Segmentation Fault while using ROS melodic for Inferencing using TensorRT on Jetson Nano
Hello everyone,
I am currently working on a project using a Jetson Nano where I am trying to perform inference using TensorRT (Yolov5 object detection) in a ROS (Melodic) node. I have encountered a Bus Error(Core dumped) / segmentation fault (core dumped), which seems to arise from a memory conflict between ROS and TensorRT. I am seeking advice or solutions from anyone who might have faced and resolved a similar issue.
I have provided the code to my inference node below. I would greatly appreciate any insights, suggestions, or solutions.
Environment Details:
Jetpack Version: 4.6.
ROS Version: ROS Melodic
TensorRT Version: 8.2.1.8
PyCUDA: 2019.1.2
Torch version: 1.10.0
CUDA: 10.2
#!/usr/bin/env python3
import rospy
from sensor_msgs.msg import Image
from std_msgs.msg import String
import json
import cv2
import imutils
from cv_bridge import CvBridge, CvBridgeError
import numpy as np
import tensorrt as trt
import pycuda.autoinit
import random
import ctypes
import pycuda.driver as cuda
import time
import multiprocessing as mp
import threading
EXPLICIT_BATCH = 1 << (int)(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
host_inputs  = []
cuda_inputs  = []
host_outputs = []
cuda_outputs = []
bindings = []
class YoloTRT():
    def __init__(self, library, engine, conf, yolo_ver):
        print("Initiating Engine")
        self.CONF_THRESH = conf
        self.IOU_THRESHOLD = 0.4
        self.LEN_ALL_RESULT = 38001
        self.LEN_ONE_RESULT = 38
        self.yolo_version = yolo_ver
        self.categories = ["pedestrian", "people", "bicycle", "car", "van", "truck", "tricycle", "awning-tricycle", "bus", "motor"]
        TRT_LOGGER = trt.Logger(trt.Logger.INFO)
        ctypes.CDLL(library)
        with open(engine, 'rb') as f:
            serialized_engine = f.read()
        runtime = trt.Runtime(TRT_LOGGER)
        self.engine = runtime.deserialize_cuda_engine(serialized_engine)
        self.batch_size = self.engine.max_batch_size
        for binding in self.engine:
            size = trt.volume(self.engine.get_binding_shape(binding)) * self.batch_size
            dtype = trt.nptype(self.engine.get_binding_dtype(binding))
            host_mem = cuda.pagelocked_empty(size, dtype)
            cuda_mem = cuda.mem_alloc(host_mem.nbytes)
            bindings.append(int(cuda_mem))
            if self.engine.binding_is_input(binding):
                self.input_w = self.engine.get_binding_shape(binding)[-1]
                self.input_h = self.engine.get_binding_shape(binding)[-2]
                host_inputs.append(host_mem)
                cuda_inputs.append(cuda_mem)
            else:
                host_outputs.append(host_mem)
                cuda_outputs.append(cuda_mem)
        print("Done Initializing Engine")
    def PreProcessImg(self, img):
        image_raw = img
        h, w, c = image_raw.shape
        image = cv2.cvtColor(image_raw, cv2.COLOR_BGR2RGB)
        r_w = self.input_w / w
        r_h = self.input_h / h
        if r_h > r_w:
            tw = self.input_w
            th = int(r_w * h)
            tx1 = tx2 = 0
            ty1 = int((self.input_h - th) / 2)
            ty2 = self.input_h - th - ty1
        else:
            tw = int(r_h * w)
            th = self.input_h
            tx1 = int((self.input_w - tw) / 2)
            tx2 = self.input_w - tw - tx1
            ty1 = ty2 = 0
        image = cv2.resize(image, (tw, th))
        image = cv2.copyMakeBorder(image, ty1, ty2, tx1, tx2, cv2.BORDER_CONSTANT, None, (128, 128, 128))
        image = image.astype(np.float32)
        image /= 255.0
        image = np.transpose(image, [2, 0, 1])
        image = np.expand_dims(image, axis=0)
        image = np.ascontiguousarray(image)
        return image, image_raw, h, w
    def Inference(self, img):
        input_image, image_raw, origin_h, origin_w = self.PreProcessImg(img)
        np.copyto(host_inputs[0], input_image.ravel())
        stream = cuda.Stream()
        self.context = self.engine.create_execution_context()
