HI ,all:
the machine will reboot, the kernel log as follow:
Jun 1 09:45:23 : [ 34.440685] imx185: module is already loaded
Jun 1 09:45:23 : [ 34.456752] igb 0001:01:00.3 enP1p1s0f3: renamed from eth4
Jun 1 09:45:23 : [ 34.473613] ixgbe 0005:01:00.0 enP5p1s0f0: renamed from eth5
Jun 1 09:45:23 : [ 34.488648] Could not create tracefs 'imx185_s_stream' directory
Jun 1 09:45:23 : [ 34.488706] imx185: module is already loaded
Jun 1 09:45:23 : [ 34.496825] ixgbe 0005:01:00.1 enP5p1s0f1: renamed from eth6
Jun 1 09:45:23 : [ 34.528800] Could not create tracefs 'imx185_s_stream' directory
Jun 1 09:45:23 : [ 34.528861] imx185: module is already loaded
Jun 1 09:45:23 : [ 34.529233] can_dev: exports duplicate symbol alloc_can_err_skb (owned by kernel)
Jun 1 09:45:23 : [ 34.590813] usbcore: registered new interface driver option
Jun 1 09:45:23 : [ 34.590850] usbserial: USB Serial support registered for GSM modem (1-port)
Jun 1 09:45:23 : [ 34.591588] option 1-4:1.0: GSM modem (1-port) converter detected
Jun 1 09:45:23 : [ 34.592492] usb 1-4: GSM modem (1-port) converter now attached to ttyUSB0
Jun 1 09:45:23 : [ 34.593148] option 1-4:1.1: GSM modem (1-port) converter detected
Jun 1 09:45:23 : [ 34.593374] usb 1-4: GSM modem (1-port) converter now attached to ttyUSB1
Jun 1 09:45:23 : [ 34.593450] option 1-4:1.2: GSM modem (1-port) converter detected
Jun 1 09:45:23 : [ 34.595024] usb 1-4: GSM modem (1-port) converter now attached to ttyUSB2
Jun 1 09:45:23 : [ 34.596928] option 1-4:1.3: GSM modem (1-port) converter detected
Jun 1 09:45:23 : [ 34.597139] usb 1-4: GSM modem (1-port) converter now attached to ttyUSB3
Jun 1 09:45:23 : [ 34.660368] FAN rising trip_level:1 cur_temp:52750 trip_temps[2]:63000
Jun 1 09:45:23 : [ 34.741155] EXT4-fs (nvme0n1): mounted filesystem with ordered data mode. Opts: (null)
Jun 1 09:45:23 : [ 35.520929] using random self ethernet address
Jun 1 09:45:23 : [ 35.520962] using random host ethernet address
Jun 1 09:45:23 : [ 35.734721] random: crng init done
Jun 1 09:45:23 : [ 35.734764] random: 7 urandom warning(s) missed due to ratelimiting
Jun 1 09:45:23 : [ 36.062935] Mass Storage Function, version: 2009/09/11
Jun 1 09:45:23 : [ 36.062947] LUN: removable file: (no medium)
Jun 1 09:45:23 : [ 36.068871] using random self ethernet address
Jun 1 09:45:23 : [ 36.068905] using random host ethernet address
Jun 1 09:45:23 : [ 36.178781] rndis0: HOST MAC 36:7b:30:95:a4:10
Jun 1 09:45:23 : [ 36.179109] rndis0: MAC 36:7b:30:95:a4:11
Jun 1 09:45:23 : [ 36.179652] usb0: HOST MAC 36:7b:30:95:a4:12
Jun 1 09:45:23 : [ 36.179686] usb0: MAC 36:7b:30:95:a4:13
Jun 1 09:45:23 : [ 36.179704] tegra-xudc-new 3550000.xudc: exiting ELPG
Jun 1 09:45:23 : [ 36.180206] tegra-xudc-new 3550000.xudc: exiting ELPG done
Jun 1 09:45:23 : [ 36.180219] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
Jun 1 09:45:23 : [ 36.180497] tegra-xudc-new 3550000.xudc: entering ELPG
Jun 1 09:45:23 : [ 36.180697] tegra-xudc-new 3550000.xudc: entering ELPG done
Jun 1 09:45:23 : [ 36.180713] tegra-xudc-new 3550000.xudc: exiting ELPG
