nvvideoconvert log, but I could not provide a more specific stack trace to pinpoint the function where the error is thrown. GDB frames calls shows the fault is thrown at g_type_check_value in gst_value_is_fixed, in gst_pad_push_event
Including the last seen logs below
05810 19001 0x55be0e5041e0 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:capsfilter0:sink sent query 0x55be0d924b20 (caps), result 1
0:00:24.702111795 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstobject.c:263:gst_object_unref:capsfilter0:sink 0x55be0d95b7b0 unref 2->1
0:00:24.702122318 19001 0x55be0e5041e0 DEBUG default gstutils.c:2769:query_caps_func:fuzer:src intersect with result video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702127178 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:262:gst_caps_new_empty: created caps 0x55be0d916d40
0:00:24.702135972 19001 0x55be0e5041e0 TRACE structure gststructure.c:154:gst_structure_new_id_empty_with_size: created structure 0x7f557c0474c0
0:00:24.702148971 19001 0x55be0e5041e0 DEBUG default gstutils.c:2771:query_caps_func:fuzer:src intersected video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702159208 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f5594008ad0 unref 7->6
0:00:24.702170396 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x55be0d924f20 ref 2->3
0:00:24.702188104 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x55be0d916d40 ref 1->2
0:00:24.702193116 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d916d40 unref 2->1
0:00:24.702197406 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d924f20 unref 3->2
0:00:24.702202111 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x55be0d916d40 ref 1->2
0:00:24.702206345 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d924ad0 unref 1->0
0:00:24.702210380 19001 0x55be0e5041e0 TRACE structure gststructure.c:392:gst_structure_free: free structure 0x7f557c046c40
0:00:24.702213970 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:216:_gst_caps_free: freeing caps 0x55be0d924ad0
0:00:24.702219083 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d916d40 unref 2->1
0:00:24.702224425 19001 0x55be0e5041e0 DEBUG GST_PADS gstpad.c:3437:gst_pad_query_default:fuzer:fuzerpad20 not forwarding 0x55be0d924b20 (caps) query
0:00:24.702228958 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstobject.c:263:gst_object_unref: 0x55be0d958200 unref 2->1
0:00:24.702233978 19001 0x55be0e5041e0 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:fuzer:fuzerpad20 sent query 0x55be0d924b20 (caps), result 1
0:00:24.702238018 19001 0x55be0e5041e0 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:fuzer:fuzerpad20 do probes
0:00:24.702243658 19001 0x55be0e5041e0 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:fuzer:fuzerpad20 hook 1 with flags 0x00003010 does not match 00002200
0:00:24.702248289 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstobject.c:263:gst_object_unref:fuzer:fuzerpad20 0x7f55b395cd40 unref 4->3
0:00:24.702252441 19001 0x55be0e5041e0 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:ubin21:src do probes
0:00:24.702257958 19001 0x55be0e5041e0 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:ubin21:src hook 1 with flags 0x00003040 does not match 00002200
0:00:24.702263478 19001 0x55be0e5041e0 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:ubin21:src hook 2 with flags 0x00003010 does not match 00002200
0:00:24.702273838 19001 0x55be0e5041e0 DEBUG default gstutils.c:2769:query_caps_func:ubin21:src intersect with result video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702277760 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:262:gst_caps_new_empty: created caps 0x55be0d91b4f0
0:00:24.702280466 19001 0x55be0e5041e0 TRACE structure gststructure.c:154:gst_structure_new_id_empty_with_size: created structure 0x7f5568046b60
0:00:24.702289211 19001 0x55be0e5041e0 DEBUG default gstutils.c:2771:query_caps_func:ubin21:src intersected video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702293131 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f5594008ad0 unref 6->5
0:00:24.702297468 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x55be0d6ef400 ref 5->6
0:00:24.702300722 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x55be0d91b4f0 ref 1->2
0:00:24.702304010 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d91b4f0 unref 2->1
