Segmentation fault when using different GPUs
I met a weird bug when running Issacgym’s joint_monkey examples. For example, when I specify cuda:0 as the GPU to run the example, everything works well:
However, when I use different GPU like cuda:1 (by seting CUDA_VISIBLE_DEVICES=1), the error happens:
@gstate
Hi @xidong.feng.20
Looks like we might have a problem to track down here with CUDA_VISIBLE_DEVICES. In the meantime, it is better anyways to explicitly specify your sim and/or graphics devices on the command line using:
--sim_device=cuda:n --graphics_device=k
Note that the sim_device parameter uses CUDA style device syntax, while the graphics_device parameter uses the vulkan device ID, which may not always be the same as the CUDA device ID style.
Take care,
-Gav
this helps!
really hard to find solution btw :)
How does the Vulkan ID relate to the GPU ID assigned by CUDA? I’m having a hard time trying to instantiate new renderers on devices that are not CUDA:0 and would appreciate any pointers to relevant documentation. Thanks!
This still doesn’t work for me. Most of the GPU memory is being used on GPU 1 when I specify sim_device=cuda:1 rl_device=cuda:1 graphics_device_id=1, however, some memory is still required on GPU 0. This crashes when GPU 0 is fully utilized, e.g. if tensorflow is running on that GPU. This makes it impossible to run isaac gym on machines shared across multiple users (since someone might be using tensorflow).
Agree. I also found that some memory is taken up on GPU 0, though I specify sim_device=cuda:1 rl_device=cuda:1 graphics_device_id=1.