Jun 1 09:45:23 : [ 36.181160] tegra-xudc-new 3550000.xudc: exiting ELPG done
Jun 1 09:45:23 : [ 36.181180] tegra-xudc-new 3550000.xudc: entering ELPG
Jun 1 09:45:23 : [ 36.181372] tegra-xudc-new 3550000.xudc: entering ELPG done
Jun 1 09:45:23 : [ 36.185317] l4tbr0: port 1(rndis0) entered blocking state
Jun 1 09:45:23 : [ 36.185328] l4tbr0: port 1(rndis0) entered disabled state
Jun 1 09:45:23 : [ 36.185493] device rndis0 entered promiscuous mode
Jun 1 09:45:23 : [ 36.193892] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
Jun 1 09:45:23 : [ 36.198235] l4tbr0: port 2(usb0) entered blocking state
Jun 1 09:45:23 : [ 36.198245] l4tbr0: port 2(usb0) entered disabled state
Jun 1 09:45:23 : [ 36.200267] device usb0 entered promiscuous mode
Jun 1 09:45:23 : [ 36.205074] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
Jun 1 09:45:23 : [ 36.207678] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
Jun 1 09:45:23 : [ 36.345570] IPv6: ADDRCONF(NETDEV_UP): enP1p1s0f0: link is not ready
Jun 1 09:45:23 : [ 36.465099] IPv6: ADDRCONF(NETDEV_UP): enP1p1s0f0: link is not ready
Jun 1 09:45:23 : [ 36.481301] IPv6: ADDRCONF(NETDEV_UP): enP1p1s0f1: link is not ready
Jun 1 09:45:24 : [ 36.603890] IPv6: ADDRCONF(NETDEV_UP): enP1p1s0f1: link is not ready
Jun 1 09:45:24 : [ 36.614505] IPv6: ADDRCONF(NETDEV_UP): enP1p1s0f2: link is not ready
Jun 1 09:45:24 : [ 36.737923] IPv6: ADDRCONF(NETDEV_UP): enP1p1s0f2: link is not ready
Jun 1 09:45:24 : [ 36.747578] IPv6: ADDRCONF(NETDEV_UP): enP1p1s0f3: link is not ready
Jun 1 09:45:24 : [ 36.873914] IPv6: ADDRCONF(NETDEV_UP): enP1p1s0f3: link is not ready
Jun 1 09:45:24 : [ 36.889761] IPv6: ADDRCONF(NETDEV_UP): enP5p1s0f0: link is not ready
Jun 1 09:45:24 : [ 36.900791] zram: Added device: zram0
Jun 1 09:45:24 : [ 36.901519] zram: Added device: zram1
Jun 1 09:45:24 : [ 36.901964] zram: Added device: zram2
Jun 1 09:45:24 : [ 36.902454] zram: Added device: zram3
Jun 1 09:45:24 : [ 36.903158] zram: Added device: zram4
Jun 1 09:45:24 : [ 36.903529] zram: Added device: zram5
Jun 1 09:45:24 : [ 36.903963] zram: Added device: zram6
Jun 1 09:45:24 : [ 36.904585] zram: Added device: zram7
Jun 1 09:45:24 : [ 36.922699] zram0: detected capacity change from 0 to 1036939264
Jun 1 09:45:24 : [ 36.931086] ixgbe 0005:01:00.0: registered PHC device on enP5p1s0f0
Jun 1 09:45:24 : [ 36.951335] Adding 1012632k swap on /dev/zram0. Priority:5 extents:1 across:1012632k SS
Jun 1 09:45:24 : [ 36.953956] zram1: detected capacity change from 0 to 1036939264
Jun 1 09:45:24 : [ 36.964603] Adding 1012632k swap on /dev/zram1. Priority:5 extents:1 across:1012632k SS
Jun 1 09:45:24 : [ 36.967531] zram2: detected capacity change from 0 to 1036939264
Jun 1 09:45:24 : [ 36.977560] Adding 1012632k swap on /dev/zram2. Priority:5 extents:1 across:1012632k SS
Jun 1 09:45:24 : [ 36.979881] zram3: detected capacity change from 0 to 1036939264
Jun 1 09:45:24 : [ 36.991666] Adding 1012632k swap on /dev/zram3. Priority:5 extents:1 across:1012632k SS