        cuda.memcpy_htod_async(cuda_inputs[0], host_inputs[0], stream)
        t1 = time.time()
        self.context.execute_async(self.batch_size, bindings, stream_handle=stream.handle)
        cuda.memcpy_dtoh_async(host_outputs[0], cuda_outputs[0], stream)
        stream.synchronize()
        t2 = time.time()
        output = host_outputs[0]
        for i in range(self.batch_size):
            result_boxes, result_scores, result_classid = self.PostProcess(output[i * self.LEN_ALL_RESULT: (i + 1) * self.LEN_ALL_RESULT], origin_h, origin_w)
        det_res = []
        for j in range(len(result_boxes)):
            box = result_boxes[j]
            det = dict()
            det["class"] = self.categories[int(result_classid[j])]
            det["conf"] = result_scores[j]
            det["box"] = box
            det_res.append(det)
            self.PlotBbox(box, img, label="{}:{:.2f}".format(self.categories[int(result_classid[j])], result_scores[j]),)
        return det_res, t2-t1
    def PostProcess(self, output, origin_h, origin_w):
        num = int(output[0])
        if self.yolo_version == "v5":
            pred = np.reshape(output[1:], (-1, self.LEN_ONE_RESULT))[:num, :]
            pred = pred[:, :6]
        elif self.yolo_version == "v7":
            pred = np.reshape(output[1:], (-1, 6))[:num, :]
        boxes = self.NonMaxSuppression(pred, origin_h, origin_w, conf_thres=self.CONF_THRESH, nms_thres=self.IOU_THRESHOLD)
        result_boxes = boxes[:, :4] if len(boxes) else np.array([])
        result_scores = boxes[:, 4] if len(boxes) else np.array([])
        result_classid = boxes[:, 5] if len(boxes) else np.array([])
        return result_boxes, result_scores, result_classid
    def NonMaxSuppression(self, prediction, origin_h, origin_w, conf_thres=0.5, nms_thres=0.4):
        boxes = prediction[prediction[:, 4] >= conf_thres]
        boxes[:, :4] = self.xywh2xyxy(origin_h, origin_w, boxes[:, :4])
        boxes[:, 0] = np.clip(boxes[:, 0], 0, origin_w -1)
        boxes[:, 2] = np.clip(boxes[:, 2], 0, origin_w -1)
        boxes[:, 1] = np.clip(boxes[:, 1], 0, origin_h -1)
        boxes[:, 3] = np.clip(boxes[:, 3], 0, origin_h -1)
        confs = boxes[:, 4]
        boxes = boxes[np.argsort(-confs)]
        keep_boxes = []
        while boxes.shape[0]:
            large_overlap = self.bbox_iou(np.expand_dims(boxes[0, :4], 0), boxes[:, :4]) > nms_thres
            label_match = boxes[0, -1] == boxes[:, -1]
            # Indices of boxes with lower confidence scores, large IOUs and matching labels
            invalid = large_overlap & label_match
            keep_boxes += [boxes[0]]
            boxes = boxes[~invalid]
        boxes = np.stack(keep_boxes, 0) if len(keep_boxes) else np.array([])
        return boxes
    def xywh2xyxy(self, origin_h, origin_w, x):
        y = np.zeros_like(x)
        r_w = self.input_w / origin_w
        r_h = self.input_h / origin_h
        if r_h > r_w:
            y[:, 0] = x[:, 0] - x[:, 2] / 2
            y[:, 2] = x[:, 0] + x[:, 2] / 2
            y[:, 1] = x[:, 1] - x[:, 3] / 2 - (self.input_h - r_w * origin_h) / 2
            y[:, 3] = x[:, 1] + x[:, 3] / 2 - (self.input_h - r_w * origin_h) / 2
            y /= r_w
        else:
            y[:, 0] = x[:, 0] - x[:, 2] / 2 - (self.input_w - r_h * origin_w) / 2
            y[:, 2] = x[:, 0] + x[:, 2] / 2 - (self.input_w - r_h * origin_w) / 2
            y /= r_h
        return y
    def bbox_iou(self, box1, box2, x1y1x2y2=True):
        if not x1y1x2y2:
            # Transform from center and width to exact coordinates
            b1_x1, b1_x2 = box1[:, 0] - box1[:, 2] / 2, box1[:, 0] + box1[:, 2] / 2
            b1_y1, b1_y2 = box1[:, 1] - box1[:, 3] / 2, box1[:, 1] + box1[:, 3] / 2
            b2_x1, b2_x2 = box2[:, 0] - box2[:, 2] / 2, box2[:, 0] + box2[:, 2] / 2
            b2_y1, b2_y2 = box2[:, 1] - box2[:, 3] / 2, box2[:, 1] + box2[:, 3] / 2
        else:
            # Get the coordinates of bounding boxes
            b1_x1, b1_y1, b1_x2, b1_y2 = box1[:, 0], box1[:, 1], box1[:, 2], box1[:, 3]
            b2_x1, b2_y1, b2_x2, b2_y2 = box2[:, 0], box2[:, 1], box2[:, 2], box2[:, 3]
