I’m trying to install CUDA sdk on Slackware Linux, using: cuda_6.5.14_linux_64.run. But the installer complains about not enoug space on the device. Here is the full listing:
Do you accept the previously read EULA? (accept/decline/quit): accept
You are attempting to install on an unsupported configuration. Do you wish to continue? ((y)es/(n)o) [ default is no ]: y
Install the CUDA 6.5 Toolkit? ((y)es/(n)o/(q)uit): y
Enter Toolkit Location [ default is /usr/local/cuda-6.5 ]:
Do you want to install a symbolic link at /usr/local/cuda? ((y)es/(n)o/(q)uit):
Do you want to install a symbolic link at /usr/local/cuda? ((y)es/(n)o/(q)uit): y
Install the CUDA 6.5 Samples? ((y)es/(n)o/(q)uit): y
Enter CUDA Samples Location [ default is /home/ghi ]:
Not enough space on parition mounted at /.
Need 1563279360 bytes.
Disk space check has failed. Installation cannot continue.
The result of df command:
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda1 19097204 16179016 1925056 90% /
/dev/sda3 9483076 979028 7999288 11% /usr/local
/dev/sda2 432423184 137239116 273195184 34% /home
tmpfs 2019108 0 2019108 0% /dev/shm
Any suggestions?
