Segmentation Fault on AGX Xavier but not on other machine
Hi all,
I was wondering if you would be able to provide me with some insight as to why the AGX Xavier is experiencing a segmentation fault at: model.predict(np.array([p]))[0]
It is line 40 of Step 5: Build Your First Python Chatbot Project - DZone AI
The program would work for five interactions but would get segmentation faults afterward. If I were to run the program again, I would just get segmentation faults until some time has passed. After running the debugging tool, I realized that the segmentation fault occurs exactly at model.predict(np.array([p]))[0].
I have tested out the code on my personal ubuntu laptop and it performs exceptionally well without error. It seems as though the AGX Xavier is experiencing issues with allocating and deallocating memory. So it seems as though the AGX is trying to access memory beyond its limitation, but I can’t seem to understand why this is an issue with the AGX. Is there a way to provide enough space to the AGX to allocate and deallocate?
Could you monitor the device status with tegrastats at the same time.
$ tegrastats
Segmentation fault usually is caused by the illegal access rather than OOM.
It will be good to confirm the memory usage first.
Hi AastaLLL
Below you will find the data from tegrastats. I started tegrastats the second I click play on visual studio. I asked about five questions before I got a segmentation fault this time. Sometimes I get a segmentation fault as soon as I start the code and then other times the code runs for a couple questions then closed with the segmentation fault.
> RAM 7919/31921MB (lfb 5326x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@1190,7%@1190,2%@1190,2%@1190,4%@1190,2%@1190,1%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@35C GPU@35.5C iwlwifi@37C Tdiode@38C PMIC@100C AUX@35C CPU@37C thermal@35.75C Tboard@35C
> RAM 7920/31921MB (lfb 5326x4MB) SWAP 6/15960MB (cached 1MB) CPU [21%@1190,12%@1190,20%@1190,17%@1190,11%@1190,13%@1190,20%@1190,10%@1190] EMC_FREQ 0% GR3D_FREQ 42% AO@35C GPU@36C iwlwifi@37C Tdiode@38C PMIC@100C AUX@35C CPU@37.5C thermal@35.75C Tboard@35C
> RAM 7932/31921MB (lfb 5326x4MB) SWAP 6/15960MB (cached 1MB) CPU [31%@2265,9%@2265,23%@2265,40%@2265,14%@2265,22%@2265,24%@2265,23%@2265] EMC_FREQ 0% GR3D_FREQ 3% AO@35C GPU@35.5C iwlwifi@37C Tdiode@38.25C PMIC@100C AUX@35.5C CPU@38.5C thermal@35.9C Tboard@35C
> RAM 7971/31921MB (lfb 5326x4MB) SWAP 6/15960MB (cached 1MB) CPU [32%@2265,28%@2265,44%@2265,38%@2265,21%@2265,41%@2265,26%@2265,25%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@35.5C GPU@36C iwlwifi@37C Tdiode@38.25C PMIC@100C AUX@35.5C CPU@38.5C thermal@36.55C Tboard@35C
> RAM 8006/31921MB (lfb 5326x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@2265,5%@2265,10%@2265,7%@2265,9%@2265,86%@2265,3%@2265,5%@2265] EMC_FREQ 0% GR3D_FREQ 16% AO@35.5C GPU@36C iwlwifi@36C Tdiode@38.5C PMIC@100C AUX@35.5C CPU@39C thermal@36.55C Tboard@35C
> RAM 8035/31921MB (lfb 5326x4MB) SWAP 6/15960MB (cached 1MB) CPU [35%@2265,21%@2265,11%@2265,10%@2265,10%@2265,47%@2265,16%@2265,14%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@35.5C GPU@36C iwlwifi@37C Tdiode@38.5C PMIC@100C AUX@35.5C CPU@38.5C thermal@36.85C Tboard@35C
> RAM 8057/31921MB (lfb 5326x4MB) SWAP 6/15960MB (cached 1MB) CPU [84%@2265,5%@2265,0%@2265,0%@2265,0%@2265,1%@2265,0%@2265,0%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@35.5C GPU@36C iwlwifi@37C Tdiode@38.75C PMIC@100C AUX@35.5C CPU@38.5C thermal@36.55C Tboard@35C
> RAM 8076/31921MB (lfb 5326x4MB) SWAP 6/15960MB (cached 1MB) CPU [73%@2265,6%@2265,0%@2265,0%@2265,0%@2265,0%@2265,1%@2265,2%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@35.5C GPU@36C iwlwifi@37C Tdiode@38.75C PMIC@100C AUX@35.5C CPU@38.5C thermal@36.55C Tboard@35C
> RAM 8092/31921MB (lfb 5326x4MB) SWAP 6/15960MB (cached 1MB) CPU [55%@2265,7%@2265,0%@2265,0%@2265,1%@2265,0%@2265,19%@2265,3%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@35.5C GPU@38.5C iwlwifi@37C Tdiode@38.75C PMIC@100C AUX@35.5C CPU@38.5C thermal@36.75C Tboard@35C
> RAM 8275/31921MB (lfb 5326x4MB) SWAP 6/15960MB (cached 1MB) CPU [24%@2265,17%@2265,12%@2265,27%@2265,3%@2265,3%@2265,8%@2265,31%@2265] EMC_FREQ 0% GR3D_FREQ 1% AO@36C GPU@36.5C iwlwifi@37C Tdiode@38.75C PMIC@100C AUX@36C CPU@39C thermal@37.05C Tboard@35C
> RAM 8646/31921MB (lfb 5311x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@2265,3%@2265,90%@2265,18%@2265,1%@2265,0%@2265,2%@2265,1%@2265] EMC_FREQ 0% GR3D_FREQ 1% AO@35.5C GPU@36C iwlwifi@37C Tdiode@38.75C PMIC@100C AUX@36C CPU@39C thermal@37.05C Tboard@35C
> RAM 14532/31921MB (lfb 3840x4MB) SWAP 6/15960MB (cached 1MB) CPU [3%@2265,1%@2265,100%@2265,1%@2265,0%@2265,0%@2265,2%@2265,2%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39C PMIC@100C AUX@36C CPU@39C thermal@37.05C Tboard@35C
> RAM 20500/31921MB (lfb 2348x4MB) SWAP 6/15960MB (cached 1MB) CPU [2%@2265,0%@2265,100%@2265,0%@2265,0%@2265,0%@2265,1%@2265,0%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@38.75C PMIC@100C AUX@36C CPU@39C thermal@37.05C Tboard@35C
> RAM 25642/31921MB (lfb 1063x4MB) SWAP 6/15960MB (cached 1MB) CPU [1%@2265,2%@2265,100%@2265,3%@2265,0%@2265,0%@2265,1%@2265,0%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@38.75C PMIC@100C AUX@36C CPU@39C thermal@36.9C Tboard@35C
> RAM 26311/31921MB (lfb 896x4MB) SWAP 6/15960MB (cached 1MB) CPU [3%@1497,3%@1497,25%@1190,13%@1190,0%@1190,0%@1190,2%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 8% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39C PMIC@100C AUX@36C CPU@38C thermal@37.05C Tboard@35C
> RAM 26317/31921MB (lfb 895x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@2265,5%@2265,2%@2265,4%@2265,2%@2265,0%@2265,3%@2265,15%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@35.5C GPU@36.5C iwlwifi@39C Tdiode@38.75C PMIC@100C AUX@36C CPU@39C thermal@36.6C Tboard@35C
> RAM 26319/31921MB (lfb 895x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@1190,10%@1190,12%@1190,6%@1190,19%@1190,6%@1190,12%@1190,9%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36C iwlwifi@38C Tdiode@38.75C PMIC@100C AUX@35.5C CPU@38C thermal@36.9C Tboard@35C
> RAM 26321/31921MB (lfb 895x4MB) SWAP 6/15960MB (cached 1MB) CPU [10%@1190,2%@1190,2%@1190,3%@1190,12%@1190,2%@1190,5%@1190,5%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@35.5C GPU@36C iwlwifi@41C Tdiode@38.75C PMIC@100C AUX@35.5C CPU@38C thermal@36.4C Tboard@35C
> RAM 26323/31921MB (lfb 895x4MB) SWAP 6/15960MB (cached 1MB) CPU [16%@2265,8%@2265,1%@2265,2%@2265,10%@2265,6%@2265,3%@2265,6%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@35.5C GPU@36C iwlwifi@37C Tdiode@38.75C PMIC@100C AUX@35.5C CPU@38.5C thermal@36.4C Tboard@35C
> RAM 26326/31921MB (lfb 895x4MB) SWAP 6/15960MB (cached 1MB) CPU [13%@2265,9%@2265,13%@2265,7%@2265,11%@2265,6%@2265,15%@2265,26%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@35.5C GPU@36.5C iwlwifi@37C Tdiode@38.75C PMIC@100C AUX@36C CPU@38.5C thermal@36.9C Tboard@35C
> RAM 26340/31921MB (lfb 895x4MB) SWAP 6/15960MB (cached 1MB) CPU [38%@2265,53%@2265,31%@2265,26%@2265,18%@2265,23%@2265,21%@2265,8%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@35.5C GPU@36.5C iwlwifi@38C Tdiode@39C PMIC@100C AUX@36C CPU@39.5C thermal@36.9C Tboard@35C
> RAM 26358/31921MB (lfb 895x4MB) SWAP 6/15960MB (cached 1MB) CPU [18%@2265,42%@2265,41%@2265,42%@2265,14%@2265,14%@2265,15%@2265,19%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39C PMIC@100C AUX@36C CPU@40C thermal@37.35C Tboard@35C
> RAM 26372/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [26%@2265,26%@2265,24%@2265,50%@2265,13%@2265,18%@2265,29%@2265,21%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@41C Tdiode@39.25C PMIC@100C AUX@36.5C CPU@40C thermal@37.35C Tboard@35C
> RAM 26388/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [51%@2265,19%@2265,11%@2265,17%@2265,15%@2265,14%@2265,41%@2265,20%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39C PMIC@100C AUX@36.5C CPU@40C thermal@37.85C Tboard@35C
> RAM 26416/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [16%@2265,35%@2265,11%@2265,22%@2265,4%@2265,18%@2265,16%@2265,54%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@37C iwlwifi@38C Tdiode@39.25C PMIC@100C AUX@36.5C CPU@40C thermal@37.7C Tboard@35C
> RAM 26431/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [26%@2265,41%@2265,9%@2265,17%@2265,14%@2265,34%@2265,22%@2265,28%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.25C PMIC@100C AUX@36.5C CPU@40C thermal@37.7C Tboard@35C
> RAM 26443/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [25%@2265,23%@2265,35%@2265,33%@2265,46%@2265,27%@2265,47%@2265,18%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@37C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@40C thermal@37.7C Tboard@35C
> RAM 26447/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@2265,7%@2265,42%@2265,33%@2265,13%@2265,20%@2265,43%@2265,44%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@40C thermal@37.85C Tboard@35C
