Hello, i just want to configure simple VXLAN connection between two switches running Nivida Onyx 3.10.2002.
one VTEP interface on each switch, and want to map just on VLAN to one vni, L2 bridge, in cumulus Linux it is easy, on Onyx i have to set the interface nve to nve controller bgp mode to map to a vni to a specific vlan, is that correct?
the other command i found nve vlan bridge requires the ethernet interface to set to nve mody only, that not what i want. Is this nve controller bgp mode a must on the nve interface to map a VLAN to a VNI?
Here attached the chapter of ONYX User Guide for your reference to configure VxLAN.
Please kindly be noted, ONYX support will end at the end of 2025. After that only Cumulus Linux will be supported.
