Segmentation fault at gym.draw_viewer
I tried to test Isaac Gym by running joint_monkey.py, but it crashed with a segmentation fault.
After debugging the error, I found that the segmentation fault occurs when executing gym.draw_viewer(viewer, sim, True).
My computer has two GPUs, 3090 and 4090, and my environment is python 3.8, nvidia-smi 535.113.01, and CUDA 11.7.
What is causing the segmentation fault?
The printed messages are follows:
Importing module ‘gym_38’ (/home/jmkim/isaacgym/python/isaacgym/_bindings/linux-x86_64/gym_38.so)
Setting GYM_USD_PLUG_INFO_PATH to /home/jmkim/isaacgym/python/isaacgym/_bindings/linux-x86_64/usd/plugInfo.json
WARNING: Forcing CPU pipeline.
Not connected to PVD
+++ Using GPU PhysX
Physics Engine: PhysX
Physics Device: cuda:0
GPU Pipeline: disabled
Loading asset ‘mjcf/nv_humanoid.xml’ from ‘…/…/assets’
DOF 0
Type: Rotation
Stiffness: 20.0
Damping: 5.0
Armature: 0.02
Limited? True
Lower -0.785398
Upper 0.785398
DOF 1
Type: Rotation
Stiffness: 20.0
Damping: 5.0
Armature: 0.01
Limited? True
Lower -1.308997
Upper 0.523599
DOF 2
Type: Rotation
Stiffness: 10.0
Damping: 5.0
Armature: 0.01
Limited? True
Lower -0.610865
Upper 0.610865
DOF 3
Type: Rotation
Stiffness: 10.0
Damping: 5.0
Armature: 0.01
Limited? True
Lower -0.785398
Upper 0.261799
DOF 4
Type: Rotation
Stiffness: 10.0
Damping: 5.0
Armature: 0.01
Limited? True
Lower -1.047198
Upper 0.610865
DOF 5
Type: Rotation
Stiffness: 20.0
Damping: 5.0
Armature: 0.01
Limited? True
Lower -2.094395
Upper 0.785398
DOF 6
Type: Rotation
Stiffness: 5.0
Damping: 0.1
Armature: 0.007
Limited? True
Lower -2.792527
Upper 0.034907
DOF 7
Type: Rotation
Stiffness: 2.0
Damping: 1.0
Armature: 0.006
Limited? True
Lower -0.872665
Upper 0.872665
DOF 8
Type: Rotation
Stiffness: 2.0
Damping: 1.0
Armature: 0.006
Limited? True
Lower -0.872665
Upper 0.872665
DOF 9
Type: Rotation
Stiffness: 10.0
Damping: 5.0
Armature: 0.01
Limited? True
Lower -0.785398
Upper 0.261799
DOF 10
Type: Rotation
Stiffness: 10.0
Damping: 5.0
Armature: 0.01
Limited? True
Lower -1.047198
Upper 0.610865
DOF 11
Type: Rotation
Stiffness: 20.0
Damping: 5.0
Armature: 0.01
Limited? True
Lower -2.094395
Upper 0.785398
DOF 12
Type: Rotation
Stiffness: 5.0
Damping: 0.1
Armature: 0.007
Limited? True
Lower -2.792527
Upper 0.034907
DOF 13
Type: Rotation
Stiffness: 2.0
Damping: 1.0
Armature: 0.006
Limited? True
Lower -0.872665
Upper 0.872665
DOF 14
Type: Rotation
Stiffness: 2.0
Damping: 1.0
Armature: 0.006
Limited? True
Lower -0.872665
Upper 0.872665
DOF 15
Type: Rotation
Stiffness: 10.0
Damping: 5.0
Armature: 0.01
Limited? True
Lower -1.570796
Upper 1.221731
DOF 16
Type: Rotation
Stiffness: 10.0
Damping: 5.0
Armature: 0.01
Limited? True
Lower -1.570796
Upper 1.221731
DOF 17
Type: Rotation
Stiffness: 2.0
Damping: 1.0
Armature: 0.006
Limited? True
Lower -1.570796
Upper 0.872665
DOF 18
Type: Rotation
Stiffness: 10.0
Damping: 5.0
Armature: 0.01
Limited? True
Lower -1.570796
Upper 1.221731
DOF 19
Type: Rotation
Stiffness: 10.0
Damping: 5.0
Armature: 0.01
Limited? True
Lower -1.570796
Upper 1.221731
DOF 20
Type: Rotation
Stiffness: 2.0
Damping: 1.0
Armature: 0.006
Limited? True
Lower -1.570796
Upper 0.872665
Creating 36 environments
Animating DOF 0 (‘abdomen_z’)
Same problem?Have you solved?
Same problem! Have you solved?
Hi, same problem here, but I solved it by using:
export VK_ICD_FILENAMES=/etc/vulkan/icd.d/nvidia_icd.json
or
export VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/nvidia_icd.json.
However, please make sure you have already installed the Vulkan.
These two links may helpful: Running Examples Hangs and Isaac Gym Black window missing nvidia_icd.json Segmentation fault
