Separate Power module
I have designed the carrier board based on the P3768-A04 Jetson Orin NX reference schematic. However, the power IC is not switching. During debugging, I found that the issue appears to be related to the power section layout design.
Would it be possible to design the 5V and 3.3V power sections as separate modules and connect them to the main board through test points?
Could you share more details about your proposed setup, including a schematic or block diagram showing the external 5V and 3.3V supplies and the test points you plan to connect them to?
Please also explain how the external supplies would be isolated from the existing power circuitry and how you plan to maintain the power-up and power-down sequencing requirements in the Jetson Orin NX Series and Orin Nano Series Design Guide.