Jun 1 09:45:24 : [ 36.995623] zram4: detected capacity change from 0 to 1036939264
Jun 1 09:45:24 : [ 37.006183] Adding 1012632k swap on /dev/zram4. Priority:5 extents:1 across:1012632k SS
Jun 1 09:45:24 : [ 37.009003] zram5: detected capacity change from 0 to 1036939264
Jun 1 09:45:24 : [ 37.019000] Adding 1012632k swap on /dev/zram5. Priority:5 extents:1 across:1012632k SS
Jun 1 09:45:24 : [ 37.021736] zram6: detected capacity change from 0 to 1036939264
Jun 1 09:45:24 : [ 37.032423] Adding 1012632k swap on /dev/zram6. Priority:5 extents:1 across:1012632k SS
Jun 1 09:45:24 : [ 37.034849] zram7: detected capacity change from 0 to 1036939264
Jun 1 09:45:24 : [ 37.038288] IPv6: ADDRCONF(NETDEV_UP): enP5p1s0f0: link is not ready
Jun 1 09:45:24 : [ 37.045178] Adding 1012632k swap on /dev/zram7. Priority:5 extents:1 across:1012632k SS
Jun 1 09:45:24 : [ 37.054328] IPv6: ADDRCONF(NETDEV_UP): enP5p1s0f1: link is not ready
Jun 1 09:45:24 : [ 37.098466] ixgbe 0005:01:00.1: registered PHC device on enP5p1s0f1
Jun 1 09:45:24 : [ 37.100905] ixgbe 0005:01:00.0 enP5p1s0f0: detected SFP+: 5
Jun 1 09:45:24 : [ 37.205975] IPv6: ADDRCONF(NETDEV_UP): enP5p1s0f1: link is not ready
Jun 1 09:45:24 : [ 37.218765] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Jun 1 09:45:24 : [ 37.305095] gpio tegra-gpio wake20 for gpio=52(G:4)
Jun 1 09:45:24 : [ 37.312328] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Jun 1 09:45:25 : [ 37.757290] tegradc 15200000.nvdisplay: blank - powerdown
Jun 1 09:45:27 : [ 40.497189] igb 0001:01:00.3 enP1p1s0f3: igb: enP1p1s0f3 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
Jun 1 09:45:27 : [ 40.499342] IPv6: ADDRCONF(NETDEV_CHANGE): enP1p1s0f3: link becomes ready
Jun 1 09:45:31 : [ 43.616352] FAN rising trip_level:1 cur_temp:51550 trip_temps[2]:63000
Jun 1 10:10:17 : [ 1530.636067] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
Jun 1 10:29:23 : [ 2676.506319] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
Jun 1 10:46:40 : [ 3712.874901] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
Jun 1 20:40:05 : [39316.422501] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
Jun 1 20:44:00 : [39551.702191] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
Jun 2 15:43:38 : [107926.233534] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
Jun 2 16:05:38 : [109246.008100] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
Jun 2 16:12:33 : [109660.862089] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
Jun 2 16:17:15 : [109942.363415] FAN rising trip_level:2 cur_temp:63200 trip_temps[3]:72000
Jun 2 16:20:42 : [110150.109984] nvgpu: 17000000.gv11b gk20a_fifo_tsg_unbind_channel_verify_status:2200 [ERR] Channel 504 to be removed from TSG 4 has NEXT set!
Jun 2 16:20:42 : [110150.110013] nvgpu: 17000000.gv11b gk20a_tsg_unbind_channel:164 [ERR] Channel 504 unbind failed, tearing down TSG 4
Jun 2 16:20:42 : [110150.110776] nvgpu: 17000000.gv11b gk20a_fifo_tsg_unbind_channel_verify_status:2200 [ERR] Channel 507 to be removed from TSG 3 has NEXT set!
