Hello during reboot tests my Nvidia Xavier the file system was corrupted.
The reboot was done using soft reboot by entering the reboot command.
I am using customised BSP over customized nvidia Xavier evb.
The broken log:
[0000.054] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0000.062] I> MB1 (prd-version: 2.6.0.0-t194-41334769-cab45716)
[0000.068] I> Boot-mode: Coldboot
[0000.071] I> Platform: Silicon
[0000.074] I> Chip revision : A02P
[0000.077] I> Bootrom patch version : 15 (correctly patched)
[0000.082] I> ATE fuse revision : 0x200
[0000.085] I> Ram repair fuse : 0x0
[0000.088] I> Ram Code : 0x2
[0000.091] I> rst_source: 0xb, rst_level: 0x1
[0000.096] I> Boot-device: SDMMC (instance: 3)
[0000.112] I> sdmmc DDR50 mode
[0000.116] I> Boot chain mechanism: A/B
[0000.119] I> Current Boot-Chain Slot: 0
[0000.123] I> BR-BCT Boot-Chain: 0, status: 0. update flag: 0
[0000.130] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0000.135] I> Temperature = 45500
[0000.138] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.143] W> Skipping boost for clk: BPMP_APB
[0000.147] W> Skipping boost for clk: AXI_CBB
[0000.151] W> Skipping boost for clk: AON_CPU_NIC
[0000.155] W> Skipping boost for clk: CAN1
[0000.159] W> Skipping boost for clk: CAN2
[0000.163] I> Boot-device: SDMMC (instance: 3)
[0000.172] I> Sdmmc: HS400 mode enabled
[0000.176] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.183] W> Thermal config not found in BCT
[0000.191] W> MEMIO rail config not found in BCT
[0000.214] I> sdmmc bdev is already initialized
[0000.258] W> Platform config not found in BCT
[0000.292] I> MB1 done
����main enter
SPE VERSION #: R01.00.18 Created: Jan 29 2021 @ 14:18:27
HW Function test
Start Scheduler.
in late init
[0000.301] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-74494172)
[0000.302] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.302] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.303] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.309] W> device prod register failed
[0000.313] I> gpio framework initialized
[0000.316] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.324] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.331] I> No valid sdcard_params in mb1_bct
[0000.336] I> Boot_device: SDMMC_BOOT instance: 3
[0000.340] I> sdmmc-3 params source = boot args
[0000.349] I> sdmmc-3 params source = boot args
[0000.350] I> sdmmc bdev is already initialized
[0000.383] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0000.399] I> Found 44 partitions in SDMMC_USER (instance 3)
[0000.400] I> Active Boot chain : 0
[0000.456] I> Relocating BR-BCT
[0000.458] > DEVICE_PROD: device prod is not initialized.
[0000.483] E> I2C: slave not found in slaves.
[0000.484] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0000.485] E> I2C_DEV: Failed to send register address 0x00000000.
[0000.486] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0000.486] E> eeprom: Failed to read I2C slave device
[0000.490] I> Failed to read CVB eeprom data @ AE
[0000.494] I> Retrying CVB eeprom read @ AC ...
[0000.499] E> I2C: slave not found in slaves.
[0000.503] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0000.510] E> I2C_DEV: Failed to send register address 0x00000000.
[0000.516] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0000.525] E> eeprom: Failed to read I2C slave device
[0000.530] I> Failed to read CVB eeprom data @ AC
[0000.581] I> Relocating OP-TEE dtb from: 0x6bfff710 to 0x70050000, size: 1008
[0000.582] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0000.582] I> [1] START: 0xaf010000, SIZE: 0x189f0000
[0000.583] I> [2] START: 0xc7b00000, SIZE: 0xc0000
[0000.583] I> [3] START: 0xca000000, SIZE: 0x800000
[0000.583] I> dram_block larger than 80000000
[0000.586] I> [4] START: 0x100000000, SIZE: 0x780000000
[0000.597] I> Setting NS memory ranges to OP-TEE dtb finished.
[0000.611] I> found decompressor handler: lz4
[0001.107] I> EKB detected (length: 0x410) @ VA:0x526ff400
[0001.109] I> Setting EKB blob info to OPTEE dtb finished.
��NOTICE: BL31: v2.6(release):346877e39
NOTICE: BL31: Built : 12:32:40, Aug 1 2023
I/TC: Physical secure memory base 0xcb040000 size 0xf00000
bpmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
clk_early initialized
mail_early initialized
fuse initialized
hwwdt initialized
t194_ec_get_ec_list: found 45 ecs
ec initialized
vmon_setup_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
mc initialized
reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
regulator initialized
��I/TC:
��avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
suspend initialized
pg_late initialized
pg_mrq_init initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
��I/TC: Non-secure external DT found
��clk_dt_late initialized
noc_late initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
avfs_clk_mach_post initialized
avfs_clk_platform_post initialized
cvc_late initialized
regulator_post initialized
rm initialized
console_late initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] ��I/TC: OP-TEE version: 3.21 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Aug 1 19:39:56 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
