After installing the drivers for the GPUs using sudo ubuntu-drivers autoinstall I got have the following drivers:
ii libnvidia-cfg1-530:amd64 530.41.03-0ubuntu0.20.04.2 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-530 530.41.03-0ubuntu0.20.04.2 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-530:amd64 530.41.03-0ubuntu0.20.04.2 amd64 NVIDIA libcompute package
ii libnvidia-compute-530:i386 530.41.03-0ubuntu0.20.04.2 i386 NVIDIA libcompute package
ii libnvidia-decode-530:amd64 530.41.03-0ubuntu0.20.04.2 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-530:i386 530.41.03-0ubuntu0.20.04.2 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-530:amd64 530.41.03-0ubuntu0.20.04.2 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-530:i386 530.41.03-0ubuntu0.20.04.2 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-530:amd64 530.41.03-0ubuntu0.20.04.2 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-530:amd64 530.41.03-0ubuntu0.20.04.2 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-530:i386 530.41.03-0ubuntu0.20.04.2 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-530:amd64 530.41.03-0ubuntu0.20.04.2 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-530:i386 530.41.03-0ubuntu0.20.04.2 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ml-dev 10.1.243-3 amd64 NVIDIA Management Library (NVML) development files
ii linux-modules-nvidia-530-open-5.15.0-70-generic 5.15.0-70.77~20.04.1+1 amd64 Linux kernel nvidia modules for version 5.15.0-70
ii linux-modules-nvidia-530-open-generic-hwe-20.04 5.15.0-70.77~20.04.1+1 amd64 Extra drivers for nvidia-530-open for the generic-hwe-20.04 flavour
ii nvidia-compute-utils-530 530.41.03-0ubuntu0.20.04.2 amd64 NVIDIA compute utilities
ii nvidia-cuda-dev 10.1.243-3 amd64 NVIDIA CUDA development files
ii nvidia-cuda-doc 10.1.243-3 all NVIDIA CUDA and OpenCL documentation
ii nvidia-cuda-gdb 10.1.243-3 amd64 NVIDIA CUDA Debugger (GDB)
ii nvidia-cuda-toolkit 10.1.243-3 amd64 NVIDIA CUDA development toolkit
ii nvidia-driver-530-open 530.41.03-0ubuntu0.20.04.2 amd64 NVIDIA driver (open kernel) metapackage
ii nvidia-kernel-common-530 530.41.03-0ubuntu0.20.04.2 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-530-open 530.41.03-0ubuntu0.20.04.2 amd64 NVIDIA kernel source package
ii nvidia-opencl-dev:amd64 10.1.243-3 amd64 NVIDIA OpenCL development files
ii nvidia-prime 0.8.16~0.20.04.2 all Tools to enable NVIDIA's Prime
ii nvidia-profiler 10.1.243-3 amd64 NVIDIA Profiler for CUDA and OpenCL
ii nvidia-settings 470.57.02-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-530 530.41.03-0ubuntu0.20.04.2 amd64 NVIDIA driver support binaries
ii nvidia-visual-profiler 10.1.243-3 amd64 NVIDIA Visual Profiler for CUDA and OpenCL
ii screen-resolution-extra 0.18build1 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-530 530.41.03-0ubuntu0.20.04.2 amd64 NVIDIA binary Xorg driver
I then installed the cuda toolkit using the following command sudo apt-get install nvidia-cuda-toolkit
However, when I run nvidia-smi I get the following error:
No devices were found
Can someone help with this?
nvidia-bug-report.log (943.3 KB)
