Segmentation fault when do OTA with segmentation model
Could you guys help me confirm if OTA update supports segmentation model?
• Hardware Platform (GPU)
• DeepStream Version: nvcr.io/nvidia/deepstream:6.3-gc-triton-devel
• Issue Type( questions, bugs)
I modified deepstream-test5 example a bit like this:
  • add pre-process plugin before nvinfer
  • using model segmentation instead in the config-file properties of nvinfer plugin
Problem: Segmentation fault when switching segmentation model with deepstream example
Could you download my deepstream-test6 example to reproduce the issue?
Run app:
./deepstream-test5-app -c configs/test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt -p 0 -o configs/test5_ota_override_config.txt
Then modifiy the ota config
vim configs/test5_ota_override_config.txt
deepstream-test6.zip (77.2 KB)
sorry for the late reply. could you use gdb to get the crash stack?
here it is:
please refer to section 8 of test5 README. there are some limitation for OTA functionality.
I didn’t use any other models, I just switched the same model but got this error
how did you operate exactly? let me have a try.
just download my example app, I just add nvpreprocess before nvinfer then run app like README and do OTA file modification
nvinfer plugin is opensource. I can reproduce this issue. it is related to if (oldParams.numDetectedClasses){} part code in DsNvInferImpl::initNewInferModelParams. when I removed this part code. the app run fine. will continue to check.
let me know if you have final solution, thank you so much
numDetectedClasses is only for detector and Instance Segmentation model. here is the final solution.
In function DsNvInferImpl::initNewInferModelParams of /opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvinfer/gstnvinfer_impl.cpp, please modify
if (oldParams.numDetectedClasses) {
to
if ((oldParams.networkType == NvDsInferNetworkType_Detector
|| oldParams.networkType == NvDsInferNetworkType_InstanceSegmentation)
&& oldParams.numDetectedClasses) {
then rebuild according to readme, then replace /opt/nvidia/deepstream/deepstream/lib/gst-plugins/libnvdsgst_infer.so with the new so.
thank you so much, I will give a try and respond to you soon
Sorry for the late reply, Is this still an DeepStream issue to support? Thanks!