[0001.935] I> Welcome to NVDisp-Init
[0001.935] I> NVDisp-Init version: t194-709c0123
[0001.935] I> CPU-BL Params @ 0xca020000
[0001.935] I> 0) Base:0x00000000 Size:0x00000000
[0001.936] I> 1) Base:0xc8100000 Size:0x00100000
[0001.936] I> 2) Base:0xc9800000 Size:0x00200000
[0001.936] I> 3) Base:0xc8600000 Size:0x00200000
[0001.939] I> 4) Base:0xc8000000 Size:0x00100000
[0001.943] I> 5) Base:0xc7f00000 Size:0x00100000
[0001.948] I> 6) Base:0xc9400000 Size:0x00400000
[0001.952] I> 7) Base:0xc9000000 Size:0x00400000
[0001.957] I> 8) Base:0xc7e00000 Size:0x00100000
[0001.961] I> 9) Base:0xc7d00000 Size:0x00100000
[0001.966] I> 10) Base:0xca800000 Size:0x00800000
[0001.970] I> 11) Base:0x40000000 Size:0x00040000
[0001.975] I> 12) Base:0xc7c00000 Size:0x00100000
[0001.979] I> 13) Base:0x40046000 Size:0x00002000
[0001.984] I> 14) Base:0x40048000 Size:0x00002000
[0001.988] I> 15) Base:0xaf000000 Size:0x00004000
[0001.992] I> 16) Base:0x4004a000 Size:0x00002000
[0001.997] I> 17) Base:0xc7a00000 Size:0x00100000
[0002.001] I> 18) Base:0x4004c000 Size:0x00002000
[0002.006] I> 19) Base:0xc9a00000 Size:0x00600000
[0002.010] I> 20) Base:0x4004e000 Size:0x00002000
[0002.015] I> 21) Base:0xc7bc0000 Size:0x0000c000
[0002.019] I> 22) Base:0x00000000 Size:0x00000000
[0002.024] I> 23) Base:0xc7be0000 Size:0x00020000
[0002.028] I> 24) Base:0xcc000000 Size:0x02000000
[0002.033] I> 25) Base:0x40050000 Size:0x00002000
[0002.037] I> 26) Base:0x40040000 Size:0x00006000
[0002.042] I> 27) Base:0xc8c00000 Size:0x00400000
[0002.046] I> 28) Base:0xc8400000 Size:0x00200000
[0002.050] I> 29) Base:0xc8800000 Size:0x00400000
[0002.055] I> 30) Base:0xc7bd0000 Size:0x00010000
[0002.059] I> 31) Base:0x00000000 Size:0x00000000
[0002.064] I> 32) Base:0xf8000000 Size:0x08000000
[0002.068] I> 33) Base:0xce000000 Size:0x2a000000
[0002.073] I> 34) Base:0xcb000000 Size:0x01000000
[0002.077] I> 35) Base:0xae000000 Size:0x01000000
[0002.082] I> 36) Base:0xa0000000 Size:0x0e000000
[0002.086] I> 37) Base:0xca000000 Size:0x00800000
[0002.091] I> 38) Base:0x80000000 Size:0x20000000
[0002.095] I> 39) Base:0xb0000000 Size:0x08000000
[0002.100] I> 40) Base:0x00000000 Size:0x00000000
[0002.104] I> 41) Base:0x00000000 Size:0x00000000
[0002.108] I> 42) Base:0xc8200000 Size:0x00200000
[0002.113] I> 43) Base:0x00000000 Size:0x00000000
[0002.117] I> 44) Base:0x00000000 Size:0x00000000
[0002.122] I> 45) Base:0x00000000 Size:0x00000000
[0002.126] GIC-SPI Target CPU: 0
[0002.129] Interrupts Init done
[0002.132] calling constructors
[0002.135] initializing heap
[0002.138] I> Heap: [0xa0960000 ... 0xadf00000]
[0002.142] initializing threads
[0002.145] initializing timers
[0002.148] creating bootstrap completion thread
[0002.152] top of bootstrap2()
[0002.155] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0002.159] initializing platform
[0002.162] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0002.168] W> device prod register failed
[0002.172] I> Bl_dtb @0xadf00000
[0002.175] I> gpio framework initialized
[0002.186] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.191] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.197] I> fixed regulator driver initialized
[0002.214] I> register 'maxim' power off handle
[0002.216] I> virtual i2c enabled
[0002.216] I> registered 'maxim,max20024' pmic
[0002.217] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.217] I> Boot-device: eMMC
[0002.219] I> Boot_device: SDMMC_BOOT instance: 3
[0002.225] I> sdmmc-3 params source = boot args
[0002.228] W> No board IDs available
[0002.231] E> Failed to get board id info!
[0002.235] I> sdmmc bdev is already initialized
[0002.239] I> sdmmc-3 params source = boot args
[0002.245] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0002.251] I> Found 44 partitions in SDMMC_USER (instance 3)
[0002.260] E> cannot find any other nvdisp nodes
[0002.260] E> no valid display unit config found in dtb
[0002.266] W> display init failed
[0002.267] initializing target
[0002.269] calling apps_init()
[0002.272] starting app kernel_boot_app
[0002.276] I> Kernel type = Normal
Jetson UEFI firmware (version 4.1-33958178 built on 2023-08-01T19:34:02+00:00)
��E/TC:? 0 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_origin=0
E/LD: init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
E/TC:? 0 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting Recovery Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[ 0.000000] Linux version 5.10.120-tegra (user@user-System-Product-Name) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Thu Nov 9 12:3
[ 0.000000] Machine model: Jetson-AGX
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] printk: bootconsole [tegra_comb_uart0] enabled
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x859dc6b18 SMBIOS=0xc7bb0000 SMBIOS 3.0=0x8585c0000 MEMATTR=0x8590de018 ESRT=0x85913e798 RNG=0x87c264c18 MEMRESERVE=0x859132f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x000000085913e798 to 0x000000085913e7d0.
