is there a way how to set empty output buffer?
If I have in shader program
rtBuffer<float4, 2> output_buffer;
then I must set it from program, because otherwise I got an error when optix validate.
Calling program[“output_buffer”]->setBuffer(NULL); causes program crash.
I need multiple output buffers, but no everytime, something like:
if (isColor)
color_buffer[index] = color;
if (isNormal)
normal_buffer[index] = normal;
I found some solution with callable programs. So I create callable program for each output buffer and set this buffer into it.
However this solution have two problems:
- I must have callable program for each buffer (is there a way how to copy optix::Buffer to avoid compile it for each buffer?)
- When I don’t need this buffer and I remove it, I must remove also this callable program.
Is there other way how to do this?