0:00:24.702306979 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d6ef400 unref 6->5
0:00:24.702313510 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x55be0d91b4f0 ref 1->2
0:00:24.702318309 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d916d40 unref 1->0
0:00:24.702323233 19001 0x55be0e5041e0 TRACE structure gststructure.c:392:gst_structure_free: free structure 0x7f557c0474c0
0:00:24.702326543 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:216:_gst_caps_free: freeing caps 0x55be0d916d40
0:00:24.702331312 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d91b4f0 unref 2->1
0:00:24.702336244 19001 0x55be0e5041e0 DEBUG GST_PADS gstpad.c:3437:gst_pad_query_default:src:proxypad143 not forwarding 0x55be0d924b20 (caps) query
0:00:24.702339914 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstobject.c:263:gst_object_unref:ubin21:src 0x55be621b6ba0 unref 5->4
0:00:24.702345343 19001 0x55be0e5041e0 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:src:proxypad143 sent query 0x55be0d924b20 (caps), result 1
0:00:24.702351208 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstobject.c:263:gst_object_unref:src:proxypad143 0x7f55b00290f0 unref 2->1
0:00:24.702365020 19001 0x55be0e5041e0 DEBUG default gstutils.c:2769:query_caps_func:queue2:src intersect with result video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702373517 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:262:gst_caps_new_empty: created caps 0x55be0d716ad0
0:00:24.702377647 19001 0x55be0e5041e0 TRACE structure gststructure.c:154:gst_structure_new_id_empty_with_size: created structure 0x7f55b3473c20
0:00:24.702389179 19001 0x55be0e5041e0 DEBUG default gstutils.c:2771:query_caps_func:queue2:src intersected video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702397689 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f5594008ad0 unref 5->4
0:00:24.702402517 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x55be0d9298a0 ref 3->4
0:00:24.702406900 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x55be0d716ad0 ref 1->2
0:00:24.702410946 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d716ad0 unref 2->1
0:00:24.702415138 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d9298a0 unref 4->3
0:00:24.702424170 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x55be0d716ad0 ref 1->2
0:00:24.702428070 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d91b4f0 unref 1->0
0:00:24.702432407 19001 0x55be0e5041e0 TRACE structure gststructure.c:392:gst_structure_free: free structure 0x7f5568046b60
0:00:24.702436489 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:216:_gst_caps_free: freeing caps 0x55be0d91b4f0
0:00:24.702441172 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d716ad0 unref 2->1
0:00:24.702451049 19001 0x55be0e5041e0 DEBUG GST_PADS gstpad.c:3437:gst_pad_query_default:queue2:sink not forwarding 0x55be0d924b20 (caps) query
0:00:24.702456011 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstobject.c:263:gst_object_unref: 0x55be62146660 unref 2->1
0:00:24.702461909 19001 0x55be0e5041e0 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:queue2:sink sent query 0x55be0d924b20 (caps), result 1
0:00:24.702476105 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstobject.c:263:gst_object_unref:queue2:sink 0x55be62141cb0 unref 2->1
0:00:24.702487094 19001 0x55be0e5041e0 DEBUG default gstutils.c:2769:query_caps_func:tagger1:src intersect with result video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702493274 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:262:gst_caps_new_empty: created caps 0x7f5594008b70
0:00:24.702498359 19001 0x55be0e5041e0 TRACE structure gststructure.c:154:gst_structure_new_id_empty_with_size: created structure 0x55be0d91d440
0:00:24.702512155 19001 0x55be0e5041e0 DEBUG default gstutils.c:2771:query_caps_func:tagger1:src intersected video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702517431 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f5594008ad0 unref 4->3
0:00:24.702523537 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x55be0d6ef400 ref 5->6
0:00:24.702534049 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x7f5594008b70 ref 1->2
0:00:24.702538555 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f5594008b70 unref 2->1
0:00:24.702543036 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d6ef400 unref 6->5
0:00:24.702548400 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x7f5594008b70 ref 1->2