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af010000-0x00000000c79fffff]
[ 0.000000] node 0: [mem 0x00000000c7b00000-0x00000000c7b9ffff]
[ 0.000000] node 0: [mem 0x00000000c7ba0000-0x00000000c7bbffff]
[ 0.000000] node 0: [mem 0x00000000ca000000-0x00000000ca7fffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000858191fff]
[ 0.000000] node 0: [mem 0x0000000858192000-0x0000000858375fff]
[ 0.000000] node 0: [mem 0x0000000858376000-0x000000085850ffff]
[ 0.000000] node 0: [mem 0x0000000858510000-0x000000085851ffff]
[ 0.000000] node 0: [mem 0x0000000858520000-0x00000008585bffff]
[ 0.000000] node 0: [mem 0x00000008585c0000-0x00000008585cffff]
[ 0.000000] node 0: [mem 0x00000008585d0000-0x00000008590dffff]
[ 0.000000] node 0: [mem 0x00000008590e0000-0x000000085912ffff]
[ 0.000000] node 0: [mem 0x0000000859130000-0x000000085922ffff]
[ 0.000000] node 0: [mem 0x0000000859230000-0x000000085940ffff]
[ 0.000000] node 0: [mem 0x0000000859410000-0x000000085943ffff]
[ 0.000000] node 0: [mem 0x0000000859440000-0x000000085950ffff]
[ 0.000000] node 0: [mem 0x0000000859510000-0x000000085960ffff]
[ 0.000000] node 0: [mem 0x0000000859610000-0x00000008598cffff]
[ 0.000000] node 0: [mem 0x00000008598d0000-0x0000000859f3ffff]
[ 0.000000] node 0: [mem 0x0000000859f40000-0x0000000859fdffff]
[ 0.000000] node 0: [mem 0x0000000859fe0000-0x000000085a10ffff]
[ 0.000000] node 0: [mem 0x000000085a110000-0x000000085a24ffff]
[ 0.000000] node 0: [mem 0x000000085a250000-0x000000085a2dffff]
[ 0.000000] node 0: [mem 0x000000085a2e0000-0x000000085a32ffff]
[ 0.000000] node 0: [mem 0x000000085a330000-0x000000085a35ffff]
[ 0.000000] node 0: [mem 0x000000085a360000-0x000000085a3fffff]
[ 0.000000] node 0: [mem 0x000000085a400000-0x000000085a44ffff]
[ 0.000000] node 0: [mem 0x000000085a450000-0x000000085a4effff]
[ 0.000000] node 0: [mem 0x000000085a4f0000-0x000000085a9cffff]
[ 0.000000] node 0: [mem 0x000000085a9d0000-0x000000085abaffff]
[ 0.000000] node 0: [mem 0x000000085abb0000-0x000000087c21ffff]
[ 0.000000] node 0: [mem 0x000000087c220000-0x000000087c26ffff]
[ 0.000000] node 0: [mem 0x000000087c270000-0x000000087fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000087fffffff]
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c3800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8032421
[ 0.000000] Kernel command line: root=/dev/initrd rw rootwait console=ttyTCU0,115200n8 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 sdhci_te
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000b3800000-0x00000000c3800000] (256MB)
[ 0.000000] Memory: 31672824K/32639680K available (18560K kernel code, 3164K rwdata, 7164K rodata, 3968K init, 1418K bss, 901320K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.006746] Console: colour dummy device 80x25
[ 0.010427] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.020555] pid_max: default: 32768 minimum: 301
[ 0.025401] LSM: Security Framework initializing
[ 0.029882] Yama: becoming mindful.
[ 0.033515] SELinux: Initializing.
[ 0.037315] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.044750] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.056234] rcu: Hierarchical SRCU implementation.
[ 0.057789] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.065884] DTS File Name: /home/user/work/Linux4Som/besomlinuxkernel/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-000i
[ 0.085145] DTB Build time: Nov 9 2023 12:16:13
[ 0.091935] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.096408] Remapping and enabling EFI services.
[ 0.102338] smp: Bringing up secondary CPUs ...
��: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
��[ 0.198853] Detected PIPT I-cache on CPU1
[ 0.198907] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[ 0.228481] Detected PIPT I-cache on CPU2
[ 0.228560] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[ 0.258112] Detected PIPT I-cache on CPU3
[ 0.258185] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[ 0.287774] Detected PIPT I-cache on CPU4
[ 0.287874] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[ 0.317445] Detected PIPT I-cache on CPU5
[ 0.317512] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[ 0.347207] Detected PIPT I-cache on CPU6
[ 0.347309] CPU6: Booted secondary processor 0x0000000300 [0x4e0f0040]
[ 0.377086] Detected PIPT I-cache on CPU7
[ 0.377190] CPU7: Booted secondary processor 0x0000000301 [0x4e0f0040]
[ 0.377638] smp: Brought up 1 node, 8 CPUs
[ 0.379426] SMP: Total of 8 processors activated.
[ 0.379789] CPU features: detected: Privileged Access Never
[ 0.380175] CPU features: detected: LSE atomic instructions
[ 0.380927] CPU features: detected: User Access Override
[ 0.386456] CPU features: detected: 32-bit EL0 Support
[ 0.391550] CPU features: detected: RAS Extension Support
[ 0.397045] CPU features: detected: CRC32 instructions
[ 0.402141] CPU features: detected: 32-bit EL1 Support
[ 0.469994] CPU: All CPU(s) started at EL2
[ 0.479856] devtmpfs: initialized
[ 0.529176] Registered cp15_barrier emulation handler
[ 0.529406] Registered setend emulation handler
[ 0.529493] KASLR enabled
[ 0.529760] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.529925] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.531331] pinctrl core: initialized pinctrl subsystem
[ 0.532451] SMBIOS 3.0.0 present.
[ 0.532551] DMI: Unknown Jetson-AGX/Jetson-AGX, BIOS 4.1-33958178 08/01/2023
[ 0.533479] NET: Registered protocol family 16
[ 0.536383] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.538062] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.539568] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.539773] audit: initializing netlink subsys (disabled)
[ 0.540226] audit: type=2000 audit(0.476:1): state=initialized audit_enabled=0 res=1
[ 0.540607] thermal_sys: Registered thermal governor 'step_wise'
[ 0.540613] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.540745] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.543013] cpuidle: using governor menu
[ 0.546286] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.553350] ASID allocator initialised with 32768 entries
[ 0.558650] Serial: AMBA PL011 UART driver
[ 0.565258] Tegra reboot handler registered.