> RAM 26447/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [20%@2265,10%@2265,30%@2265,27%@2265,33%@2265,37%@2265,49%@2265,35%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.75C PMIC@100C AUX@37C CPU@40.5C thermal@38C Tboard@35C
> RAM 26462/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [9%@2265,17%@2265,13%@2265,14%@2265,19%@2265,65%@2265,35%@2265,6%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@40.5C iwlwifi@41C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@40.5C thermal@38C Tboard@35C
> RAM 26482/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [12%@2265,9%@2265,22%@2265,38%@2265,9%@2265,17%@2265,29%@2265,37%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@40C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@40C thermal@38C Tboard@35C
> RAM 26486/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [23%@2265,15%@2265,25%@2265,3%@2265,16%@2265,28%@2265,13%@2265,9%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37.5C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@37C CPU@39.5C thermal@38.2C Tboard@35C
> RAM 26485/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [9%@1190,3%@1190,6%@1190,0%@1190,2%@1190,3%@1190,2%@1190,0%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@39C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@39C thermal@37.55C Tboard@35C
> RAM 26485/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,4%@1190,0%@1190,1%@1190,4%@1190,2%@1190,0%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@39C thermal@37.25C Tboard@36C
> RAM 26484/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,7%@1190,4%@1190,0%@1190,2%@1190,1%@1190,5%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@38C Tdiode@39.25C PMIC@100C AUX@36.5C CPU@38.5C thermal@37.25C Tboard@36C
> RAM 26487/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [15%@1804,16%@1804,5%@1804,5%@1804,5%@1804,3%@1804,2%@1804,0%@1804] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@37C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36C CPU@38.5C thermal@37.4C Tboard@36C
> RAM 26489/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,1%@1190,2%@1190,0%@1190,1%@1190,1%@1190,3%@1190,7%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@37C iwlwifi@39C Tdiode@39.25C PMIC@100C AUX@36C CPU@38.5C thermal@37.05C Tboard@36C
> RAM 26490/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [10%@1190,15%@1190,6%@1190,5%@1190,8%@1190,3%@1190,10%@1190,6%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@37C iwlwifi@37C Tdiode@39.25C PMIC@100C AUX@36C CPU@38.5C thermal@37.1C Tboard@36C
> RAM 26490/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@1958,2%@1958,5%@1958,3%@1958,9%@1958,3%@1958,5%@1958,2%@1958] EMC_FREQ 0% GR3D_FREQ 43% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.25C PMIC@100C AUX@36C CPU@39C thermal@36.9C Tboard@36C
> RAM 26489/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [13%@2035,12%@2035,15%@2265,13%@2265,11%@2265,12%@2265,22%@2265,11%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@40C Tdiode@39.25C PMIC@100C AUX@36C CPU@39.5C thermal@37.55C Tboard@36C
> RAM 26519/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@2265,3%@2265,43%@2265,19%@2265,7%@2265,2%@2265,23%@2265,35%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@39.5C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@39.5C thermal@37.55C Tboard@36C
> RAM 26545/31921MB (lfb 894x4MB) SWAP 6/15960MB (cached 1MB) CPU [9%@2265,12%@2265,13%@2265,11%@2265,20%@2265,42%@2265,12%@2265,29%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@39C Tdiode@39.25C PMIC@100C AUX@36.5C CPU@40C thermal@37.55C Tboard@36C
> RAM 26709/31921MB (lfb 887x4MB) SWAP 6/15960MB (cached 1MB) CPU [75%@2265,10%@2265,44%@2265,12%@2265,20%@2265,10%@2265,9%@2265,65%@2265] EMC_FREQ 0% GR3D_FREQ 4% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@40C thermal@37.85C Tboard@36C
> RAM 26899/31921MB (lfb 842x4MB) SWAP 6/15960MB (cached 1MB) CPU [31%@2265,15%@2265,17%@2265,60%@2265,30%@2265,17%@2265,24%@2265,9%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@40C thermal@37.7C Tboard@36C
> RAM 26917/31921MB (lfb 838x4MB) SWAP 6/15960MB (cached 1MB) CPU [15%@2265,22%@2265,25%@2265,4%@2265,32%@2265,61%@2265,37%@2265,21%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37.5C iwlwifi@37C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@40.5C thermal@37.7C Tboard@36C
> RAM 26933/31921MB (lfb 835x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@2265,6%@2265,16%@2265,15%@2265,21%@2265,45%@2265,17%@2265,30%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37.5C iwlwifi@37C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@40.5C thermal@37.7C Tboard@36C
> RAM 26950/31921MB (lfb 830x4MB) SWAP 6/15960MB (cached 1MB) CPU [30%@2265,20%@2265,24%@2265,14%@2265,15%@2265,4%@2265,19%@2265,43%@2265] EMC_FREQ 0% GR3D_FREQ 11% AO@37C GPU@37.5C iwlwifi@37C Tdiode@39.75C PMIC@100C AUX@37C CPU@40.5C thermal@38.05C Tboard@36C
> RAM 26961/31921MB (lfb 827x4MB) SWAP 6/15960MB (cached 1MB) CPU [17%@2265,7%@2265,17%@2265,21%@2265,15%@2265,18%@2265,22%@2265,21%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@37.5C iwlwifi@37C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@39.5C thermal@38.05C Tboard@36C
> RAM 26961/31921MB (lfb 827x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@1190,2%@1190,0%@1190,1%@1190,2%@1190,0%@1190,3%@1190,4%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@38.5C thermal@37.4C Tboard@36C
> RAM 26962/31921MB (lfb 827x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@1190,1%@1190,0%@1190,1%@1190,0%@1190,0%@1190,4%@1190,0%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@38.5C thermal@37.25C Tboard@36C
> RAM 26962/31921MB (lfb 827x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,2%@1190,1%@1190,1%@1190,0%@1190,0%@1190,2%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@38.5C thermal@37.25C Tboard@36C
> RAM 26962/31921MB (lfb 827x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@1190,4%@1190,1%@1190,1%@1190,3%@1190,4%@1190,4%@1190,3%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@38.5C iwlwifi@43C Tdiode@39.25C PMIC@100C AUX@36.5C CPU@38.5C thermal@37.25C Tboard@36C
> RAM 26962/31921MB (lfb 827x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,1%@1190,0%@1190,2%@1190,1%@1190,0%@1190,5%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@40C Tdiode@39.5C PMIC@100C AUX@36C CPU@38.5C thermal@37.25C Tboard@36C
> RAM 26961/31921MB (lfb 827x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,2%@1190,1%@1190,1%@1190,0%@1190,0%@1190,2%@1190,5%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39.25C PMIC@100C AUX@36C CPU@38.5C thermal@37.05C Tboard@36C
> RAM 26991/31921MB (lfb 821x4MB) SWAP 6/15960MB (cached 1MB) CPU [18%@2265,7%@2265,3%@2265,6%@2265,3%@2265,3%@2265,6%@2265,2%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39.25C PMIC@100C AUX@36C CPU@39.5C thermal@37.05C Tboard@36C
> RAM 27019/31921MB (lfb 810x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@1190,4%@1190,5%@1190,7%@1190,7%@1190,23%@1190,13%@1190,5%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@36.5C iwlwifi@38C Tdiode@39.25C PMIC@100C AUX@36C CPU@38.5C thermal@37.05C Tboard@36C
> RAM 27020/31921MB (lfb 809x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,2%@1190,3%@1190,14%@1190,1%@1190,2%@1190,5%@1190,3%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@38C Tdiode@39.25C PMIC@100C AUX@36C CPU@38.5C thermal@37.25C Tboard@36C
> RAM 27021/31921MB (lfb 809x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,2%@1190,1%@1190,0%@1190,5%@1190,0%@1190,2%@1190,3%@1190] EMC_FREQ 0% GR3D_FREQ 10% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39.25C PMIC@100C AUX@36C CPU@38.5C thermal@36.9C Tboard@36C
> RAM 27021/31921MB (lfb 809x4MB) SWAP 6/15960MB (cached 1MB) CPU [3%@1190,0%@1190,1%@1190,5%@1190,6%@1190,0%@1190,3%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39C PMIC@100C AUX@36C CPU@38.5C thermal@36.75C Tboard@36C
> RAM 27021/31921MB (lfb 809x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@1190,2%@1190,5%@1190,1%@1190,6%@1190,0%@1190,0%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39.25C PMIC@100C AUX@36C CPU@38.5C thermal@36.75C Tboard@36C
> RAM 27021/31921MB (lfb 809x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@1190,2%@1190,1%@1190,0%@1190,5%@1190,0%@1190,1%@1190,0%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39C PMIC@100C AUX@36C CPU@38.5C thermal@36.75C Tboard@36C
> RAM 27021/31921MB (lfb 809x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,0%@1190,0%@1190,1%@1190,4%@1190,0%@1190,1%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39C PMIC@100C AUX@36C CPU@38C thermal@36.9C Tboard@36C
> RAM 27021/31921MB (lfb 809x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@1190,1%@1190,0%@1190,1%@1190,0%@1190,0%@1190,1%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@38C iwlwifi@37C Tdiode@39C PMIC@100C AUX@36C CPU@38C thermal@36.75C Tboard@36C
