I want to use Optix via Nsight since I’m using a Linux system. Unfortunately, I couldn’t find much information about including Optix to Nsight and I’m not really experienced in C/C++. Here is what I did until now:
- added path of 'include' and 'include/optixu' to Properties>Settings>Tool Settings>Includes
- unchecked all boxes in Properties>Settings>Tool Settings>Debug
- Properties>Settings>Tool Settings>Libraries: added 'libopitx' and 'liboptixu' to -l and the path to 'lib64' to -L
- added path to 'lib64' to LD_LIBRARY_PATH and CLASSPATH
I tested it on the first part of the tutorial, but now I’m ending up with this error message:
make all
Building file: ../src/box.cu
Invoking: NVCC Compiler
/usr/local/cuda-8.0/bin/nvcc -I/home/nburkard/Downloads/NVIDIA-OptiX-SDK-5.0.0-linux64/include -I/home/nburkard/Downloads/NVIDIA-OptiX-SDK-5.0.0-linux64/include/optixu -O0 -gencode arch=compute_20,code=sm_20 -odir "src" -M -o "src/box.d" "../src/box.cu"
nvcc warning : The 'compute_20', 'sm_20', and 'sm_21' architectures are deprecated, and may be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
/usr/local/cuda-8.0/bin/nvcc -I/home/nburkard/Downloads/NVIDIA-OptiX-SDK-5.0.0-linux64/include -I/home/nburkard/Downloads/NVIDIA-OptiX-SDK-5.0.0-linux64/include/optixu -O0 --compile --relocatable-device-code=false -gencode arch=compute_20,code=compute_20 -gencode arch=compute_20,code=sm_20 -x cu -o "src/box.o" "../src/box.cu"
ptxas /tmp/tmpxft_000014e9_00000000-6_box.ptx, line 131; error : Label expected for argument 0 of instruction 'call'
ptxas /tmp/tmpxft_000014e9_00000000-6_box.ptx, line 131; error : Call target not recognized
ptxas /tmp/tmpxft_000014e9_00000000-6_box.ptx, line 131; error : Function '_rt_potential_intersection' not declared in this scope
ptxas /tmp/tmpxft_000014e9_00000000-6_box.ptx, line 160; error : Label expected for argument 0 of instruction 'call'
ptxas /tmp/tmpxft_000014e9_00000000-6_box.ptx, line 160; error : Call target not recognized
ptxas /tmp/tmpxft_000014e9_00000000-6_box.ptx, line 160; error : Function '_rt_report_intersection' not declared in this scope
src/subdir.mk:34: recipe for target 'src/box.o' failed
ptxas /tmp/tmpxft_000014e9_00000000-6_box.ptx, line 167; error : Label expected for argument 0 of instruction 'call'
ptxas /tmp/tmpxft_000014e9_00000000-6_box.ptx, line 167; error : Call target not recognized
ptxas /tmp/tmpxft_000014e9_00000000-6_box.ptx, line 167; error : Function '_rt_potential_intersection' not declared in this scope
ptxas /tmp/tmpxft_000014e9_00000000-6_box.ptx, line 196; error : Label expected for argument 0 of instruction 'call'
ptxas /tmp/tmpxft_000014e9_00000000-6_box.ptx, line 196; error : Call target not recognized
ptxas /tmp/tmpxft_000014e9_00000000-6_box.ptx, line 196; error : Function '_rt_report_intersection' not declared in this scope
ptxas /tmp/tmpxft_000014e9_00000000-6_box.ptx, line 131; error : Unknown symbol '_rt_potential_intersection'
ptxas /tmp/tmpxft_000014e9_00000000-6_box.ptx, line 131; fatal : Label expected for forward reference of '_rt_potential_intersection'
ptxas fatal : Ptx assembly aborted due to errors
make: *** [src/box.o] Error 255
Any help would be really appreciated!