[ 0.617105] mc: mapped MMIO address: 0xffff800010ee0000 -> 0x2c10000
[ 0.617265] mc: mapped MMIO address: 0xffff800010f00000 -> 0x2c20000
[ 0.617426] mc: mapped MMIO address: 0xffff800010f20000 -> 0x2c30000
[ 0.617565] mc: mapped MMIO address: 0xffff800010f40000 -> 0x2c40000
[ 0.617699] mc: mapped MMIO address: 0xffff800010f60000 -> 0x2c50000
[ 0.617837] mc: mapped MMIO address: 0xffff800010f80000 -> 0x2b80000
[ 0.618026] mc: mapped MMIO address: 0xffff800010fa0000 -> 0x2b90000
[ 0.618197] mc: mapped MMIO address: 0xffff800010fc0000 -> 0x2ba0000
[ 0.619098] mc: mapped MMIO address: 0xffff800010fe0000 -> 0x2bb0000
[ 0.625585] mc: mapped MMIO address: 0xffff800011000000 -> 0x1700000
[ 0.632071] mc: mapped MMIO address: 0xffff800011020000 -> 0x1710000
[ 0.638457] mc: mapped MMIO address: 0xffff800011040000 -> 0x1720000
[ 0.644828] mc: mapped MMIO address: 0xffff800011060000 -> 0x1730000
[ 0.651223] mc: mapped MMIO address: 0xffff800011080000 -> 0x1740000
[ 0.657614] mc: mapped MMIO address: 0xffff8000110a0000 -> 0x1750000
[ 0.663989] mc: mapped MMIO address: 0xffff8000110c0000 -> 0x1760000
[ 0.670377] mc: mapped MMIO address: 0xffff8000110e0000 -> 0x1770000
[ 0.676839] mc-err: mcerr ops are set to t19x
[ 0.690720] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.690856] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.694350] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.701009] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.715201] ACPI: Interpreter disabled.
[ 0.716371] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.719379] iommu: Default domain type: Translated
[ 0.720770] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.727725] SCSI subsystem initialized
[ 0.730765] usbcore: registered new interface driver usbfs
[ 0.735972] usbcore: registered new interface driver hub
[ 0.741714] usbcore: registered new device driver usb
[ 0.747251] mc: Linux media interface: v0.10
[ 0.751158] videodev: Linux video capture interface: v2.00
[ 0.756999] pps_core: LinuxPPS API ver. 1 registered
[ 0.761456] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.770576] PTP clock support registered
[ 0.774730] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.781373] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.788155] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.795527] Registered efivars operations
[ 0.799251] FPGA manager framework
[ 0.802231] Advanced Linux Sound Architecture Driver Initialized.
[ 0.808798] Bluetooth: Core ver 2.22
[ 0.811962] NET: Registered protocol family 31
[ 0.815977] Bluetooth: HCI device and connection manager initialized
[ 0.822363] Bluetooth: HCI socket layer initialized
[ 0.827611] Bluetooth: L2CAP socket layer initialized
[ 0.832629] Bluetooth: SCO socket layer initialized
[ 0.839372] camchar: rtcpu character device driver loaded
[ 0.843929] clocksource: Switched to clocksource arch_sys_counter
[ 1.276084] VFS: Disk quotas dquot_6.6.0
[ 1.276247] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.277022] pnp: PnP ACPI: disabled
[ 1.290321] la/ptsa driver initialized.
[ 1.290598] NET: Registered protocol family 2
[ 1.290968] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 1.305359] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 1.305849] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 1.306975] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 1.307595] TCP: Hash tables configured (established 262144 bind 65536)
[ 1.308015] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 1.308600] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 1.309296] NET: Registered protocol family 1
[ 1.310487] RPC: Registered named UNIX socket transport module.
[ 1.310642] RPC: Registered udp transport module.
[ 1.310764] RPC: Registered tcp transport module.
[ 1.310874] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.311051] PCI: CLS 0 bytes, default 64
[ 1.311468] Trying to unpack rootfs image as initramfs...
[ 1.729315] Freeing initrd memory: 13036K
[ 1.734804] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.735317] kvm [1]: IPA Size Limit: 40 bits
[ 1.736059] kvm [1]: vgic interrupt IRQ9
[ 1.736755] kvm [1]: VHE mode initialized successfully
[ 1.738615] Initialise system trusted keyrings
[ 1.738998] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 1.746598] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.747868] NFS: Registering the id_resolver key type
[ 1.748079] Key type id_resolver registered
[ 1.748178] Key type id_legacy registered
[ 1.748390] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.748553] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.748756] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.758908] NET: Registered protocol family 38
[ 1.759014] Key type asymmetric registered
[ 1.759162] Asymmetric key parser 'x509' registered
[ 1.759321] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 1.759718] io scheduler mq-deadline registered
[ 1.759845] io scheduler kyber registered
[ 1.773252] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.773460] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.773689] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.782326] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[ 1.782372] scrncapt: init (heads:4 wins:6 planes:4)
[ 1.783734] EINJ: ACPI disabled.
[ 1.787477] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 1.787611] tegra-pmc: ### PMC reset source: MAINSWRST
[ 1.787721] tegra-pmc: ### PMC reset level: L1
[ 1.791914] tegra-pmc: ### PMC reset status reg: 0x2d
[ 1.797140] tegra-pmc: PMC Prod config success
[ 1.807134] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.810412] printk: console [ttyTCU0] enabled
1.815819] printk: bootconsole [tegra_comb_uart0] disabled
[ 1.815819] printk: bootconsole [tegra_comb_uart0] disabled
[ 1.828609] arm-smmu 10000000.iommu: probing hardware configuration...
[ 1.833828] arm-smmu 10000000.iommu: SMMUv2 with:
[ 1.838547] arm-smmu 10000000.iommu: stage 1 translation
[ 1.843640] arm-smmu 10000000.iommu: stage 2 translation
[ 1.849221] arm-smmu 10000000.iommu: nested translation
[ 1.854395] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 1.861755] arm-smmu 10000000.iommu: 64 context banks (0 stage-2 only)
[ 1.871975] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 1.875191] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 1.881429] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 1.889167] arm-smmu 12000000.iommu: probing hardware configuration...
[ 1.894118] arm-smmu 12000000.iommu: SMMUv2 with:
[ 1.898846] arm-smmu 12000000.iommu: stage 1 translation
[ 1.904608] arm-smmu 12000000.iommu: stage 2 translation
[ 1.909774] arm-smmu 12000000.iommu: nested translation
[ 1.915466] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 1.922650] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 1.932807] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 1.935740] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 1.942067] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 1.949674] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 1.959969] tegra_profiler: version: 1.151, samples/io: 51/30
[ 1.962682] tegra_profiler: auth: init
[ 1.966754] THERMAL EST: found 3 subdevs
[ 1.970418] THERMAL EST num_resources: 0
[ 1.974002] [THERMAL EST subdev 0]
[ 1.977586] [THERMAL EST subdev 1]
[ 1.980755] [THERMAL EST subdev 2]
[ 1.984241] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.990697] THERMAL EST: thz register success.