> RAM 27021/31921MB (lfb 809x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,3%@1190,0%@1190,0%@1190,1%@1190,1%@1190,4%@1190,0%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@35.5C GPU@36.5C iwlwifi@37C Tdiode@39C PMIC@100C AUX@35.5C CPU@38C thermal@36.55C Tboard@36C
> RAM 27021/31921MB (lfb 809x4MB) SWAP 6/15960MB (cached 1MB) CPU [3%@1190,4%@1190,0%@1190,0%@1190,2%@1190,1%@1190,1%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36C iwlwifi@37C Tdiode@39C PMIC@100C AUX@35.5C CPU@38C thermal@36.75C Tboard@36C
> RAM 27021/31921MB (lfb 809x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,3%@1190,0%@1190,0%@1190,1%@1190,3%@1190,3%@1190,0%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36C iwlwifi@37C Tdiode@38.75C PMIC@100C AUX@35.5C CPU@38C thermal@36.75C Tboard@36C
> RAM 27021/31921MB (lfb 809x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,1%@1190,0%@1190,0%@1190,1%@1190,2%@1190,4%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39C PMIC@100C AUX@35.5C CPU@38C thermal@36.4C Tboard@36C
> RAM 27022/31921MB (lfb 810x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@1190,3%@1190,7%@1190,1%@1190,3%@1190,0%@1190,4%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@38C Tdiode@39C PMIC@100C AUX@35.5C CPU@37.5C thermal@36.4C Tboard@36C
> RAM 27036/31921MB (lfb 805x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@2265,2%@2265,2%@2265,2%@2265,1%@2265,78%@2265,2%@2265,1%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@38C Tdiode@39C PMIC@100C AUX@36C CPU@38.5C thermal@37.5C Tboard@36C
> RAM 27054/31921MB (lfb 801x4MB) SWAP 6/15960MB (cached 1MB) CPU [3%@2265,1%@2265,1%@2265,0%@2265,0%@1190,100%@1190,2%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39C PMIC@100C AUX@36C CPU@38.5C thermal@37.5C Tboard@36C
> RAM 27074/31921MB (lfb 796x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@1190,2%@1190,1%@1190,1%@1190,0%@1190,100%@1190,1%@1190,0%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39.25C PMIC@100C AUX@36C CPU@38.5C thermal@37.05C Tboard@36C
> RAM 27093/31921MB (lfb 792x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@2265,2%@2265,0%@2265,0%@2265,0%@2265,100%@2265,1%@2265,0%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39.25C PMIC@100C AUX@36C CPU@39C thermal@37.2C Tboard@36C
> RAM 27046/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [12%@1190,4%@1190,3%@1190,13%@1190,5%@1190,17%@1190,17%@1190,14%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@42C Tdiode@39.25C PMIC@100C AUX@36C CPU@38.5C thermal@37.35C Tboard@36C
> RAM 27046/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,3%@1190,1%@1190,0%@1190,0%@1190,0%@1190,2%@1190,7%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@39C Tdiode@39C PMIC@100C AUX@36C CPU@38.5C thermal@36.9C Tboard@36C
> RAM 27048/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [9%@1190,10%@1190,4%@1190,5%@1190,2%@1190,6%@1190,8%@1190,7%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@38C Tdiode@39.25C PMIC@100C AUX@36C CPU@38.5C thermal@36.9C Tboard@36C
> RAM 27048/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@1190,2%@1190,2%@1190,2%@1190,1%@1190,0%@1190,3%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39C PMIC@100C AUX@36C CPU@38.5C thermal@36.9C Tboard@36C
> RAM 27049/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,2%@1190,2%@1190,3%@1190,1%@1190,0%@1190,5%@1190,3%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39C PMIC@100C AUX@36C CPU@38C thermal@36.75C Tboard@36C
> RAM 27049/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [3%@1190,1%@1190,0%@1190,2%@1190,1%@1190,0%@1190,2%@1190,3%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@37C Tdiode@39C PMIC@100C AUX@36C CPU@38C thermal@36.75C Tboard@36C
> RAM 27049/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [14%@2265,10%@2265,9%@2265,12%@2265,8%@2265,5%@2265,9%@2265,11%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@36.5C iwlwifi@38C Tdiode@39C PMIC@100C AUX@36C CPU@39C thermal@37.05C Tboard@36C
> RAM 26981/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@2265,3%@2265,36%@2265,33%@2265,25%@2265,3%@2265,34%@2265,35%@2265] EMC_FREQ 0% GR3D_FREQ 18% AO@36C GPU@37C iwlwifi@37C Tdiode@39.25C PMIC@100C AUX@36C CPU@39.5C thermal@37.05C Tboard@36C
> RAM 26981/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [10%@2265,4%@2265,46%@2265,14%@2265,12%@2265,10%@2265,43%@2265,31%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.25C PMIC@100C AUX@36.5C CPU@40C thermal@37.5C Tboard@36C
> RAM 26955/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,3%@1190,30%@1190,32%@1190,3%@1190,2%@1190,38%@1190,6%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.25C PMIC@100C AUX@36.5C CPU@38.5C thermal@37.55C Tboard@36C
> RAM 26955/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@2265,3%@2265,98%@2265,0%@2265,0%@2265,0%@2265,1%@2265,98%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@40C thermal@37.7C Tboard@36C
> RAM 26942/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@1190,4%@1190,6%@1190,0%@1190,6%@1190,0%@1190,32%@1190,8%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@38.5C thermal@37.7C Tboard@36C
> RAM 26941/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@1190,0%@1190,1%@1190,2%@1190,8%@1190,4%@1190,1%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@38.5C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@38.5C thermal@37.25C Tboard@36C
> RAM 26941/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@1190,3%@1190,1%@1190,0%@1190,2%@1190,1%@1190,1%@1190,0%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36C GPU@37C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36C CPU@38.5C thermal@37.7C Tboard@36C
> RAM 26941/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [9%@1190,5%@1190,4%@1190,4%@1190,6%@1190,2%@1190,5%@1190,4%@1190] EMC_FREQ 0% GR3D_FREQ 1% AO@36C GPU@37C iwlwifi@37C Tdiode@39.25C PMIC@100C AUX@36C CPU@38.5C thermal@36.9C Tboard@36C
> RAM 26944/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@2265,23%@2265,10%@2265,18%@2265,23%@2265,9%@2265,23%@2265,18%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@40C thermal@37.7C Tboard@36C
> RAM 26964/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [35%@2265,29%@2265,29%@2265,15%@2265,25%@2265,6%@2265,25%@2265,37%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@38C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@40.5C thermal@37.7C Tboard@36C
> RAM 26978/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [12%@2265,18%@2265,35%@2265,30%@2265,11%@2265,25%@2265,26%@2265,41%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@39C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@40C thermal@37.7C Tboard@36C
> RAM 26992/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [38%@2265,56%@2265,54%@2265,30%@2265,40%@2265,29%@2265,24%@2265,20%@2265] EMC_FREQ 0% GR3D_FREQ 39% AO@36.5C GPU@37.5C iwlwifi@40C Tdiode@39.75C PMIC@100C AUX@37C CPU@41.5C thermal@37.85C Tboard@36C
> RAM 27014/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [88%@2265,55%@2265,44%@2265,51%@2265,63%@2265,72%@2265,68%@2265,65%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@37.5C iwlwifi@38C Tdiode@40C PMIC@100C AUX@37C CPU@42C thermal@38.5C Tboard@36C
> RAM 27018/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [52%@2265,31%@2265,31%@2265,27%@2265,33%@2265,66%@2265,23%@2265,49%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@38C iwlwifi@37C Tdiode@40C PMIC@100C AUX@37C CPU@41C thermal@38.55C Tboard@36C
> RAM 27027/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [30%@2265,17%@2265,19%@2265,27%@2265,31%@2265,50%@2265,14%@2265,47%@2265] EMC_FREQ 0% GR3D_FREQ 45% AO@37C GPU@38C iwlwifi@39C Tdiode@40.25C PMIC@100C AUX@37.5C CPU@41C thermal@38.85C Tboard@36C
> RAM 27052/31921MB (lfb 800x4MB) SWAP 6/15960MB (cached 1MB) CPU [35%@2265,14%@2265,18%@2265,12%@2265,42%@2265,29%@2265,41%@2265,48%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@38C iwlwifi@38C Tdiode@40.25C PMIC@100C AUX@37.5C CPU@41C thermal@38.55C Tboard@36C
> RAM 27063/31921MB (lfb 799x4MB) SWAP 6/15960MB (cached 1MB) CPU [36%@2265,28%@2265,46%@2265,19%@2265,35%@2265,38%@2265,16%@2265,32%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@38C iwlwifi@37C Tdiode@40.25C PMIC@100C AUX@37.5C CPU@41C thermal@38.85C Tboard@36C
> RAM 27078/31921MB (lfb 795x4MB) SWAP 6/15960MB (cached 1MB) CPU [20%@2265,42%@2265,38%@2265,11%@2265,24%@2265,11%@2265,40%@2265,27%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@38C iwlwifi@43C Tdiode@40.5C PMIC@100C AUX@37.5C CPU@41C thermal@38.7C Tboard@36C
> RAM 27097/31921MB (lfb 791x4MB) SWAP 6/15960MB (cached 1MB) CPU [15%@2265,17%@2265,10%@2265,41%@2265,33%@2265,20%@2265,22%@2265,17%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@41C iwlwifi@38C Tdiode@40.25C PMIC@100C AUX@37.5C CPU@41C thermal@38.85C Tboard@36C
> RAM 27107/31921MB (lfb 789x4MB) SWAP 6/15960MB (cached 1MB) CPU [9%@1190,15%@1190,9%@1190,2%@1190,10%@1190,10%@1190,19%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38C iwlwifi@38C Tdiode@40.5C PMIC@100C AUX@37.5C CPU@39.5C thermal@38.1C Tboard@36C
