Hi
For a couple of weeks and through several different project setups, I have constantly run into the same bug over and over when running this basic program:
#include <optix_world.h>
#include <optixu/optixu_math_namespace.h>
using namespace optix;
rtBuffer<float4, 2> output_buffer;
rtDeclareVariable(uint2, launch_index, rtLaunchIndex, );
rtDeclareVariable(float4, bg_colour, , );
RT_PROGRAM void pinhole_camera()
output_buffer[launch_index] = bg_colour;
According to the compiler everything compiles fine, however at runtime it spits out this error:
OptiX Error: Parse error (Details: Function “_rtProgramCreateFromPTXFile” caught exception: Can’t find definition of buffer for instruction: call (%rd20), _rt_buffer_get_64, (%rd21, %r7, %r8, %rd22, %rd23, %rd24, %rd25);, [5571728])
I have tried using different many different compiler setting, changing the host program to C++, copying properties directly from the samples, and copying files directly from the wizard example, but this error will not go away. Any help in either pointing me in the right direction or explaining what I may be doing wrong is greatly appreciated.