[ 1.994951] THERMAL EST: end of probe, return err: 0
[ 2.000025] nvsciipc: loaded module
[ 2.007356] tun: Universal TUN/TAP device driver, 1.6
[ 2.009505] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.015764] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.021556] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.026240] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.032585] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.037885] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.044087] PPP generic driver version 2.4.2
[ 2.048279] PPP BSD Compression module registered
[ 2.052846] PPP Deflate Compression module registered
[ 2.058092] PPP MPPE Compression module registered
[ 2.062853] usbcore: registered new interface driver r8152
[ 2.068619] usbcore: registered new interface driver asix
[ 2.073693] usbcore: registered new interface driver ax88179_178a
[ 2.079831] usbcore: registered new interface driver cdc_ether
[ 2.086023] usbcore: registered new interface driver net1080
[ 2.091655] usbcore: registered new interface driver cdc_subset
[ 2.097405] usbcore: registered new interface driver zaurus
[ 2.103145] usbcore: registered new interface driver cdc_ncm
[ 2.108793] usbcore: registered new interface driver aqc111
[ 2.114417] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.120748] ohci-pci: OHCI PCI platform driver
[ 2.124794] ohci-platform: OHCI generic platform driver
[ 2.130521] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 2.136969] usbcore: registered new interface driver uas
[ 2.141092] usbcore: registered new interface driver usb-storage
[ 2.147698] mousedev: PS/2 mouse device common for all mice
[ 2.152814] usbcore: registered new interface driver xpad
[ 2.160629] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.163362] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:21 UTC (21)
[ 2.171090] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.177767] i2c /dev entries driver
[ 2.180967] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 2.186980] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 2.192039] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 2.197502] tegra-i2c 3190000.i2c: Adding to iommu group 1
[ 2.202966] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 2.208206] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[ 2.213725] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[ 2.227002] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 2.227810] device-mapper: uevent: version 1.0.3
[ 2.230760] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.241309] cpuidle: Initializing cpuidle driver
[ 2.245692] sdhci: Secure Digital Host Controller Interface driver
[ 2.249636] sdhci: Copyright(c) Pierre Ossman
[ 2.254344] Synopsys Designware Multimedia Card Interface Driver
[ 2.260290] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.266238] sdhci-tegra 3460000.sdhci: Adding to iommu group 2
[ 2.267158] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[ 2.279819] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[ 2.301839] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x2
[ 2.305552] max77620 4-003c: Backup battery charging support disabled
[ 2.311841] vdd-1v0: supplied by regulator-dummy
[ 2.317292] vdd-1v8-hs: supplied by regulator-dummy
[ 2.322119] vdd-1v8-ls: supplied by regulator-dummy
[ 2.326872] vdd-1v8-ao: supplied by regulator-dummy
[ 2.330843] vddio-ddr-1v1: supplied by regulator-dummy
[ 2.335270] vdd-rtc: supplied by regulator-dummy
[ 2.337108] spmic-ldo1: supplied by regulator-dummy
[ 2.338373] vdd-ao-3v3: supplied by regulator-dummy
[ 2.344581] vddio-emmc-3v3: supplied by regulator-dummy
[ 2.350967] spmic-ldo4: supplied by regulator-dummy
[ 2.352191] vdd-usb-3v3: supplied by regulator-dummy
[ 2.358384] vddio-sdmmc1-3v3: supplied by regulator-dummy
[ 2.364734] vdd-csi-1v2: supplied by vdd-1v8-ls
[ 2.370269] spmic-ldo8: supplied by vdd-1v8-ls
[ 2.371798] gpio-510 (gpio_default): hogged as output/high
[ 2.373262] gpio-511 (gpio_default): hogged as output/high
[ 2.379692] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[ 2.518953] max77686-rtc max77620-rtc: registered as rtc0
[ 2.520028] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 2.520389] max77620 4-003c: max77620 probe successful
��debugfs initialized
��[ 3.490641] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.491625] hid: raw HID events driver (C) Jiri Kosina
[ 3.492284] usbcore: registered new interface driver usbhid
[ 3.492425] usbhid: USB HID core driver
[ 3.494306] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 3
[ 3.495556] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
��[ 22.527748] Camera-FW on t194-rce-safe started
TCU early console enabled.
[ 22.602387] Camera-FW on t194-rce-safe ready SHA1=058eec60 (crt 0.774 ms, total boot 75.442 ms)
��[ 3.580839] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 3.581468] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.582301] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 3.582901] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 3.584660] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 3.585272] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 3.585802] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 3.587370] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (49)
[ 3.587609] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.589400] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 3.589921] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 3.596744] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 3.603310] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 3.603431] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=058eec606b43624552a5258fda5b4f3967bdfde1
[ 3.623452] tegra_aon c1a0000.aon: Adding to iommu group 4
[ 3.629678] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 3.635456] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.643216] denver_knobs_init:MTS_VERSION:55637613
[ 3.658556] t19x_cache tegra-cache: probed
[ 3.660698] optee: probing for conduit method.
