I am running Isaac Gym on my Lenovo P1 with a Quadro P2000 laptop GPU. It would run the examples at full speed and render everything properly. All of a sudden, nothing would run at full speed anymore and all of the text is unable to render, the ground plane does not render. The simulation can only run for a few seconds and then crashes. I didn’t change anything and I’m not sure how to debug. The output is the same as it was before. Here is an example of how Isaac Gym looks now, and example output (not from same run)
(rlgpu) dave@dave:~/isaacgym/python/examples$ python joint_monkey.py --asset_id 1
Importing module 'gym_37' (/home/dave/anaconda3/envs/rlgpu/lib/python3.7/site-packages/isaacgym/_bindings/linux-x86_64/gym_37.so)
Setting GYM_USD_PLUG_INFO_PATH to /home/dave/anaconda3/envs/rlgpu/lib/python3.7/site-packages/isaacgym/_bindings/linux-x86_64/usd/plugInfo.json
WARNING: Forcing CPU pipeline.
Not connected to PVD
+++ Using GPU PhysX
Physics Engine: PhysX
Physics Device: cuda:0
GPU Pipeline: disabled
WARNING: lavapipe is not a conformant vulkan implementation, testing use only.
Loading asset 'mjcf/nv_ant.xml' from '../../assets'
DOF 0
Type: Rotation
Stiffness: 0.0
Damping: 0.1
Armature: 0.01
Limited? True
Lower -0.698132
Upper 0.698132
DOF 1
Type: Rotation
Stiffness: 0.0
Damping: 0.1
Armature: 0.01
Limited? True
Lower 0.523599
Upper 1.745329
DOF 2
Type: Rotation
Stiffness: 0.0
Damping: 0.1
Armature: 0.01
Limited? True
Lower -0.698132
Upper 0.698132
DOF 3
Type: Rotation
Stiffness: 0.0
Damping: 0.1
Armature: 0.01
Limited? True
Lower -1.745329
Upper -0.523599
DOF 4
Type: Rotation
Stiffness: 0.0
Damping: 0.1
Armature: 0.01
Limited? True
Lower -0.698132
Upper 0.698132
DOF 5
Type: Rotation
Stiffness: 0.0
Damping: 0.1
Armature: 0.01
Limited? True
Lower -1.745329
Upper -0.523599
DOF 6
Type: Rotation
Stiffness: 0.0
Damping: 0.1
Armature: 0.01
Limited? True
Lower -0.698132
Upper 0.698132
DOF 7
Type: Rotation
Stiffness: 0.0
Damping: 0.1
Armature: 0.01
Limited? True
Lower 0.523599
Upper 1.745329
Creating 2 environments
Animating DOF 0 ('hip_1')
