• Hardware Platform (Jetson / GPU) 4090
• DeepStream Version 7.0
• TensorRT Version
import os
import numpy as np
import tensorrt as trt
import pycuda.driver as cuda
import pycuda.autoinit
import triton_python_backend_utils as pb_utils
import torch
import torchvision.ops as ops
import cv2
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
class TritonPythonModel:
def initialize(self, args):
self.logger = pb_utils.Logger
def execute(self, requests):
responses = []
for request in requests:
try:
in_tensor = pb_utils.get_input_tensor_by_name(request, "INPUT0")
input_data = in_tensor.as_numpy() # (B, 3, H, W), float32, RGB [0-255]
B = input_data.shape[0]
orig_shapes = []
original_images_rgb = []
images_rgb_for_yolox = []
for i in range(B):
img_chw = input_data[i] # (3, H, W)
img_hwc = np.transpose(img_chw, (1, 2, 0)) # (H, W, 3), RGB
original_images_rgb.append(img_hwc.copy())
images_rgb_for_yolox.append(img_hwc)
orig_shapes.append(img_hwc.shape)
# 🖼️ SAVE INPUT IMAGE (RGB) for debugging
# Input is RGB float32 [0-255] → convert to uint8
img_uint8 = img_hwc.astype(np.uint8) # Still RGB!
# OpenCV saves in BGR, so convert RGB → BGR
img_bgr = cv2.cvtColor(img_uint8, cv2.COLOR_RGB2BGR)
save_path = f"/saved/{self.save_count}.jpg"
cv2.imwrite(save_path, img_bgr)
self.save_count += 1
def finalize(self):
self.stream.synchronize()
self.logger.log_info("✅ YOLOX+ReID CPU backend finalized.")
import cv2
import numpy as np
import tritonclient.http as httpclient
def get_frame_from_video(cap, frame_id, one_based=False):
"""Đọc frame thứ frame_id từ video."""
if one_based:
frame_id = frame_id - 1
cap.set(cv2.CAP_PROP_POS_FRAMES, frame_id)
ret, frame = cap.read()
if not ret:
raise ValueError(f"Không đọc được frame {frame_id}")
return frame
def main():
# ---- Cấu hình ----
reid_file = "/ssd1/lelong/pytorch/AI_CITY/PoseTrack/result/reid/scene_094/camera_0961.npy"
bbox_file = "/ssd1/lelong/pytorch/AI_CITY/PoseTrack/result/detection/scene_094/camera_0961.txt"
video_path = "/ssd1/lelong/pytorch/AI_CITY/PoseTrack/dataset/test/scene_094/camera_0961/video.mp4"
triton_url = "192.168.1.90:32000"
model_name = "yolox_reid_ensemble" # Model ensemble đã triển khai
# ---- Load dữ liệu ----
reid_feats_saved = np.load(reid_file, mmap_mode="r") # (N, D)
detections = read_detections(bbox_file)
cap = cv2.VideoCapture(video_path)
# ---- Chọn 1 mẫu để test ----
idx = 2
frame_id, gt_bbox, conf = detections[idx]
feat_saved = reid_feats_saved[idx] # (D,)
# Lấy frame full (frame_id trong file là 1-based hay 0-based?)
# Giả sử file txt dùng 1-based → chuyển sang 0-based
frame = get_frame_from_video(cap, frame_id, one_based=False)
# Chuẩn bị input cho ensemble: (1, 3, H, W), FP32 [0-255]
input_data = np.expand_dims(np.transpose(frame[:, :, ::-1], (2, 0, 1)), axis=0).astype(np.float32)
# Gửi tới Triton ensemble
triton_client = httpclient.InferenceServerClient(url=triton_url)
input_tensor = httpclient.InferInput("INPUT0", input_data.shape, "FP32")
input_tensor.set_data_from_numpy(input_data)
outputs = [
httpclient.InferRequestedOutput("OUTPUT0"),
httpclient.InferRequestedOutput("REID_EMBEDDINGS")
try:
result = triton_client.infer(model_name=model_name, inputs=[input_tensor], outputs=outputs)
dets = result.as_numpy("OUTPUT0")[0] # (N, 6)
reids = result.as_numpy("REID_EMBEDDINGS")[0] # (N, D)
except Exception as e:
print("❌ Lỗi khi gọi model ensemble:")
print(e)
cap.release()
return
if __name__ == "__main__":
main()
Above is the Triton HTTP and Python backend code I use to save images (the input image is in RGB, C, H, W format).