��C: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[ 3.661513] optee: revision 3.21 (d8269f24)
[ 3.777436] optee: dynamic shared memory is enabled
[ 3.778536] optee: initialized driver
[ 3.782835] nvpmodel: initialized successfully
[ 3.783301] tegra_hv: get_hvd: not initialized yet
[ 3.783447] user_ivc_mempool: hypervisor not present
[ 3.784897] usbcore: registered new interface driver snd-usb-audio
[ 3.786524] u32 classifier
[ 3.786699] input device check on
[ 3.786950] Actions configured
[ 3.787495] Initializing XFRM netlink socket
[ 3.788693] NET: Registered protocol family 10
[ 3.791746] Segment Routing with IPv6
[ 3.792173] NET: Registered protocol family 17
[ 3.792529] NET: Registered protocol family 15
[ 3.792879] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.794278] Bluetooth: RFCOMM socket layer initialized
[ 3.794631] Bluetooth: RFCOMM ver 1.11
[ 3.794899] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.795211] Bluetooth: HIDP socket layer initialized
[ 3.796479] 9pnet: Installing 9P2000 support
[ 3.796782] Key type dns_resolver registered
[ 3.798216] registered taskstats version 1
[ 3.798413] Loading compiled-in X.509 certificates
[ 3.841500] Loaded X.509 cert 'Build time autogenerated kernel key: 040f37620ff24e4f4f1fb259d4cf06f682cae012'
[ 3.843087] tegra194-pcie 14180000.pcie: Adding to iommu group 5
[ 3.848779] tegra194-pcie 14180000.pcie: host bridge /pcie@14180000 ranges:
[ 3.849217] tegra194-pcie 14180000.pcie: IO 0x0038100000..0x00381fffff -> 0x0038100000
[ 3.849708] tegra194-pcie 14180000.pcie: MEM 0x1800000000..0x1b3fffffff -> 0x1800000000
[ 3.850055] tegra194-pcie 14180000.pcie: MEM 0x1b40000000..0x1bffffffff -> 0x0040000000
[ 3.956174] tegra194-pcie 14180000.pcie: Link up
[ 3.967151] tegra194-pcie 14180000.pcie: PCI host bridge to bus 0000:00
[ 3.967359] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.967521] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 3.967745] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[ 3.967987] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[ 3.968319] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 3.968734] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 3.979293] pci 0000:01:00.0: [15b7:501a] type 00 class 0x010802
[ 3.979636] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 3.980103] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x000000ff 64bit]
[ 3.991193] pci 0000:00:00.0: BAR 14: assigned [mem 0x1b40000000-0x1b400fffff]
[ 3.991558] pci 0000:01:00.0: BAR 0: assigned [mem 0x1b40000000-0x1b40003fff 64bit]
[ 3.992015] pci 0000:01:00.0: BAR 4: assigned [mem 0x1b40004000-0x1b400040ff 64bit]
[ 3.992340] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 3.992587] pci 0000:00:00.0: bridge window [mem 0x1b40000000-0x1b400fffff]
[ 3.992841] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 3.993184] pci 0000:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 4.000917] pcieport 0000:00:00.0: Adding to iommu group 5
[ 4.006310] pcieport 0000:00:00.0: PME: Signaling with IRQ 24
[ 4.012211] pcieport 0000:00:00.0: AER: enabled with IRQ 24
[ 4.017942] nvme 0000:01:00.0: Adding to iommu group 5
[ 4.023223] nvme nvme0: pci function 0000:01:00.0
[ 4.027094] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[ 4.028130] tegra194-pcie 14100000.pcie: Adding to iommu group 6
[ 4.040763] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 4.045469] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 4.051112] nvme nvme0: allocated 32 MiB host memory buffer.
[ 4.054189] tegra194-pcie 14100000.pcie: MEM 0x1200000000..0x122fffffff -> 0x1200000000
[ 4.054213] tegra194-pcie 14100000.pcie: MEM 0x1230000000..0x123fffffff -> 0x0040000000
[ 4.065864] nvme nvme0: 8/0/0 default/read/poll queues
[ 5.176466] tegra194-pcie 14100000.pcie: Phy link never came up
[ 5.176832] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 5.176971] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 5.177130] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 5.177321] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[ 5.177507] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[ 5.177785] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 5.178134] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.197865] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 5.198055] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.199046] pcieport 0001:00:00.0: Adding to iommu group 6
[ 5.199822] pcieport 0001:00:00.0: PME: Signaling with IRQ 26
[ 5.200600] pcieport 0001:00:00.0: AER: enabled with IRQ 26
[ 5.201478] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 5.202184] pci 0001:00:00.0: Removing from iommu group 6
[ 5.202367] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 5.204212] tegra194-pcie 14140000.pcie: Adding to iommu group 7
[ 5.206292] tegra194-pcie 14140000.pcie: host bridge /pcie@14140000 ranges:
[ 5.206562] tegra194-pcie 14140000.pcie: IO 0x0034100000..0x00341fffff -> 0x0034100000
[ 5.213138] tegra194-pcie 14140000.pcie: MEM 0x1280000000..0x12afffffff -> 0x1280000000
[ 5.222028] tegra194-pcie 14140000.pcie: MEM 0x12b0000000..0x12bfffffff -> 0x0040000000
[ 6.336429] tegra194-pcie 14140000.pcie: Phy link never came up
[ 6.336774] tegra194-pcie 14140000.pcie: PCI host bridge to bus 0003:00
[ 6.336928] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 6.337081] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 6.337270] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[ 6.337460] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[ 6.337736] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 6.338073] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 6.357523] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 6.357791] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.358670] pcieport 0003:00:00.0: Adding to iommu group 7
[ 6.359466] pcieport 0003:00:00.0: PME: Signaling with IRQ 28
[ 6.360399] pcieport 0003:00:00.0: AER: enabled with IRQ 28
[ 6.361419] pci_bus 0003:01: busn_res: [bus 01-ff] is released
[ 6.362039] pci 0003:00:00.0: Removing from iommu group 7
[ 6.362235] pci_bus 0003:00: busn_res: [bus 00-ff] is released
[ 6.364147] tegra194-pcie 141a0000.pcie: Adding to iommu group 8
[ 6.365106] tegra194-pcie 141a0000.pcie: supply vddio-pex-ctl not found, using dummy regulator
[ 6.368284] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 6.373355] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 6.381742] tegra194-pcie 141a0000.pcie: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 6.390467] tegra194-pcie 141a0000.pcie: MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[ 7.504510] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 7.504842] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 7.505026] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 7.505141] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 7.505368] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 7.505526] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 7.505838] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 7.506211] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 7.548814] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 7.548975] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.549916] pcieport 0005:00:00.0: Adding to iommu group 8