0:00:24.702553803 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d716ad0 unref 1->0
0:00:24.702559322 19001 0x55be0e5041e0 TRACE structure gststructure.c:392:gst_structure_free: free structure 0x7f55b3473c20
0:00:24.702563928 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:216:_gst_caps_free: freeing caps 0x55be0d716ad0
0:00:24.702569030 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f5594008b70 unref 2->1
0:00:24.702575490 19001 0x55be0e5041e0 DEBUG GST_PADS gstpad.c:3437:gst_pad_query_default:tagger1:sink not forwarding 0x55be0d924b20 (caps) query
0:00:24.702581222 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstobject.c:263:gst_object_unref: 0x55be62144800 unref 2->1
0:00:24.702586727 19001 0x55be0e5041e0 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:tagger1:sink sent query 0x55be0d924b20 (caps), result 1
0:00:24.702591802 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstobject.c:263:gst_object_unref:tagger1:sink 0x55be62140340 unref 2->1
0:00:24.702596929 19001 0x55be0e5041e0 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:autovideoconvert4:src do probes
0:00:24.702611172 19001 0x55be0e5041e0 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:autovideoconvert4:src hook 1 with flags 0x00003100 does not match 00002200
0:00:24.702623103 19001 0x55be0e5041e0 DEBUG default gstutils.c:2769:query_caps_func:autovideoconvert4:src intersect with result video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702627739 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:262:gst_caps_new_empty: created caps 0x7f55ab997540
0:00:24.702633398 19001 0x55be0e5041e0 TRACE structure gststructure.c:154:gst_structure_new_id_empty_with_size: created structure 0x7f55b8035480
0:00:24.702643344 19001 0x55be0e5041e0 DEBUG default gstutils.c:2771:query_caps_func:autovideoconvert4:src intersected video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702647906 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f5594008ad0 unref 3->2
0:00:24.702652837 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x55be0d929ad0 ref 23->24
0:00:24.702656915 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x7f55ab997540 ref 1->2
0:00:24.702662303 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f55ab997540 unref 2->1
0:00:24.702667508 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d929ad0 unref 24->23
0:00:24.702672541 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x7f55ab997540 ref 1->2
0:00:24.702677545 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f5594008b70 unref 1->0
0:00:24.702688150 19001 0x55be0e5041e0 TRACE structure gststructure.c:392:gst_structure_free: free structure 0x55be0d91d440
0:00:24.702696060 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:216:_gst_caps_free: freeing caps 0x7f5594008b70
0:00:24.702699881 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f55ab997540 unref 2->1
0:00:24.702705290 19001 0x55be0e5041e0 DEBUG GST_PADS gstpad.c:3437:gst_pad_query_default:src:proxypad142 not forwarding 0x55be0d924b20 (caps) query
0:00:24.702709046 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstobject.c:263:gst_object_unref:autovideoconvert4:src 0x55be621aa580 unref 3->2
0:00:24.702713095 19001 0x55be0e5041e0 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:src:proxypad142 sent query 0x55be0d924b20 (caps), result 1
0:00:24.702718465 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstobject.c:263:gst_object_unref:src:proxypad142 0x7f55b42e25a0 unref 2->1
0:00:24.702722872 19001 0x55be0e5041e0 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:<’’:sink_internal> sent query 0x55be0d924b20 (caps), result 1
0:00:24.702726419 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x7f55ab997540 ref 1->2
0:00:24.702734907 19001 0x55be0e5041e0 DEBUG GST_CAPS gstutils.c:3064:gst_pad_query_caps:<’’:sink_internal> query returned video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702741138 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x55be0d924b20 unref 1->0
0:00:24.702746339 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f5594008ad0 unref 2->1
0:00:24.702750684 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f55ab997540 unref 2->1
0:00:24.702754552 19001 0x55be0e5041e0 TRACE structure gststructure.c:392:gst_structure_free: free structure 0x7f554935ee80