> RAM 27107/31921MB (lfb 787x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@1190,5%@1190,7%@1190,1%@1190,0%@1190,0%@1190,1%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@37.5C iwlwifi@39C Tdiode@40.5C PMIC@100C AUX@37.5C CPU@39.5C thermal@38.1C Tboard@36C
> RAM 27108/31921MB (lfb 786x4MB) SWAP 6/15960MB (cached 1MB) CPU [14%@2265,4%@2265,2%@2265,2%@2265,0%@2265,1%@2265,3%@2265,3%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@37.5C iwlwifi@38C Tdiode@40.25C PMIC@100C AUX@37.5C CPU@40C thermal@38.1C Tboard@36C
> RAM 27109/31921MB (lfb 786x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@1190,3%@1190,2%@1190,1%@1190,1%@1190,0%@1190,3%@1190,3%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@37.5C iwlwifi@38C Tdiode@40.25C PMIC@100C AUX@37C CPU@39C thermal@37.9C Tboard@36C
> RAM 27109/31921MB (lfb 786x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,4%@1190,1%@1190,2%@1190,5%@1190,0%@1190,5%@1190,5%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@37.5C iwlwifi@39C Tdiode@40C PMIC@100C AUX@37C CPU@39C thermal@37.9C Tboard@36C
> RAM 27109/31921MB (lfb 786x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,4%@1190,0%@1190,1%@1190,1%@1190,0%@1190,2%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@39C iwlwifi@41C Tdiode@40C PMIC@100C AUX@37C CPU@39C thermal@37.75C Tboard@36C
> RAM 27109/31921MB (lfb 786x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,3%@1190,1%@1190,2%@1190,1%@1190,0%@1190,3%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37.5C iwlwifi@38C Tdiode@40C PMIC@100C AUX@37C CPU@39C thermal@37.75C Tboard@36C
> RAM 27111/31921MB (lfb 786x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@2265,8%@2265,10%@2265,8%@2265,5%@2265,4%@2265,8%@2265,13%@2265] EMC_FREQ 0% GR3D_FREQ 35% AO@36.5C GPU@37.5C iwlwifi@38C Tdiode@39.75C PMIC@100C AUX@37C CPU@39.5C thermal@37.75C Tboard@36C
> RAM 27111/31921MB (lfb 787x4MB) SWAP 6/15960MB (cached 1MB) CPU [23%@1190,18%@1190,20%@1190,14%@1190,15%@1190,10%@1190,18%@1190,15%@1190] EMC_FREQ 0% GR3D_FREQ 7% AO@37C GPU@37C iwlwifi@41C Tdiode@40C PMIC@100C AUX@37C CPU@39C thermal@37.7C Tboard@36C
> RAM 27113/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [42%@1420,32%@1420,17%@1420,34%@1420,24%@1420,16%@1420,28%@1420,31%@1420] EMC_FREQ 0% GR3D_FREQ 43% AO@37C GPU@37.5C iwlwifi@38C Tdiode@39.75C PMIC@100C AUX@37C CPU@39.5C thermal@38.05C Tboard@36C
> RAM 27114/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@1190,9%@1190,18%@1190,15%@1190,12%@1190,9%@1190,11%@1190,10%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@37.5C iwlwifi@38C Tdiode@40C PMIC@100C AUX@37C CPU@39C thermal@37.75C Tboard@36C
> RAM 27114/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,4%@1190,4%@1190,6%@1190,4%@1190,1%@1190,12%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@37.5C iwlwifi@38C Tdiode@40C PMIC@100C AUX@37C CPU@39C thermal@37.75C Tboard@36C
> RAM 27115/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [30%@2265,12%@2265,26%@2265,16%@2265,10%@2265,11%@2265,15%@2265,14%@2265] EMC_FREQ 0% GR3D_FREQ 40% AO@37C GPU@37.5C iwlwifi@37C Tdiode@40C PMIC@100C AUX@37C CPU@40C thermal@37.55C Tboard@36C
> RAM 27115/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [12%@1190,7%@1190,6%@1190,7%@1190,4%@1190,4%@1190,7%@1190,5%@1190] EMC_FREQ 0% GR3D_FREQ 1% AO@36.5C GPU@37.5C iwlwifi@39C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@39C thermal@37.9C Tboard@36C
> RAM 27115/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,6%@1190,3%@1190,3%@1190,5%@1190,1%@1190,2%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@38C Tdiode@40C PMIC@100C AUX@36.5C CPU@39C thermal@37.75C Tboard@36C
> RAM 27115/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,2%@1190,1%@1190,0%@1190,8%@1190,0%@1190,1%@1190,0%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@37C Tdiode@39.75C PMIC@100C AUX@37C CPU@38.5C thermal@37.4C Tboard@36C
> RAM 27115/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,4%@1190,3%@1190,3%@1190,4%@1190,0%@1190,5%@1190,7%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37.5C iwlwifi@42C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@39C thermal@37.4C Tboard@36C
> RAM 27114/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,3%@1190,4%@1190,13%@1190,3%@1190,5%@1190,6%@1190,5%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@40C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@39C thermal@37.4C Tboard@36C
> RAM 27114/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@1190,5%@1190,3%@1190,3%@1190,8%@1190,9%@1190,15%@1190,16%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@43C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@39C thermal@37.55C Tboard@36C
> RAM 27115/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [15%@1881,5%@1881,5%@1881,8%@1881,4%@1881,3%@1881,9%@1651,5%@1651] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@39C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@39C thermal@37.4C Tboard@36C
> RAM 27115/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@1190,4%@1190,6%@1190,5%@1190,4%@1190,9%@1190,5%@1190,5%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@38C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@38.5C thermal@37.4C Tboard@36C
> RAM 27114/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@2265,9%@2265,7%@2265,3%@2265,4%@2265,8%@2265,6%@2265,4%@2265] EMC_FREQ 0% GR3D_FREQ 5% AO@36.5C GPU@37C iwlwifi@38C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@39C thermal@37.4C Tboard@36C
> RAM 27113/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [20%@2265,21%@2265,17%@2265,15%@2265,14%@2265,18%@2265,17%@2265,12%@2265] EMC_FREQ 0% GR3D_FREQ 32% AO@36.5C GPU@37C iwlwifi@38C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@39.5C thermal@37.4C Tboard@36C
> RAM 27114/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [14%@1804,14%@1804,12%@1804,6%@1804,11%@1804,4%@1804,5%@1804,8%@1804] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@38C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@39C thermal@37.4C Tboard@36C
> RAM 27112/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@1190,13%@1190,9%@1190,7%@1190,9%@1190,5%@1190,9%@1190,3%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37.5C iwlwifi@38C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@39C thermal@37.25C Tboard@36C
> RAM 27113/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@2265,4%@2265,5%@2265,8%@2265,8%@2265,5%@2265,7%@2265,11%@2265] EMC_FREQ 0% GR3D_FREQ 41% AO@36.5C GPU@37C iwlwifi@38C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@40C thermal@37.7C Tboard@36C
> RAM 27114/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [10%@1190,8%@1190,6%@1190,11%@1190,8%@1190,6%@1190,12%@1190,7%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@39C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@39C thermal@37.4C Tboard@36C
> RAM 27115/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [14%@1190,11%@1190,15%@1190,13%@1190,10%@1190,9%@1190,13%@1190,11%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@36.5C GPU@37C iwlwifi@39C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@39C thermal@37.7C Tboard@36C
> RAM 27114/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@2265,6%@2265,8%@2265,5%@2265,5%@2265,5%@2265,4%@2265,8%@2265] EMC_FREQ 0% GR3D_FREQ 42% AO@36.5C GPU@37C iwlwifi@38C Tdiode@39.5C PMIC@100C AUX@36.5C CPU@39.5C thermal@37.4C Tboard@36C
> RAM 27113/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [15%@1497,11%@1497,18%@1497,11%@1497,10%@1497,10%@1497,14%@1497,12%@1497] EMC_FREQ 0% GR3D_FREQ 36% AO@36.5C GPU@37C iwlwifi@38C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@39.5C thermal@37.4C Tboard@36C
> RAM 27114/31921MB (lfb 783x4MB) SWAP 6/15960MB (cached 1MB) CPU [21%@2265,28%@2265,16%@2265,24%@2265,24%@2265,15%@2265,18%@2265,16%@2265] EMC_FREQ 0% GR3D_FREQ 39% AO@36.5C GPU@37.5C iwlwifi@38C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@40.5C thermal@37.7C Tboard@36C
> RAM 27119/31921MB (lfb 782x4MB) SWAP 6/15960MB (cached 1MB) CPU [28%@2265,21%@2265,13%@2265,35%@2265,28%@2265,32%@2265,24%@2265,31%@2265] EMC_FREQ 0% GR3D_FREQ 37% AO@36.5C GPU@37.5C iwlwifi@38C Tdiode@39.75C PMIC@100C AUX@37C CPU@40C thermal@37.85C Tboard@36C
> RAM 27119/31921MB (lfb 782x4MB) SWAP 6/15960MB (cached 1MB) CPU [14%@1190,13%@1190,18%@1190,8%@1190,16%@1190,19%@1190,7%@1190,14%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@37.5C iwlwifi@38C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@39C thermal@37.55C Tboard@36C
> RAM 27129/31921MB (lfb 781x4MB) SWAP 6/15960MB (cached 1MB) CPU [14%@2265,12%@2265,19%@2265,6%@2265,10%@2265,18%@2265,27%@2265,31%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@37.5C iwlwifi@38C Tdiode@40C PMIC@100C AUX@37C CPU@40C thermal@37.55C Tboard@36C
> RAM 27147/31921MB (lfb 777x4MB) SWAP 6/15960MB (cached 1MB) CPU [27%@2265,28%@2265,30%@2265,26%@2265,17%@2265,25%@2265,26%@2265,23%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@37.5C iwlwifi@41C Tdiode@40.25C PMIC@100C AUX@37C CPU@40.5C thermal@38.2C Tboard@36C