[ 7.550706] pcieport 0005:00:00.0: PME: Signaling with IRQ 30
[ 7.551480] pcieport 0005:00:00.0: AER: enabled with IRQ 30
[ 7.552601] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 7.553253] pci 0005:00:00.0: Removing from iommu group 8
[ 7.553442] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 7.576100] host1x 13e10000.host1x: Adding to iommu group 9
[ 7.592243] host1x 13e10000.host1x: initialized
[ 7.593010] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 10
[ 7.593464] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 7.594106] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 11
[ 7.594555] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 7.595273] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 12
[ 7.595723] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 7.596366] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 13
[ 7.596744] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 7.597345] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 14
[ 7.604601] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 7.614301] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 15
[ 7.621285] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[ 7.631300] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 16
[ 7.638255] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[ 7.648595] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 17
[ 7.655481] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[ 7.665938] falcon 15340000.vic: Adding to iommu group 18
[ 7.676427] falcon 15340000.vic: initialized
[ 7.677204] falcon 15380000.nvjpg: Adding to iommu group 18
[ 7.684513] falcon 15380000.nvjpg: initialized
[ 7.685217] falcon 154c0000.nvenc: Adding to iommu group 18
[ 7.696008] falcon 154c0000.nvenc: initialized
[ 7.696452] falcon 15a80000.nvenc1: Adding to iommu group 18
[ 7.705217] falcon 15a80000.nvenc1: initialized
[ 7.706112] nvdec 15480000.nvdec: Adding to iommu group 18
[ 7.717746] nvdec 15480000.nvdec: initialized
[ 7.718204] nvdec 15140000.nvdec1: Adding to iommu group 18
[ 7.726819] nvdec 15140000.nvdec1: initialized
[ 7.727171] tsec 15500000.tsec: Adding to iommu group 19
[ 7.734648] tsec 15500000.tsec: initialized
[ 7.735805] tsec 15100000.tsecb: Adding to iommu group 20
[ 7.743861] tsec 15100000.tsecb: initialized
[ 7.747747] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.766878] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 7.773429] gpio-374 (wifi-enable): hogged as output/high
[ 7.774562] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[ 7.776093] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[ 7.776937] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 7.783341] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 7.788939] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 7.796135] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 21
[ 7.803710] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 7.810445] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[ 7.816495] driver not enabled, cannot register any devices
[ 7.822261] tegra194-vi5 15c10000.vi: Adding to iommu group 22
[ 7.828950] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[ 7.837304] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 7.843547] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 7.852863] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[ 7.859458] pva 16000000.pva0: Adding to iommu group 23
[ 7.882474] pva 16000000.pva0: initialized
[ 7.884612] pva 16800000.pva1: Adding to iommu group 24
[ 7.893460] pva 16800000.pva1: initialized
[ 7.895393] nvdla 15880000.nvdla0: Adding to iommu group 25
[ 7.905182] nvdla 15880000.nvdla0: initialized
[ 7.906100] nvdla 158c0000.nvdla1: Adding to iommu group 26
[ 7.913629] nvdla 158c0000.nvdla1: initialized
[ 7.916201] tegradccommon 15200000.display-hub: host1x channel mapped
[ 7.916375] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=62
[ 7.916485] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[ 7.916525] tegradc 15200000.display: Adding to iommu group 27
[ 7.916532] tegradccommon 15200000.display-hub: dma mapping done
[ 7.916784] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[ 7.917637] tegradc 15210000.display: Adding to iommu group 27
[ 7.918411] tegradc 15210000.display: disp0 connected to head1->sor
[ 7.918482] generic_infoframe_type: 0x87
[ 7.918544] tegradc 15210000.display: DT parsed successfully
[ 7.918554] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[ 7.919689] tegradc 15200000.display: disp0 connected to head0->sor2
[ 7.925373] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 7.931596] generic_infoframe_type: 0x87
[ 7.937072] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 7.942752] tegradc 15200000.display: DT parsed successfully
[ 7.948991] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 7.952716] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[ 7.958477] tegra_cec 3960000.tegra_cec: probed
[ 7.968154] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 7.972977] tegra-gpcdma 2600000.dma: Adding to iommu group 1
[ 7.978800] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 7.978834] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 7.979300] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[ 7.984150] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 7.988691] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[ 7.988806] tegradc 15200000.display: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[ 7.994521] kfuse 3830000.kfuse: initialized
[ 8.000099] tegradc 15200000.display: dc_probe: failed hotplug init, -517
[ 8.083030] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 8.089287] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 8.095832] serial-tegra 3100000.serial: Adding to iommu group 1
[ 8.102030] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 35, base_baud = 0) is a TEGRA_UART
[ 8.111292] serial-tegra 3110000.serial: Adding to iommu group 1
[ 8.116852] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 36, base_baud = 0) is a TEGRA_UART
[ 8.126091] serial-tegra 3140000.serial: Adding to iommu group 1
[ 8.131376] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 8.146826] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[ 8.149528] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.154804] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 8.163118] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[ 8.171624] tegra-xusb 3610000.xhci: irq 189, io mem 0x03610000
[ 8.178200] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.186099] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.193017] usb usb1: Product: xHCI Host Controller
[ 8.197987] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 8.204545] usb usb1: SerialNumber: 3610000.xhci
[ 8.209643] hub 1-0:1.0: USB hub found
[ 8.212876] hub 1-0:1.0: 4 ports detected
[ 8.217382] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.222499] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 8.230106] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 8.237452] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.245437] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.252689] usb usb2: Product: xHCI Host Controller
