Hi
We got a strange crash in our NVENC programs that run on a host with a TITAN Xp device.
The crash points to low level libc functions (see attached valgrind report), and happens only when the program is linked with nvidia-encode.
Furthermore, the simple fact of linking with the library will lead to the crash; the program won’t make any calls to the nvenc API. It seems like nvidia-encode has a global constructor method that can thrash or shadow some function addresses.
Finally the same code and test setup won’t crash on another host with a TITAN X or M6000 device.
We’ve recently upgraded to beta driver 381.09 to workaround another bug.
Valgrind report for an empty unit test
Process terminating with default action of signal 11 (SIGSEGV)
Bad permissions for mapped region at address
at : ???
by : printf (in /usr/lib64/libc-2.17.so)
gtest.cc:2660 testing::internal::ColoredPrintf
gtest.cc:2747 testing::internal::PrettyUnitTestResultPrinter::OnTestIterationStart
gtest.cc:2995 testing::internal::TestEventRepeater::OnTestIterationStart
gtest.cc:4301 testing::internal::UnitTestImpl::RunAllTests
by : bool testing::internal::HandleSehExceptionsInMethodIfSupported<testing::internal::UnitTestImpl, bool>(testing::internal::UnitTestImpl*, bool (testing::internal::UnitTestImpl::*)(), char const*) (gtest.cc:2078)
by : bool testing::internal::HandleExceptionsInMethodIfSupported<testing::internal::UnitTestImpl, bool>(testing::internal::UnitTestImpl*, bool (testing::internal::UnitTestImpl::*)(), char const*) (gtest.cc:2114)
gtest.cc:3926 testing::UnitTest::Run
by : RUN_ALL_TESTS (gtest.h:2288)
by : main (gtest_main.cc:37)
Jump to the invalid address stated on the next line
at : ???
by : __libc_freeres (in /usr/lib64/libc-2.17.so)
by : _vgnU_freeres (in /opt/valgrind/lib/valgrind/vgpreload_core-amd64-linux.so)
by : vfprintf (in /usr/lib64/libc-2.17.so)
Address is not stack'd, malloc'd or (recently) free'd
