Smart recording on single GPU
could you also provide a pipeline graph dot to confirm? Thanks! from the graph, only decoder will use GPU. and please use nvidia-smi to check if the application used two GPU.
I have attached pipeline graph and the nvidia-smi snapshot where it is clearly spawning the same gpu1 process in gpu0 as well. please check below zip file for pipeline graph and nvidia-smi
pipeline_graph_and_nvidia_smi.zip (206.2 KB)
The same gpu1 process getting spawned in gpu0 only when I give start-sr signal.
Thanks for the sharing! I can reproduce the issue.
  1. seems the memory size on other GPUs will not continue to increase. will this issue block you? may I know you company name?
  2. if you don’t need sr-done message, here is a workaround.
    2.1 open gstdsnvurisrcbin.cpp in /opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvurisrcbin. In populate_rtsp_bin, comment out “params.callback = smart_record_callback;”. then build libnvdsgst_nvurisrcbin.so according to readme.
    2.3 backup /opt/nvidia/deepstream/deepstream/lib/gst-plugins/libnvdsgst_nvurisrcbin.so, then cp libnvdsgst_nvurisrcbin.so /opt/nvidia/deepstream/deepstream/lib/gst-plugins/libnvdsgst_nvurisrcbin.so.
Hello @fanzh !
Can you explain what this means?
so it is the sr-done message causing the issue?
Were you able to wait for couple of minutes for the process to spawn on GPU-0, and were you able to rectify this, and make the process only spawn on GPU-1, and not GPU-0?
  1. Sorry, I mean, when setting the same gpu-id for all plugins and using smart record, the application do use another GPU. From my test, the GPU usage on another GPU will not continue to increase.
  2. did you verify the workaround? it is not the sr-done causing the issue. the reason is, after generating recording, smart recording will do some tasks(this step causes the issue), then emit a sr-done message. the workaround will remove doing some tasks and sending sr-done. if you can’t accept this workaround, since the issue occurs in the closed source, we will fix in the latter versions. Or may I know you company name? maybe we can provide the fix for your company in advance.
  3. about “make the process only spawn on GPU-1, and not GPU-0”, we will fix in the latter versions. Thanks!
It does not increase but, it matches the GPU-1’s memory, what if I already have something running on GPU-0, it will affect it.
I will try it, and update you on this.
gst-nvurisrcbin is not present in deepstream-7.0
Well, I tried on deepstream7.1, the workaround works, the process spawns on GPU-1, and continues to be on GPU-1..
I want to try this for deepstream-7.0 what can I do for deepstream-7.0?
Thanks for the sharing! nvurisrcbin is closed source on DS7.0. you can copy the directory to DS7.0 for rebuilding. maybe there are some compilation errors.
am I missing something?
can I just use the ‘SO’ file /opt/nvidia/deepstream/deepstream/lib/gst-plugins/libnvdsgst_nvurisrcbin.so in deepstream-7.0, that should be fine I guess?