[ 8.257967] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 8.264139] usb usb2: SerialNumber: 3610000.xhci
[ 8.269022] hub 2-0:1.0: USB hub found
[ 8.272630] hub 2-0:1.0: 4 ports detected
[ 8.302915] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2265000 KHz, changing to: 2265600 KHz
[ 8.303981] tegra194-cpufreq ccplex: probed with BWMGR, cl:4
[ 8.304982] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[ 8.307728] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[ 8.307931] driver not enabled, cannot register any devices
[ 8.316090] mmc0: CQHCI version 5.10
[ 8.319179] tegra194-vi5 15c10000.vi: initialized
[ 8.321120] driver not enabled, cannot register any devices
[ 8.328015] tegradc 15210000.display: disp0 connected to head1->sor
[ 8.328991] nvethernet 2490000.ethernet: Adding to iommu group 28
[ 8.333081] generic_infoframe_type: 0x87
[ 8.338970] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[ 8.342762] tegradc 15210000.display: DT parsed successfully
[ 8.350606] nvethernet 2490000.ethernet: failed to read MDIO address
[ 8.356205] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[ 8.362928] nvethernet 2490000.ethernet: setting to default DMA bit mask
[ 8.370579] tegradc 15200000.display: disp0 connected to head0->sor2
[ 8.377225] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[ 8.383760] generic_infoframe_type: 0x87
[ 8.383789] tegradc 15200000.display: DT parsed successfully
[ 8.384244] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 8.390144] nvethernet 2490000.ethernet: Setting default PTP RX queue
[ 8.394119] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[ 8.399924] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 8.422132] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 8.430239] nvethernet 2490000.ethernet: Failed to read DMA Rx ring size, using default [1024]
[ 8.438519] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 8.438522] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 8.455684] tegradc 15200000.display: vblank syncpt # 11 for dc 0
[ 8.464048] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pu_offset, setting default 0
[ 8.470204] tegradc 15200000.display: vpulse3 syncpt # 12 for dc 0
[ 8.479116] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pd_offset, setting default 0
[ 8.486369] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[ 8.499951] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[ 8.501428] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 8.508084] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[ 8.522083] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[ 8.522648] tegradc 15200000.display: probed
[ 8.530319] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:63:c3:18
[ 8.541521] Console: switching to colour frame buffer device 80x30
[ 8.547629] tegradc 15200000.display: fb registered
[ 8.552524] nvethernet 2490000.ethernet: Macsec not supported/Not enabled in DT
[ 8.552568] irq: IRQ272: trimming hierarchy from :pmc@c360000
[ 8.560405] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[ 8.565742] tegradc 15210000.display: disp1 connected to head1->sor
[ 8.574356] irq: IRQ274: trimming hierarchy from :pmc@c360000
[ 8.579729] generic_infoframe_type: 0x87
[ 8.580314] mmc0: Command Queue Engine enabled
[ 8.580318] mmc0: periodic cache flush enabled
[ 8.580328] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 8.580757] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[ 8.580865] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[ 8.580961] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[ 8.581061] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB, chardev (509:0)
[ 8.584912] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36 p37 p38 p39 p40 p41 p42 p43 p44
[ 8.585526] irq: IRQ275: trimming hierarchy from :interrupt-controller@3881000
[ 8.589491] tegradc 15210000.display: DT parsed successfully
[ 8.593885] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 8.597986] tegradc 15210000.display: Display dc.(____ptrval____) registered with id=1
[ 8.605547] tegra-se-nvhost 15810000.se: Adding to iommu group 29
[ 8.608963] tegradc 15210000.display: vblank syncpt # 13 for dc 1
[ 8.616533] tegra-se-nvhost 15810000.se: initialized
[ 8.621051] tegradc 15210000.display: vpulse3 syncpt # 14 for dc 1
[ 8.622275] tegradc 15210000.display: hdmi: invalid prod list prod_list_hdmi_board
[ 8.629853] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 8.645294] tegradc 15210000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 8.653030] tegra-se-nvhost 15820000.se: Adding to iommu group 30
[ 8.699974] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 8.704992] tegra-se-nvhost 15820000.se: initialized
[ 8.710396] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 8.719935] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 8.724030] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 8.765112] tegra-se-nvhost 15830000.se: Adding to iommu group 31
[ 8.771677] tegra-se-nvhost 15830000.se: initialized
[ 8.771950] tegra-i2c 31b0000.i2c: I2C transfer timed out
[ 8.776759] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 8.784022] tegradc 15210000.display: probed
[ 8.787694] tegra-se-nvhost 15840000.se: Adding to iommu group 32
[ 8.798167] tegradc 15210000.display: fb registered
[ 8.798783] tegra-se-nvhost 15840000.se: initialized
[ 8.802932] irq: IRQ276: trimming hierarchy from :pmc@c360000
[ 8.809244] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 8.821581] tegra_actmon d230000.actmon: in actmon_register()...
[ 8.825942] tegra_actmon d230000.actmon: bwmgr_disable = 0
[ 8.831768] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 8.839737] hvc_sysfs: hypervisor is not present
[ 8.897056] ALSA device list:
[ 8.897150] No soundcards found.
[ 8.898096] Freeing unused kernel memory: 3968K
[ 8.898379] Run /init as init process
��WARNING: clock_disable: clk_power_ungate on gated domain 27 for gpcclk
��[ 8.965087] Root device found: initrd
[ 8.967983] tegra_cec 3960000.tegra_cec: Can't find physical address.
[ 8.968157] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
modprobe: FATAL: Module r8168 not found in directory /lib/modules/5.10.120-tegra
[ 8.975342] Mount initrd as rootfs and enter recovery mode
Finding OTA work dir on external storage devices
Checking whether device /dev/mmcblk?p1 exist
Looking for OTA work directory on the device(s): /dev/mmcblk0p1
Checking whether device /dev/sd?1 exist
Device /dev/sd?1 does not exist
Checking whether device /dev/nvme?n1p1 exist
Device /dev/nvme?n1p1 does not exist
Finding OTA work dir on internal storage device
mount /dev/mmcblk0p1 /mnt
[ 9.076439] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
is_boot_only_partition /mnt
OTA work directory /mnt/ota_work is not found on /dev/mmcblk0p1
OTA work directory is not found on internal and external storage devices
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.0# [ 10.299149] tegra-xusb 3610000.xhci: entering ELPG done
[ 40.007966] vdd-3v3-cvb: disabling
[ 40.008065] vdd-1v8-cvb: disabling
[ 40.008178] vdd-epb-1v0: disabling
[ 40.008254] vdd-sata-1v5: disabling
[ 40.008334] vdd-1v8-slt: disabling
[ 40.008408] vdd-3v3-slt: disabling
[ 40.008499] vdd-fan: disabling
bash-5.0#