import os
import numpy as np
import torch
import cupy as cp
from torchvision.ops import roi_align
import cv2 # <-- Thêm để lưu ảnh
responses = []
try:
input_dlpack = in_tensor.to_dlpack()
input_torch = torch.from_dlpack(input_dlpack)
if not input_torch.is_cuda:
input_torch = input_torch.cuda()
# Ensure input is float32 in [0, 255]
if input_torch.dtype == torch.uint8:
input_torch = input_torch.float()
elif input_torch.dtype == torch.float32:
if input_torch.max() <= 1.0:
input_torch = input_torch * 255.0
else:
B = input_torch.shape[0]
if not (1 <= B <= self.max_batch_size):
raise ValueError(f"Batch size must be 1–{self.max_batch_size}, got {B}")
# 🔥 CRITICAL: DeepStream sends RGB → convert to BGR for YOLOX
input_torch_bgr = input_torch.clone()
input_torch_bgr[:, [0, 2], :, :] = input_torch_bgr[:, [2, 0], :, :] # RGB → BGR
orig_shapes = [(input_torch[i].shape[1], input_torch[i].shape[2]) for i in range(B)]
# Keep original RGB for ReID!
original_images_rgb = [input_torch[i] for i in range(B)]
# 🔽 DEBUG: Save ALL original RGB images as BGR (for correct OpenCV display) 🔽
for img_rgb in original_images_rgb:
# img_rgb: (3, H, W), float32, [0,255], RGB
img_hwc_rgb = img_rgb.permute(1, 2, 0).cpu().numpy() # (H, W, 3), RGB
img_hwc_bgr = img_hwc_rgb[:, :, ::-1] # RGB → BGR
img_uint8 = np.clip(img_hwc_bgr, 0, 255).astype(np.uint8)
save_path = os.path.join(self.debug_save_dir, f"{self.count}.jpg")
cv2.imwrite(save_path, img_uint8)
self.count += 1
# 🔼 DEBUG: Save done 🔼
def finalize(self):
self.logger.log_info("✅ YOLOX+ReID backend finalized.")
config.pbtxt
backend: "python"
max_batch_size: 4
input [
data_type: TYPE_FP32
#format: FORMAT_NCHW
#dims: [3, 1080, 1920]
dims: [1080, 1920, 3]
output [
dims: [-1, 6]
dims: [-1, 2048]
instance_group [
kind: KIND_GPU
count: 1
gpus: [0]
parameters: {
key: "FORCE_CPU_ONLY_INPUT_TENSORS"
value: {
string_value:"no"
My input video is H265 and 1920x1080. My nvinferserver configuration
infer_config {
unique_id: 1
gpu_ids: [0]
max_batch_size: 4
backend {
triton {
model_name: "yolox_reid_ensemble"
version: -1
grpc {
url: "192.168.1.90:32001"
enable_cuda_buffer_sharing: true
disable_warmup: true
preprocess {
network_format: IMAGE_FORMAT_RGB
tensor_order: TENSOR_ORDER_LINEAR
maintain_aspect_ratio: 0
frame_scaling_hw: FRAME_SCALING_HW_DEFAULT
frame_scaling_filter: 0
symmetric_padding: 0
normalize {
scale_factor: 1.0
channel_offsets: [0.0,0.0,0.0]
postprocess {
other {}
extra {
copy_input_to_host_buffers: false
input_control {
process_mode : PROCESS_MODE_FULL_FRAME
#operate_on_gie_id: 1
#operate_on_class_ids: [0]
interval : 0
output_control {
output_tensor_meta: true
When I save the image 0.jpg and compare it with the 0.jpg from the Triton HTTP version, there’s a slight difference.