> RAM 27163/31921MB (lfb 773x4MB) SWAP 6/15960MB (cached 1MB) CPU [32%@2265,16%@2265,29%@2265,30%@2265,39%@2265,46%@2265,22%@2265,27%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@37.5C iwlwifi@38C Tdiode@40C PMIC@100C AUX@37C CPU@40.5C thermal@38.2C Tboard@36C
> RAM 27168/31921MB (lfb 772x4MB) SWAP 6/15960MB (cached 1MB) CPU [24%@2265,19%@2265,35%@2265,36%@2265,37%@2265,23%@2265,39%@2265,24%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37C GPU@37.5C iwlwifi@38C Tdiode@40C PMIC@100C AUX@37.5C CPU@41C thermal@38.85C Tboard@36C
> RAM 27170/31921MB (lfb 772x4MB) SWAP 6/15960MB (cached 1MB) CPU [33%@2265,34%@2265,15%@2265,10%@2265,21%@2265,16%@2265,29%@2265,48%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38C iwlwifi@43C Tdiode@40.25C PMIC@100C AUX@37.5C CPU@41C thermal@38.55C Tboard@36C
> RAM 27182/31921MB (lfb 768x4MB) SWAP 6/15960MB (cached 1MB) CPU [27%@2265,17%@2265,25%@2265,32%@2265,22%@2265,64%@2265,25%@2265,13%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38C iwlwifi@40C Tdiode@40.5C PMIC@100C AUX@37.5C CPU@41C thermal@38.7C Tboard@36C
> RAM 27196/31921MB (lfb 765x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@2265,16%@2265,19%@2265,13%@2265,30%@2265,27%@2265,23%@2265,34%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38C iwlwifi@38C Tdiode@40.5C PMIC@100C AUX@38C CPU@41C thermal@38.85C Tboard@36C
> RAM 27213/31921MB (lfb 761x4MB) SWAP 6/15960MB (cached 1MB) CPU [22%@2265,14%@2265,32%@2265,6%@2265,23%@2265,33%@2265,14%@2265,20%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38C iwlwifi@38C Tdiode@40.5C PMIC@100C AUX@37.5C CPU@40.5C thermal@38.55C Tboard@36C
> RAM 27239/31921MB (lfb 755x4MB) SWAP 6/15960MB (cached 1MB) CPU [16%@2265,16%@2265,28%@2265,9%@2265,32%@2265,14%@2265,30%@2265,6%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38C iwlwifi@41C Tdiode@40.5C PMIC@100C AUX@38C CPU@41C thermal@38.7C Tboard@36C
> RAM 27244/31921MB (lfb 753x4MB) SWAP 6/15960MB (cached 1MB) CPU [23%@2265,24%@2265,20%@2265,26%@2265,35%@2265,6%@2265,27%@2265,18%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38.5C iwlwifi@38C Tdiode@40.75C PMIC@100C AUX@37.5C CPU@41.5C thermal@38.7C Tboard@36C
> RAM 27274/31921MB (lfb 746x4MB) SWAP 6/15960MB (cached 1MB) CPU [12%@2265,10%@2265,16%@2265,29%@2265,3%@2265,27%@2265,17%@2265,49%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38.5C iwlwifi@40C Tdiode@40.75C PMIC@100C AUX@38C CPU@41C thermal@39.35C Tboard@37C
> RAM 27300/31921MB (lfb 739x4MB) SWAP 6/15960MB (cached 1MB) CPU [10%@2265,12%@2265,22%@2265,11%@2265,14%@2265,30%@2265,12%@2265,24%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@39C Tdiode@40.75C PMIC@100C AUX@38C CPU@41.5C thermal@38.9C Tboard@37C
> RAM 27331/31921MB (lfb 732x4MB) SWAP 6/15960MB (cached 1MB) CPU [19%@2265,12%@2265,24%@2265,33%@2265,8%@2265,10%@2265,17%@2265,6%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@40C Tdiode@40.75C PMIC@100C AUX@38C CPU@41C thermal@39.05C Tboard@37C
> RAM 27357/31921MB (lfb 725x4MB) SWAP 6/15960MB (cached 1MB) CPU [22%@2265,22%@2265,8%@2265,17%@2265,24%@2265,45%@2265,38%@2265,19%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@39C Tdiode@40.75C PMIC@100C AUX@38C CPU@41.5C thermal@39.2C Tboard@37C
> RAM 27370/31921MB (lfb 722x4MB) SWAP 6/15960MB (cached 1MB) CPU [21%@2265,26%@2265,15%@2265,30%@2265,4%@2265,2%@2265,17%@2265,28%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@39C Tdiode@41C PMIC@100C AUX@38C CPU@41.5C thermal@39.05C Tboard@37C
> RAM 27387/31921MB (lfb 717x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@2265,17%@2265,13%@2265,8%@2265,5%@2265,6%@2265,55%@2265,26%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@38C Tdiode@41C PMIC@100C AUX@38C CPU@41.5C thermal@39.2C Tboard@37C
> RAM 27412/31921MB (lfb 712x4MB) SWAP 6/15960MB (cached 1MB) CPU [21%@2265,31%@2265,3%@2265,6%@2265,11%@2265,20%@2265,9%@2265,31%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@38C Tdiode@41C PMIC@100C AUX@38C CPU@41C thermal@39.2C Tboard@37C
> RAM 27430/31921MB (lfb 707x4MB) SWAP 6/15960MB (cached 1MB) CPU [10%@2265,22%@2265,9%@2265,11%@2265,13%@2265,34%@2265,35%@2265,19%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@39C Tdiode@41C PMIC@100C AUX@38C CPU@41.5C thermal@39.2C Tboard@37C
> RAM 27459/31921MB (lfb 700x4MB) SWAP 6/15960MB (cached 1MB) CPU [20%@2265,15%@2265,19%@2265,33%@2265,10%@2265,26%@2265,3%@2265,15%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@38C Tdiode@41C PMIC@100C AUX@38.5C CPU@41.5C thermal@39.2C Tboard@37C
> RAM 27484/31921MB (lfb 693x4MB) SWAP 6/15960MB (cached 1MB) CPU [15%@2265,4%@2265,30%@2265,10%@2265,30%@2265,4%@2265,34%@2265,44%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@41C Tdiode@41C PMIC@100C AUX@38C CPU@41.5C thermal@39.2C Tboard@37C
> RAM 27499/31921MB (lfb 688x4MB) SWAP 6/15960MB (cached 1MB) CPU [52%@2265,19%@2265,36%@2265,31%@2265,21%@2265,15%@2265,38%@2265,25%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@42C Tdiode@41C PMIC@100C AUX@38.5C CPU@42.5C thermal@39.2C Tboard@37C
> RAM 27513/31921MB (lfb 685x4MB) SWAP 6/15960MB (cached 1MB) CPU [28%@2265,12%@2265,42%@2265,23%@2265,21%@2265,56%@2265,31%@2265,12%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@38C Tdiode@41.25C PMIC@100C AUX@38C CPU@41.5C thermal@39.7C Tboard@37C
> RAM 27528/31921MB (lfb 681x4MB) SWAP 6/15960MB (cached 1MB) CPU [22%@2265,22%@2265,14%@2265,40%@2265,31%@2265,20%@2265,11%@2265,14%@2265] EMC_FREQ 0% GR3D_FREQ 41% AO@38C GPU@38.5C iwlwifi@39C Tdiode@41.25C PMIC@100C AUX@38.5C CPU@41.5C thermal@39.55C Tboard@37C
> RAM 27550/31921MB (lfb 676x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@2265,23%@2265,7%@2265,11%@2265,32%@2265,15%@2265,27%@2265,14%@2265] EMC_FREQ 0% GR3D_FREQ 41% AO@38.5C GPU@39C iwlwifi@38C Tdiode@41.25C PMIC@100C AUX@38.5C CPU@41.5C thermal@39.4C Tboard@37C
> RAM 27578/31921MB (lfb 670x4MB) SWAP 6/15960MB (cached 1MB) CPU [9%@2265,3%@2265,22%@2265,29%@2265,15%@2265,18%@2265,28%@2265,20%@2265] EMC_FREQ 0% GR3D_FREQ 39% AO@38C GPU@39C iwlwifi@43C Tdiode@41C PMIC@100C AUX@38.5C CPU@42C thermal@39.7C Tboard@37C
> RAM 27608/31921MB (lfb 662x4MB) SWAP 6/15960MB (cached 1MB) CPU [22%@2265,19%@2265,30%@2265,31%@2265,57%@2265,28%@2265,18%@2265,10%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@39C iwlwifi@41C Tdiode@41.25C PMIC@100C AUX@38.5C CPU@42C thermal@39.55C Tboard@37C
> RAM 27640/31921MB (lfb 654x4MB) SWAP 6/15960MB (cached 1MB) CPU [28%@2265,13%@2265,19%@2265,7%@2265,7%@2265,26%@2265,33%@2265,25%@2265] EMC_FREQ 0% GR3D_FREQ 40% AO@38C GPU@39C iwlwifi@39C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@42C thermal@39.55C Tboard@37C
> RAM 27658/31921MB (lfb 649x4MB) SWAP 6/15960MB (cached 1MB) CPU [22%@2265,17%@2265,26%@2265,7%@2265,6%@2265,48%@2265,4%@2265,17%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@38.5C iwlwifi@39C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@42C thermal@39.7C Tboard@37C
> RAM 27684/31921MB (lfb 644x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@2265,24%@2265,23%@2265,32%@2265,8%@2265,41%@2265,8%@2265,9%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@38C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@41.5C thermal@39.7C Tboard@37C
> RAM 27717/31921MB (lfb 636x4MB) SWAP 6/15960MB (cached 1MB) CPU [17%@2265,12%@2265,13%@2265,31%@2265,8%@2265,26%@2265,18%@2265,10%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@39C iwlwifi@38C Tdiode@41.25C PMIC@100C AUX@38.5C CPU@41.5C thermal@39.55C Tboard@37C
> RAM 27741/31921MB (lfb 628x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@2265,13%@2265,18%@2265,28%@2265,16%@2265,9%@2265,22%@2265,63%@2265] EMC_FREQ 0% GR3D_FREQ 47% AO@38.5C GPU@39C iwlwifi@43C Tdiode@41.25C PMIC@100C AUX@38.5C CPU@43C thermal@39.85C Tboard@37C
> RAM 27763/31921MB (lfb 622x4MB) SWAP 6/15960MB (cached 1MB) CPU [19%@2265,3%@2265,8%@2265,23%@2265,8%@2265,49%@2265,17%@2265,27%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@39C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@42C thermal@39.85C Tboard@37C
> RAM 27775/31921MB (lfb 620x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@2265,28%@2265,20%@2265,47%@2265,1%@2265,3%@2265,19%@2265,12%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@38C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@42C thermal@39.7C Tboard@37C
> RAM 27801/31921MB (lfb 614x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@2265,5%@2265,29%@2265,42%@2265,8%@2265,9%@2265,4%@2265,29%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@38C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@41.5C thermal@39.7C Tboard@37C
> RAM 27829/31921MB (lfb 606x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@2265,19%@2265,15%@2265,16%@2265,14%@2265,18%@2265,26%@2265,17%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@39C iwlwifi@39C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@41.5C thermal@39.55C Tboard@37C
> RAM 27859/31921MB (lfb 598x4MB) SWAP 6/15960MB (cached 1MB) CPU [16%@2265,12%@2265,15%@2265,19%@2265,10%@2265,35%@2265,15%@2265,24%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@43C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@42C thermal@39.7C Tboard@37C
