Segmentation Fault in libnvds_nvmultiobjecttracker.so with Re-ID enabled on DeepStream 8.0 + Custom TensorRT 10.13
Issue Type: Bug / ABI Compatibility Issue
Hardware Platform: RTX 2060 GPU (x86_64)
DeepStream Version: 8.0 (8.0.0)
TensorRT Version: 10.13.2 (Custom build, System-wide installation)
NVIDIA GPU Driver Version: 580.95.05
CUDA Version: 12.8 (System)
Description
I am encountering a Segmentation Fault when enabling Re-ID (reidType: 2) in the NvDCF tracker on DeepStream 8.0. My environment uses a custom installation of TensorRT 10.13.2, whereas DeepStream 8.0 typically expects an older version (e.g., TRT 10.3).
Although I have successfully rebuilt the OSS gst-nvtracker plugin against TensorRT 10.13 headers to handle the wrapper compatibility, the application crashes inside the closed-source low-level library libnvds_nvmultiobjecttracker.so when it attempts to load the Re-ID engine.
Steps to Reproduce
  1. Environment Setup:
    • Install DeepStream 8.0.
    • Running deepstream-app with config tracker block
      [tracker]
      ll-config-file=/home/nvidia/deepstream-app/tracker/config_tracker_NvDCF_accuracy.yml
      display-tracking-id=1
      enable=1
      gpu-id=0
      ll-lib-file=/opt/nvidia/deepstream/deepstream-8.0/lib/libnvds_nvmultiobjecttracker.so
      tracker-height=256
      tracker-width=128
      Install custom TensorRT 10.13.2 at system level ([/usr/lib/x86_64-linux-gnu/libnvinfer.so.10.13.2](file:///usr/lib/x86_64-linux-gnu/libnvinfer.so.10.13.2)).
    • Rebuild gst-nvtracker plugin from sources/gst-plugins/gst-nvtracker linking against TRT 10.13. Ive converted the onnx to engine using the trtexec from the Tensorrt 10.13.2 bin directory
      trtexec
      –onnx=resnet50_market1501_aicity156.onnx
      –saveEngine=resnet50_market1501_aicity156.enfine
      –fp16
      –verbose
      –minShapes=input:1x3x256x128
      –optShapes=input:100x3x256x128
      –maxShapes=input:100x3x256x128
      –memPoolSize=workspace:2048M
  2. Configuration:
    • Use [config_tracker_NvDCF_accuracy.yml]
      config_tracker_NvDCF_accuracy.txt (8.7 KB)
    • Set reidType: 2 (Reid based reassoc).
    • Point to a valid Re-ID engine built with trtexec (TRT 10.13).
  3. Execution:
    • Run the DeepStream application.
Observed Behavior
The application crashes with a segmentation fault immediately upon loading the tracker.
GDB Backtrace:
#0  0x00007fff96b66da8 in ??? () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#1  0x00007fffd04c9aa1 in ??? () at /usr/lib/x86_64-linux-gnu/libnvinfer.so.10
#7  0x00007ffed43412c1 in TrtModule::loadTRTEngine() ()
    at /opt/nvidia/deepstream/deepstream-8.0/lib/libnvds_nvmultiobjecttracker.so
#8  0x00007ffed4343fd0 in TrtModule::initializeModel(...) ()
#12 0x00007ffed42a2d3a in NvMultiObjectTrackerBase::initialize(NvMotDataTypes::Size, unsigned long) ()
LDD Check:
Running ldd on the proprietary library:
ldd /opt/nvidia/deepstream/deepstream-8.0/lib/libnvds_nvmultiobjecttracker.so | grep nvinfer
        libnvinfer.so.10 => /usr/lib/x86_64-linux-gnu/libnvinfer.so.10 (0x000076e1d0600000)  <-- Points to TRT 10.13
Analysis
The crash appears to be a binary incompatibility (ABI mismatch) between libnvds_nvmultiobjecttracker.so and the newer TensorRT 10.13 runtime.
  • Without Re-ID (reidType: 0): The application works fine (NvDCF visual tracking works), likely because the specific TensorRT paths in the library are not exercised.
  • With Re-ID: The library attempts to deserialize the engine using TrtModule::loadTRTEngine. Since libnvds_nvmultiobjecttracker.so is closed-source and was likely compiled against an older TRT version (10.3?), it crashes when interacting with the TRT 10.13 objects/memory layout.
Request
Is there a way to obtain a version of libnvds_nvmultiobjecttracker.so compatible with newer TensorRT versions (10.13+), or is downgrading the system TensorRT the only solution? Respective rebuilding of the OSS plugin wrapper does not seem to solve the issue within the core proprietary library.
Seems like I’ve loaded other trt models alongside that conflicted with the trt runtime of the tracker. I’ve isolated the other models and the tracker engine is loading now correctly.