Jun 2 16:20:42 : [110150.110806] nvgpu: 17000000.gv11b gk20a_tsg_unbind_channel:164 [ERR] Channel 507 unbind failed, tearing down TSG 3
Jun 2 16:20:51 : [110158.512264] FAN cooling trip_level:1 cur_temp:54950 trip_temps[2]:63000
Jun 2 16:23:02 : [110289.268710] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
Jun 2 16:23:03 : [110291.077682] ai_ctrl: page allocation failure: order:10, mode:0x240c0c0(GFP_KERNEL|__GFP_COMP|__GFP_ZERO)
Jun 2 16:23:03 : [110291.077760] CPU: 0 PID: 16745 Comm: ai_ctrl Not tainted 4.9.140-tegra #108
Jun 2 16:23:03 : [110291.077763] Hardware name: Jetson-AGX (DT)
Jun 2 16:23:03 : [110291.077767] Call trace:
Jun 2 16:23:03 : [110291.077785] [<ffffff800808bdb8>] dump_backtrace+0x0/0x198
Jun 2 16:23:03 : [110291.077798] [<ffffff800808c37c>] show_stack+0x24/0x30
Jun 2 16:23:03 : [110291.077809] [<ffffff800845d820>] dump_stack+0x98/0xc0
Jun 2 16:23:03 : [110291.077818] [<ffffff80081cf49c>] warn_alloc+0x104/0x130
Jun 2 16:23:03 : [110291.077828] [<ffffff80081cf9bc>] __alloc_pages_nodemask+0x474/0xd38
Jun 2 16:23:03 : [110291.077836] [<ffffff80081f3f44>] kmalloc_order+0x3c/0x78
Jun 2 16:23:03 : [110291.077851] [<ffffff80081f3fbc>] kmalloc_order_trace+0x3c/0x138
Jun 2 16:23:03 : [110291.077860] [<ffffff8008233564>] __kmalloc+0x2f4/0x360
Jun 2 16:23:03 : [110291.077872] [<ffffff8008579080>] nvdla_queue_alloc+0x208/0x340
Jun 2 16:23:03 : [110291.077880] [<ffffff8008575190>] nvdla_open+0xc0/0x1c8
Jun 2 16:23:03 : [110291.077887] [<ffffff8008263344>] chrdev_open+0x94/0x198
Jun 2 16:23:03 : [110291.077895] [<ffffff8008259e10>] do_dentry_open+0x1b8/0x318
Jun 2 16:23:03 : [110291.077902] [<ffffff800825b3b8>] vfs_open+0x58/0x88
Jun 2 16:23:03 : [110291.077910] [<ffffff800826e674>] do_last+0x454/0xe60
Jun 2 16:23:03 : [110291.077917] [<ffffff800826f110>] path_openat+0x90/0x378
Jun 2 16:23:03 : [110291.077925] [<ffffff8008270680>] do_filp_open+0x70/0xe8
Jun 2 16:23:03 : [110291.077944] [<ffffff800825b87c>] do_sys_open+0x174/0x258
Jun 2 16:23:03 : [110291.077949] [<ffffff800825b9e4>] SyS_openat+0x3c/0x50
Jun 2 16:23:03 : [110291.077966] [<ffffff80080838c0>] el0_svc_naked+0x34/0x38
Jun 2 16:23:03 : [110291.077969] Mem-Info:
Jun 2 16:23:03 : [110291.077979] active_anon:987121 inactive_anon:179800 isolated_anon:0
Jun 2 16:23:03 : [110291.077979] active_file:663634 inactive_file:1401273 isolated_file:0
Jun 2 16:23:03 : [110291.077979] unevictable:3038 dirty:13 writeback:7 unstable:0
Jun 2 16:23:03 : [110291.077979] slab_reclaimable:127440 slab_unreclaimable:30839
Jun 2 16:23:03 : [110291.077979] mapped:187389 shmem:176372 pagetables:5467 bounce:0
Jun 2 16:23:03 : [110291.077979] free:208187 free_pcp:549 free_cma:171536
Jun 2 16:23:03 : [110291.077990] Node 0 active_anon:3948484kB inactive_anon:719200kB active_file:2654536kB inactive_file:5605092kB unevictable:12152kB isolated(anon):0kB isolated(file):0kB mapped:749556kB dirty:52kB writeback:28kB shmem:705488kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 1959936kB writeback_tmp:0kB unstable:0kB pages_scanned:0 all_unreclaimable? no