> RAM 27894/31921MB (lfb 591x4MB) SWAP 6/15960MB (cached 1MB) CPU [20%@2265,37%@2265,37%@2265,17%@2265,5%@2265,11%@2265,6%@2265,20%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@41C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@42.5C thermal@39.7C Tboard@37C
> RAM 27907/31921MB (lfb 588x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@2265,8%@2265,29%@2265,34%@2265,29%@2265,46%@2265,13%@2265,44%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39.5C iwlwifi@40C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@42C thermal@39.7C Tboard@37C
> RAM 27933/31921MB (lfb 582x4MB) SWAP 6/15960MB (cached 1MB) CPU [16%@2265,8%@2265,39%@2265,8%@2265,39%@2265,25%@2265,13%@2265,8%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@40C Tdiode@41.75C PMIC@100C AUX@38.5C CPU@42C thermal@39.7C Tboard@37C
> RAM 27946/31921MB (lfb 577x4MB) SWAP 6/15960MB (cached 1MB) CPU [37%@2265,18%@2265,12%@2265,36%@2265,14%@2265,14%@2265,20%@2265,17%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@39C Tdiode@41.75C PMIC@100C AUX@38.5C CPU@42C thermal@39.9C Tboard@37C
> RAM 27967/31921MB (lfb 573x4MB) SWAP 6/15960MB (cached 1MB) CPU [9%@2265,27%@2265,22%@2265,9%@2265,23%@2265,11%@2265,10%@2265,23%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@38C Tdiode@41.5C PMIC@100C AUX@39C CPU@41.5C thermal@39.7C Tboard@37C
> RAM 27994/31921MB (lfb 566x4MB) SWAP 6/15960MB (cached 1MB) CPU [9%@2265,3%@2265,14%@2265,24%@2265,6%@2265,2%@2265,22%@2265,48%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@40C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@42C thermal@39.7C Tboard@37C
> RAM 28025/31921MB (lfb 558x4MB) SWAP 6/15960MB (cached 1MB) CPU [12%@2265,18%@2265,27%@2265,11%@2265,13%@2265,13%@2265,28%@2265,11%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@39C Tdiode@41.75C PMIC@100C AUX@38.5C CPU@42C thermal@40.05C Tboard@37C
> RAM 28051/31921MB (lfb 552x4MB) SWAP 6/15960MB (cached 1MB) CPU [16%@2265,9%@2265,7%@2265,4%@2265,9%@2265,35%@2265,38%@2265,25%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@41C Tdiode@41.75C PMIC@100C AUX@38.5C CPU@42C thermal@39.7C Tboard@37C
> RAM 28077/31921MB (lfb 545x4MB) SWAP 6/15960MB (cached 1MB) CPU [17%@2265,58%@2265,28%@2265,12%@2265,28%@2265,29%@2265,64%@2265,18%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@44C Tdiode@41.75C PMIC@100C AUX@39C CPU@43C thermal@39.85C Tboard@37C
> RAM 28101/31921MB (lfb 540x4MB) SWAP 6/15960MB (cached 1MB) CPU [14%@2265,31%@2265,19%@2265,24%@2265,20%@2265,28%@2265,25%@2265,29%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39.5C iwlwifi@40C Tdiode@41.75C PMIC@100C AUX@39C CPU@42.5C thermal@40.15C Tboard@37C
> RAM 28122/31921MB (lfb 533x4MB) SWAP 6/15960MB (cached 1MB) CPU [26%@2265,27%@2265,14%@2265,7%@2265,20%@2265,16%@2265,25%@2265,18%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@39C Tdiode@41.75C PMIC@100C AUX@39C CPU@42C thermal@40.2C Tboard@37C
> RAM 28141/31921MB (lfb 529x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@2265,3%@2265,4%@2265,4%@2265,7%@2265,26%@2265,45%@2265,29%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39C iwlwifi@39C Tdiode@41.75C PMIC@100C AUX@39C CPU@42C thermal@40.05C Tboard@37C
> RAM 28167/31921MB (lfb 523x4MB) SWAP 6/15960MB (cached 1MB) CPU [16%@2265,48%@2265,15%@2265,23%@2265,17%@2265,13%@2265,2%@2265,2%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39C iwlwifi@39C Tdiode@41.75C PMIC@100C AUX@39C CPU@42C thermal@40.2C Tboard@37C
> RAM 28200/31921MB (lfb 515x4MB) SWAP 6/15960MB (cached 1MB) CPU [23%@2265,21%@2265,6%@2265,28%@2265,12%@2265,11%@2265,11%@2265,37%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39C iwlwifi@39C Tdiode@41.75C PMIC@100C AUX@39C CPU@42C thermal@39.9C Tboard@37C
> RAM 28224/31921MB (lfb 509x4MB) SWAP 6/15960MB (cached 1MB) CPU [43%@2265,9%@2265,4%@2265,23%@2265,16%@2265,21%@2265,15%@2265,10%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39C iwlwifi@38C Tdiode@41.75C PMIC@100C AUX@39C CPU@42.5C thermal@39.9C Tboard@37C
> RAM 28246/31921MB (lfb 503x4MB) SWAP 6/15960MB (cached 1MB) CPU [47%@2265,4%@2265,26%@2265,13%@2265,24%@2265,33%@2265,7%@2265,5%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@43C Tdiode@41.75C PMIC@100C AUX@39C CPU@42.5C thermal@40.05C Tboard@37C
> RAM 28266/31921MB (lfb 498x4MB) SWAP 6/15960MB (cached 1MB) CPU [24%@2265,46%@2265,10%@2265,12%@2265,30%@2265,31%@2265,12%@2265,17%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@39C Tdiode@41.75C PMIC@100C AUX@39C CPU@42.5C thermal@40.2C Tboard@37C
> RAM 28294/31921MB (lfb 491x4MB) SWAP 6/15960MB (cached 1MB) CPU [41%@2265,4%@2265,9%@2265,11%@2265,30%@2265,20%@2265,9%@2265,14%@2265] EMC_FREQ 0% GR3D_FREQ 39% AO@39C GPU@39.5C iwlwifi@39C Tdiode@42C PMIC@100C AUX@39C CPU@42.5C thermal@40.2C Tboard@37C
> RAM 28317/31921MB (lfb 485x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@2265,27%@2265,8%@2265,21%@2265,28%@2265,6%@2265,39%@2265,6%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@39C Tdiode@41.75C PMIC@100C AUX@39C CPU@42C thermal@40.05C Tboard@38C
> RAM 28343/31921MB (lfb 478x4MB) SWAP 6/15960MB (cached 1MB) CPU [9%@2265,9%@2265,20%@2265,6%@2265,26%@2265,17%@2265,12%@2265,60%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@39C Tdiode@41.75C PMIC@100C AUX@39C CPU@42.5C thermal@40.2C Tboard@38C
> RAM 28377/31921MB (lfb 470x4MB) SWAP 6/15960MB (cached 1MB) CPU [22%@2265,26%@2265,4%@2265,19%@2265,27%@2265,13%@2265,12%@2265,23%@2265] EMC_FREQ 0% GR3D_FREQ 37% AO@39C GPU@39.5C iwlwifi@39C Tdiode@41.75C PMIC@100C AUX@39C CPU@42.5C thermal@40.05C Tboard@38C
> RAM 28411/31921MB (lfb 461x4MB) SWAP 6/15960MB (cached 1MB) CPU [30%@2265,21%@2265,11%@2265,22%@2265,11%@2265,20%@2265,39%@2265,10%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@39C Tdiode@41.75C PMIC@100C AUX@39C CPU@43C thermal@40.2C Tboard@38C
> RAM 28429/31921MB (lfb 457x4MB) SWAP 6/15960MB (cached 1MB) CPU [21%@2265,27%@2265,26%@2265,22%@2265,25%@2265,16%@2265,33%@2265,46%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@40C Tdiode@41.75C PMIC@100C AUX@39C CPU@42C thermal@40.35C Tboard@38C
> RAM 28455/31921MB (lfb 449x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@2265,41%@2265,37%@2265,18%@2265,27%@2265,7%@2265,5%@2265,3%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@39C Tdiode@41.75C PMIC@100C AUX@39C CPU@42C thermal@40.2C Tboard@38C
> RAM 28490/31921MB (lfb 441x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@2265,20%@2265,44%@2265,23%@2265,27%@2265,4%@2265,7%@2265,4%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@40C Tdiode@42C PMIC@100C AUX@39C CPU@42C thermal@40.2C Tboard@38C
> RAM 28516/31921MB (lfb 435x4MB) SWAP 6/15960MB (cached 1MB) CPU [12%@2265,9%@2265,33%@2265,30%@2265,4%@2265,9%@2265,49%@2265,11%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@41C Tdiode@41.75C PMIC@100C AUX@39C CPU@43C thermal@40.2C Tboard@38C
> RAM 28537/31921MB (lfb 430x4MB) SWAP 6/15960MB (cached 1MB) CPU [18%@2265,6%@2265,16%@2265,39%@2265,29%@2265,5%@2265,18%@2265,5%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39.5C iwlwifi@41C Tdiode@42C PMIC@100C AUX@39C CPU@42.5C thermal@40.2C Tboard@38C
> RAM 28565/31921MB (lfb 423x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@2265,12%@2265,10%@2265,19%@2265,20%@2265,36%@2265,13%@2265,10%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@39C Tdiode@42.25C PMIC@100C AUX@39C CPU@42.5C thermal@40.2C Tboard@38C
> RAM 28578/31921MB (lfb 419x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@1190,9%@1190,19%@1190,4%@1190,18%@1190,11%@1190,6%@1190,18%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@39C Tdiode@42C PMIC@100C AUX@39C CPU@41.5C thermal@40.2C Tboard@38C
> RAM 28579/31921MB (lfb 419x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,3%@1190,1%@1190,0%@1190,0%@1190,2%@1190,2%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@39C Tdiode@42C PMIC@100C AUX@38.5C CPU@41C thermal@39.7C Tboard@38C
> RAM 28582/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@1190,6%@1190,6%@1190,4%@1190,3%@1190,6%@1190,10%@1190,7%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@39C Tdiode@41.75C PMIC@100C AUX@38.5C CPU@41C thermal@39.7C Tboard@38C
> RAM 28582/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@1190,1%@1190,1%@1190,1%@1190,0%@1190,3%@1190,6%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@40C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@41C thermal@39.4C Tboard@38C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,6%@1190,5%@1190,6%@1190,0%@1190,2%@1190,6%@1190,5%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@40C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@41C thermal@39.4C Tboard@38C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@1190,3%@1190,4%@1190,3%@1190,1%@1190,2%@1190,4%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@39C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@40.5C thermal@39.25C Tboard@38C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,1%@1190,4%@1190,5%@1190,0%@1190,3%@1190,6%@1190,10%@1190] EMC_FREQ 0% GR3D_FREQ 26% AO@38C GPU@38.5C iwlwifi@41C Tdiode@41.25C PMIC@100C AUX@38.5C CPU@41C thermal@39.4C Tboard@38C
