Setting RDMA Type of Service with DOCA
I recently noticed that MLNX_OFED is being deprecated in favor of DOCA(-OFED). I am testing switching over to DOCA-OFED for our cluster.
We use RoCEv2 and have some dedicated lossless queues set up on our switches. To select the correct queue for RDMA traffic, I set the Type of service (TOS) of the appropriate interface to 26.
Previously, with MOFED, I was able to do this by simply echoing the calculated TOS to a magic file in the interface:
TC="/sys/class/infiniband/$MLNX_INT/tc/1/traffic_class"
echo 106 > "$TC"
With DOCA, this tc folder doesn’t exist under /sys/class/infiniband/$MLNX_INT/. Is there an alternative way to set the TOS of an interface with DOCA?
I was unable to find anything in the transition guide.
Hi @jarulsamy,
How did you install DOCA-OFED on your system?
I’m working with a dual-port ConnectX-6 DX NIC and have DOCA-OFED version 2.9.1 installed (2.9.1-018000-24.10-ubuntu2404).
I can access and modify this file.
# echo 106 > /sys/class/infiniband/mlx5_0/tc/1/traffic_class
# cat /sys/class/infiniband/mlx5_0/tc/1/traffic_class
Global tclass=106
Thanks,
Chen
Hi @chenh1,
I used the upstream RPM from https://linux.mellanox.com/public/repo/doca/2.9.0/rhel9.3/x86_64/
I installed with:
dnf install -y doca-ofed kmod-mlnx-nfsrdma
