I’m able to run most of the examples with the PhysX engine (both, physx and physx_gpu options work). However, when using flex, I get a Segmentation fault error. For example, when running python soft_body.py --flex
, I get the following error:
Importing module ‘gym_37’ (/home/aa/isaacgym/python/isaacgym/_bindings/linux-x86_64/gym_37.so)
Setting GYM_USD_PLUG_INFO_PATH to /home/aa/isaacgym/python/isaacgym/_bindings/linux-x86_64/usd/plugInfo.json
Loading asset ‘urdf/icosphere.urdf’ from ‘…/…/assets’
Soft Material Properties:
(Body 0) youngs: 100000.0 poissons: 0.44999998807907104 damping: 0.0
Creating 1 environments
I followed all the instructions for installation in a conda environment (including the troubleshooting section in the documentation). On running vulkaninfo, I get the following output for VkPhysicalDeviceDriverProperties:
driverID = DRIVER_ID_NVIDIA_PROPRIETARY
driverName = NVIDIA
driverInfo = 460.32.03
conformanceVersion = 1.2.4.0
I’m running this on Ubuntu 20.04 with an RTX 3080 and CUDA version 11.2. I’ve also tried running this on Ubuntu 18.04 with a laptop GTX 1060 and that works perfectly fine.
Would appreciate any help troubleshooting this.
Thank you,
Ayush