        inter_rect_x1 = np.maximum(b1_x1, b2_x1)
        inter_rect_y1 = np.maximum(b1_y1, b2_y1)
        inter_rect_x2 = np.minimum(b1_x2, b2_x2)
        inter_rect_y2 = np.minimum(b1_y2, b2_y2)
        inter_area = np.clip(inter_rect_x2 - inter_rect_x1 + 1, 0, None) * \
                     np.clip(inter_rect_y2 - inter_rect_y1 + 1, 0, None)
        b1_area = (b1_x2 - b1_x1 + 1) * (b1_y2 - b1_y1 + 1)
        b2_area = (b2_x2 - b2_x1 + 1) * (b2_y2 - b2_y1 + 1)
        iou = inter_area / (b1_area + b2_area - inter_area + 1e-16)
        return iou
    def PlotBbox(self, x, img, color=None, label=None, line_thickness=None):
        tl = (line_thickness or round(0.002 * (img.shape[0] + img.shape[1]) / 2) + 1)  # line/font thickness
        color = color or [random.randint(0, 255) for _ in range(3)]
        c1, c2 = (int(x[0]), int(x[1])), (int(x[2]), int(x[3]))
        cv2.rectangle(img, c1, c2, color, thickness=tl, lineType=cv2.LINE_AA)
        if label:
            tf = max(tl - 1, 1)  # font thickness
            t_size = cv2.getTextSize(label, 0, fontScale=tl / 3, thickness=tf)[0]
            c2 = c1[0] + t_size[0], c1[1] - t_size[1] - 3
            cv2.rectangle(img, c1, c2, color, -1, cv2.LINE_AA)  # filled
            cv2.putText(img, label, (c1[0], c1[1] - 2), 0, tl / 3, [225, 255, 255], thickness=tf, lineType=cv2.LINE_AA,)
def process_image(yolo):
    bridge = CvBridge()
    while not rospy.is_shutdown():
        try:
            data = rospy.wait_for_message("/camera/image_raw", Image, timeout=None)
            cv_image = bridge.imgmsg_to_cv2(data, "bgr8")
            cv_image = imutils.resize(cv_image, width=1504)
            detections, _ = yolo.Inference(cv_image)
            relevant_detections = [det for det in detections if det['class'] in ['pedestrian', 'people']]
            if relevant_detections:
                detection_pub.publish(json.dumps(relevant_detections))
        except CvBridgeError as e:
            print(e)
if __name__ == '__main__':
    mp.set_start_method('spawn')
    print("Init ROS Node")
    #rospy.init_node('yolo_image_processor', anonymous=True)
    print("ROS Node init done")
    detection_pub = rospy.Publisher("/detections", String, queue_size=10)
    print("Calling YOLO wrapper")
    yolo = YoloTRT(library="path/to/libmyplugins.so", engine="path/to/yolov5s.engine", conf=0.5, yolo_ver="v5")
    print("Yolo Wrapper initialized")
    try:
        process_image(yolo)
    except KeyboardInterrupt:
        print("Shutting down YoloTRT Node")
@dusty_nv @AastaLLL
Bus error is usually caused by the concurrent access to the buffer.
Jetson doesn’t support concurrent access (read a buffer with CPU and GPU at the same time).
Please check your implementation to make sure synchronize is added accordingly.
Thanks for the reply. The bus error is thrown as soon as I import pycuda.autoinit. The code does not even enter the main function. Can you please guide me on how I could snychronize my implementation in this case?
@AastaLLL Even I am facing similar issues while trying to encapsulate my YOLOv5 object detection model in a ROS node. This issue gave me a deeper understanding of what the problem is. I am publishing camera images on a ROS topic. I want my YOLOv5 node to subscribe the published images and perform object detection. I am facing the same bus error (core dumped). Somewhat clarification on what is the share resource that ROS and pycuda.autoinit are trying to access and how to synchronize this access in this regard would be great.
Also @dusty_nv 's, I have been following your jetson-inference and ros_deep_learning repositories. It seems like you were successfully run inference using tensorRT engine in a ROS node. Did you face similar problems? How did you solve it?
Hi @jeetsuperstar, no sorry I didn’t face similar issue. In my case I was using roscpp and jetson-inference (which I already knew to be working on its own). You could try YoloTRT class first on it’s own, from an image file. Does it still make the error? If so, deduce what is causing it by using gdb or adding print statements, commenting stuff out, ect.
