segnet-camera: failed to initialize imageNet
Hello
Seeing same on fresh install on jetson nano -
michael@dizzyneuron:~/jetson-inference/build/aarch64/bin$ ./segnet-camera
[gstreamer] initialized gstreamer, version 1.14.4.0
[gstreamer] gstCamera attempting to initialize with GST_SOURCE_NVARGUS, camera 0
[gstreamer] gstCamera pipeline string:
nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=30/1, format=(string)NV12 ! nvvidconv flip-method=2 ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera successfully initialized with GST_SOURCE_NVARGUS, camera 0
segnet-camera: successfully initialized camera device
width: 1280
height: 720
depth: 12 (bpp)
segNet – loading segmentation network model from:
– prototxt: networks/FCN-Alexnet-Cityscapes-SD/deploy.prototxt
– model: networks/FCN-Alexnet-Cityscapes-SD/snapshot_iter_114860.caffemodel
– labels: networks/FCN-Alexnet-Cityscapes-SD/cityscapes-labels.txt
– colors: networks/FCN-Alexnet-Cityscapes-SD/cityscapes-deploy-colors.txt
– input_blob ‘data’
– output_blob ‘score_fr_21classes’
– batch_size 1
[TRT] TensorRT version 5.1.6
[TRT] loading NVIDIA plugins…
[TRT] Plugin Creator registration succeeded - GridAnchor_TRT
[TRT] Plugin Creator registration succeeded - NMS_TRT
[TRT] Plugin Creator registration succeeded - Reorg_TRT
[TRT] Plugin Creator registration succeeded - Region_TRT
[TRT] Plugin Creator registration succeeded - Clip_TRT
[TRT] Plugin Creator registration succeeded - LReLU_TRT
[TRT] Plugin Creator registration succeeded - PriorBox_TRT
[TRT] Plugin Creator registration succeeded - Normalize_TRT
[TRT] Plugin Creator registration succeeded - RPROI_TRT
[TRT] Plugin Creator registration succeeded - BatchedNMS_TRT
[TRT] completed loading NVIDIA plugins.
[TRT] detected model format - caffe (extension ‘.caffemodel’)
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file .1.1.GPU.FP16.engine
[TRT] cache file not found, profiling network model on device GPU
error: model file ‘networks/FCN-Alexnet-Cityscapes-SD/snapshot_iter_114860.caffemodel’ was not found.
if loading a built-in model, maybe it wasn’t downloaded before.
Run the Model Downloader tool again and select it for download:
$ cd /tools
$ ./download-models.sh
segNet – failed to initialize.
I believe problem is that the actual file is snapshot_iter_2756640.caffemodel. But am unable to find where to change.
Cheers, Michael
Hi Michael, can you try updating the model filename in this line of code?
[url]jetson-inference/segNet.cpp at 99ecf1f41b47b6d4f8fb848963f4c6517cfa82c3 · dusty-nv/jetson-inference · GitHub
Let me know if that works for you - thanks.
Dusty
Thank you that worked.
Cheers, Michael