0:00:24.702763192 19001 0x55be0e5041e0 DEBUG basetransform gstbasetransform.c:1124:gst_base_transform_find_transform: Resulted in video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702769121 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:465:gst_mini_object_ref: 0x7f55a8009a80 ref 3->4
0:00:24.702785300 19001 0x55be0e5041e0 DEBUG basetransform gstbasetransform.c:1128:gst_base_transform_find_transform: Intersecting with template caps video/x-raw(memory:NVMM), format=(string){ I420, NV12, P010_10LE, BGRx, RGBA, GRAY8, GBR, RGB, BGR, UYVP }, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-raw, format=(string){ I420, NV12, P010_10LE, BGRx, RGBA, GRAY8, GBR, RGB, BGR, UYVP }, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:24.702790855 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:262:gst_caps_new_empty: created caps 0x7f55400044a0
0:00:24.702795004 19001 0x55be0e5041e0 TRACE structure gststructure.c:154:gst_structure_new_id_empty_with_size: created structure 0x7f55b807bee0
0:00:24.702807630 19001 0x55be0e5041e0 DEBUG basetransform gstbasetransform.c:1134:gst_base_transform_find_transform: Intersection: video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702813724 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f55ab997540 unref 1->0
0:00:24.702817717 19001 0x55be0e5041e0 TRACE structure gststructure.c:392:gst_structure_free: free structure 0x7f55b8035480
0:00:24.702821760 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:216:_gst_caps_free: freeing caps 0x7f55ab997540
0:00:24.702826463 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f55a8009a80 unref 4->3
0:00:24.702843278 19001 0x55be0e5041e0 DEBUG basetransform gstbasetransform.c:1140:gst_base_transform_find_transform: Intersecting with transformed caps video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string){ I420, NV12, P010_10LE, BGRx, RGBA, GRAY8, GBR, RGB, BGR, UYVP }; video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string){ I420, NV12, P010_10LE, BGRx, RGBA, GRAY8, GBR, RGB, BGR, UYVP }
0:00:24.702848718 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:262:gst_caps_new_empty: created caps 0x55be0d91ee30
0:00:24.702855268 19001 0x55be0e5041e0 TRACE structure gststructure.c:154:gst_structure_new_id_empty_with_size: created structure 0x7f554935eea0
0:00:24.702872970 19001 0x55be0e5041e0 DEBUG basetransform gstbasetransform.c:1145:gst_base_transform_find_transform: Intersection: video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702876654 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f55400044a0 unref 1->0
0:00:24.702881258 19001 0x55be0e5041e0 TRACE structure gststructure.c:392:gst_structure_free: free structure 0x7f55b807bee0
0:00:24.702885085 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:216:_gst_caps_free: freeing caps 0x7f55400044a0
0:00:24.702889384 19001 0x55be0e5041e0 TRACE GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0x7f5594008ad0 unref 1->0
0:00:24.702894341 19001 0x55be0e5041e0 TRACE structure gststructure.c:392:gst_structure_free: free structure 0x7f55b3473c00
0:00:24.702898657 19001 0x55be0e5041e0 TRACE structure gststructure.c:392:gst_structure_free: free structure 0x7f55b8035b60
0:00:24.702903139 19001 0x55be0e5041e0 TRACE caps-features gstcapsfeatures.c:418:gst_caps_features_free: free caps features 0x7f55b00032a0
0:00:24.702907182 19001 0x55be0e5041e0 TRACE GST_CAPS gstcaps.c:216:_gst_caps_free: freeing caps 0x7f5594008ad0
0:00:24.702917317 19001 0x55be0e5041e0 DEBUG basetransform gstbasetransform.c:1166:gst_base_transform_find_transform: have non-fixed caps video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB
0:00:24.702942242 19001 0x55be0e5041e0 DEBUG basetransform gstbasetransform.c:1172:gst_base_transform_find_transform: calling fixate_caps for video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB using caps video/x-raw, format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1 on pad nvvideoconvert20:src
0:00:24.702958191 19001 0x55be0e5041e0 DEBUG nvvideoconvert gstnvvideoconvert.c:1677:gst_nvvideoconvert_fixate_caps: trying to fixate othercaps video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)[ 1/2147483647, 2147483647/1 ], framerate=(fraction)30/1, format=(string)RGB based on caps video/x-raw, format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1
0:00:24.702969082 19001 0x55be0e5041e0 DEBUG nvvideoconvert gstnvvideoconvert.c:1795:gst_nvvideoconvert_fixate_caps: Input DAR: 16 / 9
Signal: SIGSEGV (Segmentation fault)