Jun 2 16:23:03 : [110291.077996] DMA free:744120kB min:5004kB low:6800kB high:8596kB active_anon:13864kB inactive_anon:24kB active_file:7808kB inactive_file:959072kB unevictable:0kB writepending:0kB present:1839104kB managed:1812920kB mlocked:0kB slab_reclaimable:17836kB slab_unreclaimable:792kB kernel_stack:16kB pagetables:44kB bounce:0kB free_pcp:444kB local_pcp:444kB free_cma:686144kB
Jun 2 16:23:03 : lowmem_reserve[]: 0 14051 14051 14051
Jun 2 16:23:03 : [110291.078048] Normal free:88628kB min:40048kB low:54436kB high:68824kB active_anon:3934536kB inactive_anon:719176kB active_file:2646728kB inactive_file:4646020kB unevictable:12152kB writepending:80kB present:14680064kB managed:14389244kB mlocked:0kB slab_reclaimable:491924kB slab_unreclaimable:122564kB kernel_stack:8864kB pagetables:21824kB bounce:0kB free_pcp:1748kB local_pcp:680kB free_cma:0kB
Jun 2 16:23:03 : lowmem_reserve[]: 0 0 0 0
Jun 2 16:23:03 : [110291.078076] DMA: 36*4kB (UE) 39*8kB (UE) 38*16kB (UE) 37*32kB (UE) 94*64kB (UME) 54*128kB (UME) 14*256kB (UME) 3*512kB (ME) 3*1024kB (UME) 2*2048kB (UC) 175*4096kB (UMC) = 744264kB
Jun 2 16:23:03 : Normal: 138*4kB (UE) 98*8kB (UME) 316*16kB (UME) 115*32kB (UMEH) 894*64kB (UME) 24*128kB (UMH) 11*256kB (MH) 8*512kB (MH) 5*1024kB (MH) 3*2048kB (M) 0*4096kB = 88536kB
Jun 2 16:23:03 : [110291.078200] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
Jun 2 16:23:03 : [110291.078203] 2244345 total pagecache pages
Jun 2 16:23:03 : [110291.078206] 0 pages in swap cache
Jun 2 16:23:03 : [110291.078209] Swap cache stats: add 10378, delete 10378, find 0/0
Jun 2 16:23:03 : [110291.078212] Free swap = 8059544kB
Jun 2 16:23:03 : [110291.078215] Total swap = 8101056kB
Jun 2 16:23:03 : [110291.078218] 4129792 pages RAM
Jun 2 16:23:03 : [110291.078220] 0 pages HighMem/MovableOnly
Jun 2 16:23:03 : [110291.078223] 79251 pages reserved
Jun 2 16:23:03 : [110291.078242] 188416 pages cma reserved
Jun 2 16:23:03 : [110291.078251] nvdla 15880000.nvdla0: nvdla_queue_task_pool_alloc: failed to allocate task_pool->kmem_addr
Jun 2 16:23:03 : [110291.198102] ai_ctrl: page allocation failure: order:10, mode:0x240c0c0(GFP_KERNEL|__GFP_COMP|__GFP_ZERO)
Jun 2 16:23:03 : [110291.198168] CPU: 1 PID: 16745 Comm: ai_ctrl Not tainted 4.9.140-tegra #108
Jun 2 16:23:03 : [110291.198176] Hardware name: Jetson-AGX (DT)
Jun 2 16:23:03 : [110291.198180] Call trace:
Jun 2 16:23:03 : [110291.198196] [<ffffff800808bdb8>] dump_backtrace+0x0/0x198
Jun 2 16:23:03 : [110291.198203] [<ffffff800808c37c>] show_stack+0x24/0x30
Jun 2 16:23:03 : [110291.198211] [<ffffff800845d820>] dump_stack+0x98/0xc0
Jun 2 16:23:03 : [110291.198222] [<ffffff80081cf49c>] warn_alloc+0x104/0x130
Jun 2 16:23:03 : [110291.198230] [<ffffff80081cf9bc>] __alloc_pages_nodemask+0x474/0xd38
Jun 2 16:23:03 : [110291.198235] [<ffffff80081f3f44>] kmalloc_order+0x3c/0x78
Jun 2 16:23:03 : [110291.198239] [<ffffff80081f3fbc>] kmalloc_order_trace+0x3c/0x138