If the input is the 0.jpg from HTTP, my ReID cosine similarity compared to the PyTorch version is 0.9999, but if I use the image from DeepStream and Triton, the cosine similarity drops to 0.97.
When comparing the two saved images from the two versions with
import cv2
import numpy as np
def compare_images_pixel_diff(img1_path, img2_path, threshold=0):
Compare two images and return:
- Number of differing pixels (absolute difference > threshold)
- MSE and PSNR
- Maximum absolute pixel difference (averaged across channels)
- Mean absolute pixel difference (MAE)
- Color and grayscale difference images
img1 = cv2.imread(img1_path).astype(np.float32)
img2 = cv2.imread(img2_path).astype(np.float32)
if img1 is None or img2 is None:
raise FileNotFoundError("One or both image files not found.")
if img1.shape != img2.shape:
print(f"Warning: Image dimensions differ! {img1.shape} vs {img2.shape}")
h, w = max(img1.shape[0], img2.shape[0]), max(img1.shape[1], img2.shape[1])
img1 = cv2.resize(img1, (w, h), interpolation=cv2.INTER_LINEAR)
img2 = cv2.resize(img2, (w, h), interpolation=cv2.INTER_LINEAR)
# Compute absolute pixel-wise difference (per channel)
diff = np.abs(img1 - img2) # Shape: (H, W, 3)
# Convert to grayscale by averaging across channels
diff_gray = np.mean(diff, axis=2) # Shape: (H, W)
# Compute metrics
num_diff_pixels = np.sum(diff_gray > threshold)
max_diff = np.max(diff_gray) # Max deviation (mean across channels)
mean_diff = np.mean(diff_gray) # Mean Absolute Error (MAE)
mse = np.mean((img1 - img2) ** 2)
if mse == 0:
psnr = float('inf')
else:
psnr = 10 * np.log10((255.0 ** 2) / mse)
return {
"num_diff_pixels": int(num_diff_pixels),
"max_diff": float(max_diff),
"mean_diff": float(mean_diff),
"mse": float(mse),
"psnr": float(psnr),
"diff_image": diff.astype(np.uint8),
"diff_gray": diff_gray.astype(np.uint8)
# === Usage ===
img1_path = "/ssd1/lelong/mge_ai_cloud/triton/saved/1.jpg"
img2_path = "/ssd1/lelong/mge_ai_cloud/triton/saved_CPU/0.jpg"
try:
result = compare_images_pixel_diff(img1_path, img2_path, threshold=1.0)
print(f"🔹 Number of differing pixels (difference > 1): {result['num_diff_pixels']:,}")
print(f"🔹 Max pixel deviation (mean across channels): {result['max_diff']:.2f}")
print(f"🔹 Mean absolute error (MAE): {result['mean_diff']:.4f}")
print(f"🔹 MSE: {result['mse']:.4f}")
print(f"🔹 PSNR: {result['psnr']:.2f} dB")
if result['num_diff_pixels'] == 0:
print("✅ Images are identical!")
else:
print("⚠️ Images differ.")
cv2.imwrite("diff_color.jpg", result['diff_image'])
cv2.imwrite("diff_gray.jpg", result['diff_gray'])
print("🖼️ Difference images saved: diff_color.jpg, diff_gray.jpg")
print(f"Error: {e}")
🔹 Number of differing pixels (difference > 1): 400,791
🔹 Max pixel deviation (mean across channels): 10.00
🔹 Mean absolute error (MAE): 0.7882
🔹 MSE: 1.5493
🔹 PSNR: 46.23 dB
⚠️ Images differ.
The input resolution is 1920×1080, and the nvinferserver calls Triton with a config.pbtxt where the input is also defined as (3×1080×1920). So in theory, the input should remain unchanged.
However, it seems that some resizing is happening somewhere, because when I change the frame_scaling_filter values, the saved input image—although still similar—changes depending on the frame_scaling_filter setting. Currently, I using new streammux, it doesn’t has width, height property.
test result:
frame_scaling_filter: 0, 2,3,4,5,6 → Cosine similarity: 0.96118206
frame_scaling_filter: 1 → Cosine similarity: 0.8941058