> RAM 28579/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [18%@1190,1%@1190,5%@1190,2%@1190,4%@1190,5%@1190,3%@1190,4%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@39C Tdiode@41.25C PMIC@100C AUX@38C CPU@40.5C thermal@38.9C Tboard@38C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@1190,3%@1190,4%@1190,2%@1190,0%@1190,8%@1190,2%@1190,6%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@39C Tdiode@41.5C PMIC@100C AUX@38C CPU@40.5C thermal@38.9C Tboard@38C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,2%@1190,2%@1190,1%@1190,0%@1190,7%@1190,6%@1190,4%@1190] EMC_FREQ 0% GR3D_FREQ 3% AO@38C GPU@38.5C iwlwifi@40C Tdiode@41.25C PMIC@100C AUX@38C CPU@40.5C thermal@38.9C Tboard@38C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@1190,5%@1190,4%@1190,2%@1190,0%@1190,5%@1190,5%@1190,7%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@42C Tdiode@41.25C PMIC@100C AUX@38C CPU@40.5C thermal@38.75C Tboard@38C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@2265,6%@2265,3%@2265,3%@2265,14%@2265,6%@2265,10%@2265,3%@2265] EMC_FREQ 0% GR3D_FREQ 6% AO@38C GPU@38.5C iwlwifi@40C Tdiode@41.25C PMIC@100C AUX@38C CPU@41C thermal@38.9C Tboard@38C
> RAM 28581/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,2%@1190,3%@1190,3%@1190,0%@1190,6%@1190,3%@1190,4%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@39C Tdiode@41C PMIC@100C AUX@38C CPU@40C thermal@38.75C Tboard@38C
> RAM 28581/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@1344,2%@1344,1%@1344,2%@1344,0%@1344,7%@1344,4%@1344,3%@1344] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@39C Tdiode@41.25C PMIC@100C AUX@38C CPU@40C thermal@38.75C Tboard@37C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@1190,3%@1190,2%@1190,1%@1190,0%@1190,8%@1190,2%@1190,6%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@39C Tdiode@41C PMIC@100C AUX@37.5C CPU@40C thermal@38.55C Tboard@37C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@1190,3%@1190,2%@1190,1%@1190,0%@1190,6%@1190,4%@1190,4%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38C iwlwifi@39C Tdiode@41C PMIC@100C AUX@38C CPU@40C thermal@38.75C Tboard@37C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,2%@1190,2%@1190,2%@1190,1%@1190,5%@1190,3%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@39C Tdiode@40.75C PMIC@100C AUX@38C CPU@40C thermal@38.55C Tboard@37C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,1%@1190,5%@1190,4%@1190,0%@1190,1%@1190,4%@1190,4%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38C iwlwifi@39C Tdiode@40.75C PMIC@100C AUX@37.5C CPU@40C thermal@38.55C Tboard@37C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,3%@1190,4%@1190,2%@1190,3%@1190,3%@1190,5%@1190,5%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38C iwlwifi@39C Tdiode@40.75C PMIC@100C AUX@37.5C CPU@40C thermal@38.4C Tboard@37C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [3%@1190,0%@1190,1%@1190,1%@1190,0%@1190,0%@1190,7%@1190,3%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38C iwlwifi@39C Tdiode@40.75C PMIC@100C AUX@37.5C CPU@40C thermal@38.4C Tboard@37C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@2265,4%@2265,5%@2265,4%@2265,0%@2265,1%@2265,6%@2265,4%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38C iwlwifi@40C Tdiode@40.75C PMIC@100C AUX@37.5C CPU@40.5C thermal@38.55C Tboard@37C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@1190,16%@1190,5%@1190,5%@1190,5%@1190,6%@1190,3%@1190,3%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38C iwlwifi@40C Tdiode@40.75C PMIC@100C AUX@37.5C CPU@40C thermal@38.55C Tboard@37C
> RAM 28581/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@1190,1%@1190,5%@1190,5%@1190,1%@1190,8%@1190,2%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38C iwlwifi@39C Tdiode@40.75C PMIC@100C AUX@37.5C CPU@40C thermal@38.4C Tboard@37C
> RAM 28581/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,2%@1190,4%@1190,2%@1190,3%@1190,8%@1190,2%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38C iwlwifi@39C Tdiode@40.75C PMIC@100C AUX@37.5C CPU@40C thermal@38.4C Tboard@37C
> RAM 28581/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,5%@1190,3%@1190,3%@1190,0%@1190,7%@1190,6%@1190,3%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38C iwlwifi@39C Tdiode@40.75C PMIC@100C AUX@37.5C CPU@40C thermal@38.4C Tboard@37C
> RAM 28581/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,1%@1190,4%@1190,4%@1190,0%@1190,8%@1190,3%@1190,1%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38C iwlwifi@39C Tdiode@40.75C PMIC@100C AUX@37.5C CPU@40C thermal@38.4C Tboard@37C
> RAM 28580/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@1190,4%@1190,4%@1190,3%@1190,3%@1190,2%@1190,4%@1190,3%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38C iwlwifi@39C Tdiode@40.5C PMIC@100C AUX@37.5C CPU@40C thermal@38.4C Tboard@37C
> RAM 28579/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [14%@2265,15%@2265,8%@2265,11%@2265,7%@2265,6%@2265,15%@2265,15%@2265] EMC_FREQ 0% GR3D_FREQ 9% AO@37.5C GPU@38C iwlwifi@40C Tdiode@40.75C PMIC@100C AUX@37.5C CPU@40.5C thermal@38.4C Tboard@37C
> RAM 28585/31921MB (lfb 418x4MB) SWAP 6/15960MB (cached 1MB) CPU [12%@1190,14%@1190,15%@1190,13%@1190,15%@1190,10%@1190,19%@1190,10%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38C iwlwifi@41C Tdiode@40.75C PMIC@100C AUX@37.5C CPU@40C thermal@38.4C Tboard@37C
> RAM 28587/31921MB (lfb 415x4MB) SWAP 6/15960MB (cached 1MB) CPU [21%@1190,13%@1190,15%@1190,13%@1190,10%@1190,8%@1190,18%@1190,15%@1190] EMC_FREQ 0% GR3D_FREQ 45% AO@38C GPU@38.5C iwlwifi@40C Tdiode@40.5C PMIC@100C AUX@37.5C CPU@41C thermal@38.55C Tboard@37C
> RAM 28595/31921MB (lfb 410x4MB) SWAP 6/15960MB (cached 1MB) CPU [13%@1190,12%@1190,16%@1190,31%@1190,13%@1190,15%@1190,18%@1190,21%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@37.5C GPU@38.5C iwlwifi@39C Tdiode@40.75C PMIC@100C AUX@38C CPU@40C thermal@38.55C Tboard@37C
> RAM 28610/31921MB (lfb 410x4MB) SWAP 6/15960MB (cached 1MB) CPU [46%@2265,14%@2265,32%@2265,19%@2265,17%@2265,20%@2265,25%@2265,24%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@41C Tdiode@40.75C PMIC@100C AUX@38C CPU@42C thermal@38.9C Tboard@37C
> RAM 28626/31921MB (lfb 409x4MB) SWAP 6/15960MB (cached 1MB) CPU [24%@2265,28%@2265,15%@2265,26%@2265,18%@2265,17%@2265,31%@2265,16%@2265] EMC_FREQ 0% GR3D_FREQ 19% AO@38C GPU@38.5C iwlwifi@41C Tdiode@41.25C PMIC@100C AUX@38C CPU@41.5C thermal@39.35C Tboard@37C
> RAM 28634/31921MB (lfb 409x4MB) SWAP 6/15960MB (cached 1MB) CPU [23%@2265,25%@2265,23%@2265,24%@2265,17%@2265,17%@2265,32%@2265,18%@2265] EMC_FREQ 0% GR3D_FREQ 3% AO@38C GPU@38.5C iwlwifi@46C Tdiode@41.25C PMIC@100C AUX@38C CPU@41.5C thermal@39.2C Tboard@37C
> RAM 28637/31921MB (lfb 409x4MB) SWAP 6/15960MB (cached 1MB) CPU [16%@1190,13%@1190,11%@1190,21%@1190,12%@1190,18%@1190,18%@1190,15%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@43C Tdiode@41.25C PMIC@100C AUX@38C CPU@40.5C thermal@39.2C Tboard@37C
> RAM 28635/31921MB (lfb 409x4MB) SWAP 6/15960MB (cached 1MB) CPU [7%@1190,3%@1190,4%@1190,3%@1190,2%@1190,16%@1190,7%@1190,5%@1190] EMC_FREQ 0% GR3D_FREQ 6% AO@38C GPU@38.5C iwlwifi@40C Tdiode@41C PMIC@100C AUX@38C CPU@40.5C thermal@38.9C Tboard@37C
> RAM 28642/31921MB (lfb 408x4MB) SWAP 6/15960MB (cached 1MB) CPU [22%@1190,27%@1190,24%@1190,21%@1190,20%@1190,32%@1190,25%@1190,22%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38C GPU@38.5C iwlwifi@42C Tdiode@41.25C PMIC@100C AUX@38C CPU@40.5C thermal@38.9C Tboard@37C
> RAM 28692/31921MB (lfb 396x4MB) SWAP 6/15960MB (cached 1MB) CPU [29%@2265,50%@2265,18%@2265,16%@2265,26%@2265,21%@2265,54%@2265,48%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@38.5C iwlwifi@44C Tdiode@41.25C PMIC@100C AUX@38.5C CPU@42.5C thermal@39.5C Tboard@37C
> RAM 28706/31921MB (lfb 392x4MB) SWAP 6/15960MB (cached 1MB) CPU [30%@2265,25%@2265,26%@2265,45%@2265,33%@2265,25%@2265,30%@2265,17%@2265] EMC_FREQ 0% GR3D_FREQ 12% AO@38C GPU@39C iwlwifi@44C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@42C thermal@39.7C Tboard@37C
> RAM 28705/31921MB (lfb 392x4MB) SWAP 6/15960MB (cached 1MB) CPU [18%@1190,19%@1190,16%@1190,14%@1190,15%@1190,19%@1190,23%@1190,17%@1190] EMC_FREQ 0% GR3D_FREQ 6% AO@38.5C GPU@38.5C iwlwifi@41C Tdiode@41.25C PMIC@100C AUX@38.5C CPU@40.5C thermal@39.7C Tboard@37C
> RAM 27064/31921MB (lfb 399x4MB) SWAP 6/15960MB (cached 1MB) CPU [23%@2265,20%@2265,28%@2265,63%@2265,45%@2265,26%@2265,53%@2265,22%@2265] EMC_FREQ 0% GR3D_FREQ 9% AO@38.5C GPU@39C iwlwifi@47C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@42C thermal@40C Tboard@38C
> RAM 26996/31921MB (lfb 465x4MB) SWAP 6/15960MB (cached 1MB) CPU [44%@2265,28%@2265,34%@2265,39%@2265,24%@2265,29%@2265,26%@2265,13%@2265] EMC_FREQ 0% GR3D_FREQ 9% AO@38.5C GPU@39C iwlwifi@41C Tdiode@41.75C PMIC@100C AUX@39C CPU@42C thermal@40C Tboard@38C
