• Hardware Platform: Jetson AGX Orin
• DeepStream Version: 7.0
• JetPack Version: 6.0
• TensorRT Version: 8.6.2
• Issue Type( questions, bugs)
• How to reproduce the issue ? Try deepstream-app
We would like to use “Smart Video Record” feature in deepstream-app. When we set “start-record=2” for each sources (2 rtsp streams), the deepstream-app does record 2 playable videos, but it just records once, then it quits/exits.
We expect it should behave (record on interval (frequently)) what the documentation (Smart Video Record — DeepStream documentation 6.4 documentation) describes and the source code (g_timeout_add (bin->config->smart_rec_interval * 1000, smart_record_event_generator, bin);) shows.
If you have any hint on how to solve this issue, please let me know.
We provide info and log so that you refer to.
RTSP streams format:
rtsp://${USER}:${PASSWD}@${HOST_IP}:7001/${CAMO_ID}?stream=0
smart_record.log
0:2560:1920:8478ms:(null):Smart_Record_00001_20240814-044511_1312.mp4
0:2560:1920:8463ms:(null):Smart_Record_00000_20240814-044511_1312.mp4
**PERF: FPS 0 (Avg) FPS 1 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:240>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 279
NvMMLiteBlockCreate : Block : BlockType = 279
** INFO: <bus_callback:226>: Pipeline running
** WARN: <queue_src_pad_probe:275>: Invalid PTS found in stream. Stream recorded by Smart Record might have issues
**PERF: 6.51 (6.08) 7.69 (7.20)
**PERF: 6.05 (6.15) 6.44 (6.83)
**PERF: 5.91 (6.09) 6.11 (6.59)
**PERF: 6.08 (6.07) 6.28 (6.48)
** INFO: <bus_callback:263>: Received EOS. Exiting ...
Quitting
[NvMultiObjectTracker] De-initialized
App run successful