Jun 2 16:23:03 : [110291.198267] [<ffffff8008233564>] __kmalloc+0x2f4/0x360
Jun 2 16:23:03 : [110291.198286] [<ffffff8008579080>] nvdla_queue_alloc+0x208/0x340
Jun 2 16:23:03 : [110291.198312] [<ffffff8008575190>] nvdla_open+0xc0/0x1c8
Jun 2 16:23:03 : [110291.198318] [<ffffff8008263344>] chrdev_open+0x94/0x198
Jun 2 16:23:03 : [110291.198324] [<ffffff8008259e10>] do_dentry_open+0x1b8/0x318
Jun 2 16:23:03 : [110291.198330] [<ffffff800825b3b8>] vfs_open+0x58/0x88
Jun 2 16:23:03 : [110291.198336] [<ffffff800826e674>] do_last+0x454/0xe60
Jun 2 16:23:03 : [110291.198341] [<ffffff800826f110>] path_openat+0x90/0x378
Jun 2 16:23:03 : [110291.198346] [<ffffff8008270680>] do_filp_open+0x70/0xe8
Jun 2 16:23:03 : [110291.198353] [<ffffff800825b87c>] do_sys_open+0x174/0x258
Jun 2 16:23:03 : [110291.198358] [<ffffff800825b9e4>] SyS_openat+0x3c/0x50
Jun 2 16:23:03 : [110291.198363] [<ffffff80080838c0>] el0_svc_naked+0x34/0x38
Jun 2 16:23:03 : [110291.198366] Mem-Info:
Jun 2 16:23:03 : [110291.198376] active_anon:988975 inactive_anon:180135 isolated_anon:0
Jun 2 16:23:03 : [110291.198376] active_file:663576 inactive_file:1397363 isolated_file:0
Jun 2 16:23:03 : [110291.198376] unevictable:3038 dirty:13 writeback:8 unstable:0
Jun 2 16:23:03 : [110291.198376] slab_reclaimable:127281 slab_unreclaimable:30839
Jun 2 16:23:03 : [110291.198376] mapped:187396 shmem:176339 pagetables:5467 bounce:0
Jun 2 16:23:03 : [110291.198376] free:210968 free_pcp:239 free_cma:171536
Jun 2 16:23:03 : [110291.198404] Node 0 active_anon:3955900kB inactive_anon:720540kB active_file:2654304kB inactive_file:5589452kB unevictable:12152kB isolated(anon):0kB isolated(file):0kB mapped:749584kB dirty:52kB writeback:32kB shmem:705356kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 1959936kB writeback_tmp:0kB unstable:0kB pages_scanned:113 all_unreclaimable? no
Jun 2 16:23:03 : [110291.198411] DMA free:744516kB min:5004kB low:6800kB high:8596kB active_anon:13864kB inactive_anon:24kB active_file:7808kB inactive_file:959072kB unevictable:0kB writepending:0kB present:1839104kB managed:1812920kB mlocked:0kB slab_reclaimable:17836kB slab_unreclaimable:792kB kernel_stack:16kB pagetables:44kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:686144kB
Jun 2 16:23:03 : [110291.198434] Normal free:99356kB min:40048kB low:54436kB high:68824kB active_anon:3941952kB inactive_anon:720516kB active_file:2646496kB inactive_file:4630380kB unevictable:12152kB writepending:84kB present:14680064kB managed:14389244kB mlocked:0kB slab_reclaimable:491288kB slab_unreclaimable:122564kB kernel_stack:8864kB pagetables:21824kB bounce:0kB free_pcp:952kB local_pcp:188kB free_cma:0kB
Jun 2 16:23:03 : [110291.198476] DMA: 37*4kB (UME) 40*8kB (UME) 39*16kB (UME) 38*32kB (UME) 94*64kB (UME) 55*128kB (UME) 15*256kB (UME) 3*512kB (ME) 3*1024kB (UME) 2*2048kB (UC) 175*4096kB (UMC) = 744708kB
Jun 2 16:23:03 : Normal: 171*4kB (UME) 134*8kB (UME) 277*16kB (UME) 128*32kB (UMEH) 937*64kB (UME) 38*128kB (UMH) 19*256kB (MH) 12*512kB (MH) 9*1024kB (MH) 2*2048kB (M) 0*4096kB = 99436kB
