SmartRecord write 0 byte video
I extracted the event video save feature from project: deepstream-testsr (I moved this project from deepstream 6 and it worked in deepstream 5 with jetpack 4.5). When running, the console screen log start saving and save done, but the recorded video has a capacity of 0 bytes and only the first video can be recorded. (10s for each video).
I need your help to save the video normally. Thank you!
This is my code.
static gboolean
smart_record_event_generator(gpointer data)
  NvDsSRSessionId sessId = 0;
  NvDsSRContext *ctx = (NvDsSRContext *)data;
  guint startTime = START_TIME;
  guint duration = SMART_REC_DURATION;
  if (ctx->recordOn)
    g_print("Recording done.\n");
    if (NvDsSRStop(ctx, 0) != NVDSSR_STATUS_OK)
      g_printerr("Unable to stop recording\n");
  else
    g_print("Recording started..\n");
    if (NvDsSRStart(ctx, &sessId, startTime, duration,
                    NULL) != NVDSSR_STATUS_OK)
      g_printerr("Unable to start recording\n");
  return TRUE;
int main(int argc, char *argv[])
  DataContainer_t container;
  NvDsSRInitParams params = {0};
  params.containerType = NvDsSRContainerType::NVDSSR_CONTAINER_MP4;
  params.videoCacheSize = CACHE_SIZE_SEC;
  params.defaultDuration = SMART_REC_DEFAULT_DURATION;
  params.fileNamePrefix = "With_BBox";
  for (i = 0; i < num_sources; i++)
    if (NvDsSRCreate(&container.data[i], &params) != NVDSSR_STATUS_OK)
      g_printerr("Failed to create smart record bin for stream %d\n", i);
      return -1;
    gst_bin_add_many(GST_BIN(pipeline), container.data[i]->recordbin, NULL);
    if (!gst_element_link_many(tee_pre_decode, container.data[i]->recordbin, NULL))
      g_printerr("Elements of recordbin %d could not be linked. Exiting.\n", i);
      return -1;
    g_timeout_add(SMART_REC_INTERVAL * 1000, smart_record_event_generator,
                  container.data[i]);
  tee_pre_decode = gst_element_factory_make("tee", "tee-pre-decode");
  tee_post_osd = gst_element_factory_make("tee", "tee-post-osd");
  gst_bin_add_many(GST_BIN(pipeline), queue1, tee_pre_decode, pgie, queue2, nvtracker, queue3,
                   nvdsanalytics, queue4, tiler, queue5,
                   nvvidconv, queue6, nvosd, tee_post_osd, queue7, transform, sink,
                   NULL);
  if (!gst_element_link_many(streammux, queue1, pgie, queue2, nvtracker,
                             queue3, nvdsanalytics, queue4, tiler, queue5,
                             nvvidconv, tee_post_osd, queue6, nvosd, queue7, transform, sink, NULL))
    g_printerr("Elements could not be linked. Exiting.\n");
    return -1;
• Hardware Platform (Jetson / GPU): JetsonNano
• DeepStream Version: 5.0
• JetPack Version (valid for Jetson only): 4.5
• TensorRT Version: 7.0
• Issue Type( questions, new requirements, bugs): bugs
Sorry for the late response, our team will do the investigation and provide suggestions soon. Thanks
1 did you modify the code based on deepstream-testsr of deepstream 6.0?
2 About this code “gst_element_link_many(tee_pre_decode, container.data[i]->recordbin”, why did you link many recordbin to tee_pre_decode? there is a parallel limitation Frequently Asked Questions — DeepStream 6.1.1 Release documentation