> RAM 26987/31921MB (lfb 465x4MB) SWAP 6/15960MB (cached 1MB) CPU [61%@2265,21%@2265,32%@2265,31%@2265,25%@2265,39%@2265,53%@2265,37%@2265] EMC_FREQ 0% GR3D_FREQ 3% AO@38.5C GPU@39.5C iwlwifi@44C Tdiode@41.5C PMIC@100C AUX@39C CPU@43.5C thermal@39.85C Tboard@38C
> RAM 27009/31921MB (lfb 465x4MB) SWAP 6/15960MB (cached 1MB) CPU [23%@2035,29%@2035,40%@2035,25%@2035,53%@2035,40%@2035,34%@2035,30%@2035] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39.5C iwlwifi@46C Tdiode@42C PMIC@100C AUX@39C CPU@43C thermal@40.05C Tboard@38C
> RAM 27025/31921MB (lfb 465x4MB) SWAP 6/15960MB (cached 1MB) CPU [37%@2265,34%@2265,19%@2265,17%@2265,41%@2265,35%@2265,38%@2265,38%@2265] EMC_FREQ 0% GR3D_FREQ 18% AO@39C GPU@39.5C iwlwifi@46C Tdiode@42C PMIC@100C AUX@39C CPU@43C thermal@40.35C Tboard@38C
> RAM 27032/31921MB (lfb 465x4MB) SWAP 6/15960MB (cached 1MB) CPU [35%@1651,31%@1651,50%@1651,29%@1651,27%@1651,27%@1651,58%@1651,31%@1651] EMC_FREQ 0% GR3D_FREQ 15% AO@39C GPU@39.5C iwlwifi@49C Tdiode@42C PMIC@100C AUX@39.5C CPU@43C thermal@40.7C Tboard@38C
> RAM 27048/31921MB (lfb 465x4MB) SWAP 6/15960MB (cached 1MB) CPU [22%@2265,40%@2265,28%@2265,29%@2265,39%@2265,26%@2265,22%@2265,29%@2265] EMC_FREQ 0% GR3D_FREQ 15% AO@39C GPU@39.5C iwlwifi@51C Tdiode@42C PMIC@100C AUX@39.5C CPU@43.5C thermal@40.4C Tboard@38C
> RAM 27063/31921MB (lfb 464x4MB) SWAP 6/15960MB (cached 1MB) CPU [24%@2265,36%@2265,22%@2265,42%@2265,29%@2265,25%@2265,41%@2265,18%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@40C iwlwifi@48C Tdiode@42.25C PMIC@100C AUX@39C CPU@42.5C thermal@41C Tboard@38C
> RAM 27056/31921MB (lfb 464x4MB) SWAP 6/15960MB (cached 1MB) CPU [9%@1190,2%@1190,9%@1190,10%@1190,14%@1190,6%@1190,6%@1190,6%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@41.5C iwlwifi@42C Tdiode@42C PMIC@100C AUX@39C CPU@41.5C thermal@40.55C Tboard@38C
> RAM 27056/31921MB (lfb 464x4MB) SWAP 6/15960MB (cached 1MB) CPU [18%@2265,11%@2265,7%@2265,7%@2265,2%@2265,4%@2265,4%@2265,5%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@43C Tdiode@42C PMIC@100C AUX@39C CPU@42C thermal@39.9C Tboard@38C
> RAM 27054/31921MB (lfb 464x4MB) SWAP 6/15960MB (cached 1MB) CPU [14%@1190,5%@1190,3%@1190,6%@1190,2%@1190,3%@1190,3%@1190,3%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@43C Tdiode@42C PMIC@100C AUX@39C CPU@41C thermal@39.9C Tboard@38C
> RAM 27051/31921MB (lfb 464x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@1190,6%@1190,5%@1190,1%@1190,1%@1190,0%@1190,5%@1190,5%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@41C iwlwifi@41C Tdiode@42C PMIC@100C AUX@38.5C CPU@41C thermal@39.55C Tboard@38C
> RAM 27027/31921MB (lfb 464x4MB) SWAP 6/15960MB (cached 1MB) CPU [14%@1190,5%@1190,3%@1190,9%@1190,5%@1190,6%@1190,5%@1190,7%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@41C iwlwifi@41C Tdiode@42C PMIC@100C AUX@38.5C CPU@41C thermal@39.55C Tboard@38C
> RAM 27028/31921MB (lfb 464x4MB) SWAP 6/15960MB (cached 1MB) CPU [11%@1190,4%@1190,0%@1190,1%@1190,1%@1190,0%@1190,5%@1190,6%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@41C iwlwifi@41C Tdiode@41.75C PMIC@100C AUX@38.5C CPU@41C thermal@40.2C Tboard@38C
> RAM 27028/31921MB (lfb 464x4MB) SWAP 6/15960MB (cached 1MB) CPU [8%@1190,6%@1190,10%@1190,8%@1190,2%@1190,3%@1190,12%@1190,9%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39C iwlwifi@41C Tdiode@41.75C PMIC@100C AUX@38.5C CPU@41C thermal@39.4C Tboard@38C
> RAM 27027/31921MB (lfb 464x4MB) SWAP 6/15960MB (cached 1MB) CPU [12%@1190,6%@1190,14%@1190,8%@1190,4%@1190,5%@1190,7%@1190,6%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@46C Tdiode@41.75C PMIC@100C AUX@38.5C CPU@41C thermal@39.55C Tboard@38C
> RAM 27023/31921MB (lfb 464x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1574,3%@1574,17%@1574,5%@1574,7%@1574,7%@1574,13%@1574,6%@1574] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@41C iwlwifi@46C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@41C thermal@39.55C Tboard@38C
> RAM 25401/31921MB (lfb 646x4MB) SWAP 6/15960MB (cached 1MB) CPU [18%@2265,16%@2265,42%@2265,34%@2265,25%@2265,14%@2265,19%@2265,22%@2265] EMC_FREQ 0% GR3D_FREQ 8% AO@38.5C GPU@39C iwlwifi@41C Tdiode@41.75C PMIC@100C AUX@38.5C CPU@42C thermal@39.55C Tboard@38C
> RAM 8240/31921MB (lfb 4923x4MB) SWAP 6/15960MB (cached 1MB) CPU [42%@2265,34%@2265,45%@2265,41%@2265,16%@2265,16%@2265,18%@2265,14%@2265] EMC_FREQ 0% GR3D_FREQ 40% AO@39C GPU@39.5C iwlwifi@41C Tdiode@41.75C PMIC@100C AUX@39C CPU@43.5C thermal@39.7C Tboard@38C
> RAM 8238/31921MB (lfb 4923x4MB) SWAP 6/15960MB (cached 1MB) CPU [21%@1497,24%@1497,11%@1497,13%@1497,16%@1497,19%@1497,14%@1497,17%@1497] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39C iwlwifi@41C Tdiode@41.75C PMIC@100C AUX@39C CPU@41.5C thermal@40.2C Tboard@38C
> RAM 8229/31921MB (lfb 4924x4MB) SWAP 6/15960MB (cached 1MB) CPU [21%@2265,11%@2265,10%@2265,17%@2265,13%@2265,8%@2265,9%@2265,7%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39.5C iwlwifi@40C Tdiode@41.75C PMIC@100C AUX@39C CPU@41.5C thermal@39.75C Tboard@38C
> RAM 8231/31921MB (lfb 4924x4MB) SWAP 6/15960MB (cached 1MB) CPU [16%@2035,22%@2035,21%@2035,19%@2035,14%@1881,16%@1881,9%@1958,16%@1958] EMC_FREQ 0% GR3D_FREQ 46% AO@39C GPU@39.5C iwlwifi@40C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@42.5C thermal@39.4C Tboard@38C
> RAM 8232/31921MB (lfb 4924x4MB) SWAP 6/15960MB (cached 1MB) CPU [24%@1190,18%@1190,16%@1190,19%@1190,20%@1190,27%@1190,24%@1190,21%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39.5C iwlwifi@40C Tdiode@41.75C PMIC@100C AUX@38.5C CPU@41.5C thermal@40C Tboard@38C
> RAM 8232/31921MB (lfb 4924x4MB) SWAP 6/15960MB (cached 1MB) CPU [6%@1190,6%@1190,5%@1190,2%@1190,2%@1190,2%@1190,1%@1190,6%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@41C Tdiode@41.75C PMIC@100C AUX@38.5C CPU@41C thermal@39.4C Tboard@38C
> RAM 8231/31921MB (lfb 4924x4MB) SWAP 6/15960MB (cached 1MB) CPU [2%@2265,4%@2265,9%@2265,1%@2265,5%@2265,2%@2265,1%@2265,2%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39C iwlwifi@40C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@41.5C thermal@39.4C Tboard@38C
> RAM 8234/31921MB (lfb 4926x4MB) SWAP 6/15960MB (cached 1MB) CPU [20%@1190,13%@1190,9%@1190,4%@1190,8%@1190,10%@1190,9%@1190,7%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39.5C iwlwifi@40C Tdiode@41.75C PMIC@100C AUX@38.5C CPU@41C thermal@39.4C Tboard@38C
> RAM 8231/31921MB (lfb 4927x4MB) SWAP 6/15960MB (cached 1MB) CPU [9%@1420,6%@1420,6%@1420,4%@1420,2%@1420,4%@1420,5%@1420,6%@1420] EMC_FREQ 0% GR3D_FREQ 0% AO@39C GPU@39C iwlwifi@43C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@41C thermal@39.4C Tboard@38C
> RAM 8230/31921MB (lfb 4927x4MB) SWAP 6/15960MB (cached 1MB) CPU [5%@1190,1%@1190,2%@1190,3%@1190,1%@1190,8%@1190,0%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@41C Tdiode@41.75C PMIC@100C AUX@38.5C CPU@41C thermal@39.4C Tboard@38C
> RAM 8230/31921MB (lfb 4927x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@1190,2%@1190,2%@1190,1%@1190,7%@1190,7%@1190,1%@1190,3%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@40C Tdiode@41.5C PMIC@100C AUX@38.5C CPU@41C thermal@39.25C Tboard@38C
> RAM 8230/31921MB (lfb 4927x4MB) SWAP 6/15960MB (cached 1MB) CPU [4%@1190,3%@1190,1%@1190,2%@1190,7%@1190,1%@1190,3%@1190,3%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@38.5C GPU@39C iwlwifi@39C Tdiode@41.25C PMIC@100C AUX@38.5C CPU@41C thermal@39.25C Tboard@38C
Thank you for reaching out!
The memory looks good from the above profiling data.
Another common cause for segmentation fault is illegal memory access.
Have you tried the sample on other platform before? Ex. an x86 host?
If not, could you give it a try?
It helps if we can first verify this issue is Jetson only or not.
I have observed a similar issue when running training and inference on a Xavier AGX using pytorch/mmdetection. Issue never happens on PC and I have never seen it on Jetson TX2, where I was running a similar version of the script
On Xavier AGX, I can load the model once without problem, then after restarting the application I get a segfault immediately after loading the checkpoint pth file. At this point, I can barely get the model running again. If I switch to CPU instead of cuda:0, I can load the model and run inference (slowly).
I am using Pytorch 1.8.0 installed from wheel, latest mmdetection, latest mmcv, and jetpack 4.5.1
Do you have any advice on how to find out what causes this segmentation fault or how to proceed?
Do you use the PyTorch 1.8.0 package from the below comment:
If yes, could you share the detailed steps to reproduce this error?
We want to check it deeper in our environment.
More, could you run dmesg to see if any suspicious error log right after the failure?
Thanks for your suggestion. Yes I am using PyTorch 1.8.0 and also 1.9.0 from the link you sent.
I tried monitoring both dmesg and memory usage but did not notice anything out of the ordinary.
After doing slightly more tests, the issue seem to be related to the power mode configuration. At least the problem does not occur when I run both sudo nvpmodel -m 0 AND jetson_clocks.sh. Coincidence? Not sure, but at least it’s working now.
