SFT init failed
When I was trying to run the doca url filter on host through vf.
The Trouble shooting give suggestion this error below may be relevant to too many cores.
sudo ./doca_url_filter -a 01:00.0 -a 0000:01:00.3 -a 0000:01:00.4 -l 0,1 – -p
[sudo] password for egaoyuc:
EAL: Detected 56 lcore(s)
EAL: Detected 2 NUMA nodes
EAL: Detected shared linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode ‘VA’
EAL: 2048 hugepages of size 2097152 reserved, but no mounted hugetlbfs found for that size
EAL: Probing VFIO support…
EAL: VFIO support initialized
EAL: Probe PCI driver: mlx5_pci (15b3:a2d6) device: 0000:01:00.0 (socket 0)
EAL: Probe PCI driver: mlx5_pci (15b3:101e) device: 0000:01:00.3 (socket 0)
EAL: Probe PCI driver: mlx5_pci (15b3:101e) device: 0000:01:00.4 (socket 0)
EAL: No legacy callbacks, legacy socket not created
port-0: SFT init failed err=-12
[11:49:25:811302][DOCA][ERR][NUTILS:286]: SFT init failed, ret=-12
But when I do this -l 0
sudo ./doca_url_filter -a 01:00.0 -a 0000:01:00.3 -a 0000:01:00.4 -l 0 – -p
[11:54:06:051766][DOCA][ERR][NUTILS:622]: At least 2 cores are needed for the application to run, available_cores=1
[11:54:06:051794][DOCA][ERR][URL_FILTER:275]: Failed to update application ports and queues: DOCA Driver call failure
It suggests this way. Can anyone help?
After trying, I set the running command as :
./doca_url_filter -a 0000:01:00.3,class=regex:eth,representor=[196609],sft_en=0 -a 0000:01:00.4,class=regex:eth,representor=[196610],sft_en=0 -l 0-7 – -p
And now the new error is :
Help please!