Jun 2 16:23:03 : [110291.198577] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
Jun 2 16:23:03 : [110291.198579] 2240290 total pagecache pages
Jun 2 16:23:03 : [110291.198583] 0 pages in swap cache
Jun 2 16:23:03 : [110291.198586] Swap cache stats: add 10431, delete 10431, find 0/0
Jun 2 16:23:03 : [110291.198589] Free swap = 8059332kB
Jun 2 16:23:03 : [110291.198591] Total swap = 8101056kB
Jun 2 16:23:03 : [110291.198594] 4129792 pages RAM
Jun 2 16:23:03 : [110291.198597] 0 pages HighMem/MovableOnly
Jun 2 16:23:03 : [110291.198599] 79251 pages reserved
Jun 2 16:23:03 : [110291.198602] 188416 pages cma reserved
Jun 2 16:23:03 : [110291.198608] nvdla 158c0000.nvdla1: nvdla_queue_task_pool_alloc: failed to allocate task_pool->kmem_addr
Jun 2 16:25:34 : [110442.136610] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
Jun 2 16:32:53 : [110881.133259] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
Jun 2 16:46:32 : [ 0.000000] Booting Linux on physical CPU 0x0
Jun 2 16:46:32 : [ 0.000000] Linux version 4.9.140-tegra (tztek@build) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #108 SMP PREEMPT Fri May 15 14:06:44 CST 2020 tztek_version:v0.0.2_debug
Jun 2 16:46:32 : [ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
Jun 2 16:46:32 : [ 0.000000] OF: fdt:memory scan node memory, reg size 48,
Jun 2 16:46:32 : [ 0.000000] OF: fdt: - 80000000 , 2c000000
Jun 2 16:46:32 : [ 0.000000] OF: fdt: - ac200000 , 44600000
Jun 2 16:46:32 : [ 0.000000] OF: fdt: - 100000000 , 380000000
Jun 2 16:46:32 : [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
Jun 2 16:46:32 : [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
Jun 2 16:46:32 : [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
Jun 2 16:46:32 : [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
Jun 2 16:46:32 : [ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
Jun 2 16:46:32 : [ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
Jun 2 16:46:32 : [ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
Jun 2 16:46:32 : [ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
Jun 2 16:46:32 : [ 0.000000] On node 0 totalpages: 4129792
Jun 2 16:46:32 : [ 0.000000] DMA zone: 7184 pages used for memmap
Jun 2 16:46:32 : [ 0.000000] DMA zone: 0 pages reserved
Jun 2 16:46:32 : [ 0.000000] DMA zone: 459776 pages, LIFO batch:31
Jun 2 16:46:32 : [ 0.000000] Normal zone: 57344 pages used for memmap
Jun 2 16:46:32 : [ 0.000000] Normal zone: 3670016 pages, LIFO batch:31
Jun 2 16:46:32 : [ 0.000000] psci: probing for conduit method from DT.
Jun 2 16:46:32 : [ 0.000000] psci: PSCIv1.0 detected in firmware.
Jun 2 16:46:32 : [ 0.000000] psci: Using standard PSCI v0.2 function IDs
Jun 2 16:46:32 : [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Jun 2 16:46:32 : [ 0.000000] psci: SMC Calling Convention v1.1
Jun 2 16:46:32 : [ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc3ffc47000 s61592 r8192 d32616 u102400
Jun 2 16:46:32 : [ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
