Hi…
I’m new in CUDA. Now I have one c++ code and want to run in under CUDA. May I know how to start and which section need to do 1st ?
This is the source code that I need to run on CUDA
#include <iostream>
#include <fstream>
#include <cstdlib>
#include <string>
#include <cmath>
#include <sys/time.h>
using namespace std;
double similarity_score(char a,char b);
double find_array_max(double array[],int length);
void insert_at(char arr[], int n, int idx, char val);
void checkfile(int open, char filename[]);
string read_sequence(ifstream& f);
int ind;
double mu,delta;
int main(int argc, char** argv){
// read info from arguments
if(argc!=6){
cout<<"Give me the propen number of input arguments:"<<endl<<"1 : mu"<<endl;
cout<<"2 : delta"<<endl<<"3 : filename sequence A"<<endl<<"4 : filename sequence B"<<endl;
cout<<"5 : maximal length N of sequences"<<endl;exit(1);
mu = atof(argv[1]);
delta = atof(argv[2]);
// give it the filenames
char *nameof_seq_a = argv[3];
char *nameof_seq_b = argv[4];
int N_max = atoi(argv[5]);
string seq_a,seq_b;
// read the sequences into two vectors:
ifstream stream_seq_b; // first define the input-streams for seq_a and seq_b
stream_seq_b.open(nameof_seq_b); // the same for seq_b
checkfile(! stream_seq_b,nameof_seq_b);
seq_b = read_sequence(stream_seq_b);
ifstream stream_seq_a;
stream_seq_a.open(nameof_seq_a); // open the file for input
checkfile(! stream_seq_a,nameof_seq_a); // check, whether the file was opened successfully
seq_a = read_sequence(stream_seq_a);
// string s_a=seq_a,s_b=seq_b;
int N_a = seq_a.length(); // get the actual lengths of the sequences
int N_b = seq_b.length();
// initialize H
double H[N_a+1][N_b+1];
for(int i=0;i<=N_a;i++){
for(int j=0;j<=N_b;j++){
H[i][j]=0.;
double temp[4];
int I_i[N_a+1][N_b+1],I_j[N_a+1][N_b+1]; // Index matrices to remember the 'path' for backtracking
// here comes the actual algorithm
for(int i=1;i<=N_a;i++){
for(int j=1;j<=N_b;j++){
temp[0] = H[i-1][j-1]+similarity_score(seq_a[i-1],seq_b[j-1]);
temp[1] = H[i-1][j]-delta;
temp[2] = H[i][j-1]-delta;
temp[3] = 0.;
H[i][j] = find_array_max(temp,4);
switch(ind){
case 0: // score in (i,j) stems from a match/mismatch
I_i[i][j] = i-1;
I_j[i][j] = j-1;
break;
case 1: // score in (i,j) stems from a deletion in sequence A
I_i[i][j] = i-1;
I_j[i][j] = j;
break;
case 2: // score in (i,j) stems from a deletion in sequence B
I_i[i][j] = i;
I_j[i][j] = j-1;
break;
case 3: // (i,j) is the beginning of a subsequence
I_i[i][j] = i;
I_j[i][j] = j;
break;
// Print the matrix H to the console
cout<<"**********************************************"<<endl;
cout<<"The scoring matrix is given by "<<endl<<endl;
cout<<H[i][j]<<" ";
cout<<endl;
// search H for the maximal score
double H_max = 0.;
int i_max=0,j_max=0;
if(H[i][j]>H_max){
H_max = H[i][j];
i_max = i;
j_max = j;
//cout<<H_max<<endl;
// Backtracking from H_max
int current_i=i_max,current_j=j_max;
int next_i=I_i[current_i][current_j];
int next_j=I_j[current_i][current_j];
int tick=0;
char consensus_a[N_a+N_b+2],consensus_b[N_a+N_b+2];
while(((current_i!=next_i) || (current_j!=next_j)) && (next_j!=0) && (next_i!=0)){
if(next_i==current_i) consensus_a[tick] = '-'; // deletion in A
else consensus_a[tick] = seq_a[current_i-1]; // match/mismatch in A
if(next_j==current_j) consensus_b[tick] = '-'; // deletion in B
else consensus_b[tick] = seq_b[current_j-1]; // match/mismatch in B
current_i = next_i;
current_j = next_j;
next_i = I_i[current_i][current_j];
next_j = I_j[current_i][current_j];
tick++;
// Output of the consensus motif to the console
cout<<endl<<"***********************************************"<<endl;
cout<<"The alignment of the sequences"<<endl<<endl;
for(int i=0;i<N_a;i++){cout<<seq_a[i];}; cout<<" and"<<endl;
for(int i=0;i<N_b;i++){cout<<seq_b[i];}; cout<<endl<<endl;
cout<<"is for the parameters mu = "<<mu<<" and delta = "<<delta<<" given by"<<endl<<endl;
for(int i=tick-1;i>=0;i--) cout<<consensus_a[i];
cout<<endl;
for(int j=tick-1;j>=0;j--) cout<<consensus_b[j];
cout<<endl;
} // END of main
// auxiliary functions used by main:
void checkfile(int open, char filename[]){
if (open){cout << "Error: Can't open the file "<<filename<<endl;exit(1);}
else cout<<"Opened file "<<filename<<endl;
double similarity_score(char a,char b){
double result;
if(a==b){
result=1.;
else{
result=-mu;
return result;
double find_array_max(double array[],int length){
double max = array[0]; // start with max = first element
ind = 0;
for(int i = 1; i<length; i++){
if(array[i] > max){
max = array[i];
ind = i;
return max; // return highest value in array
// overflows.
string seq;
char line[5000];
while( f.good() )
f.getline(line,5000);
// cout << "Line:" << line << endl;
if( line[0] == 0 || line[0]=='#' )
continue;
for(int i = 0; line[i] != 0; ++i)
int c = toupper(line[i]);
if( c != 'A' && c != 'G' && c != 'C' && c != 'T' )
continue;
//cout << char(c);
seq.push_back(char(c));
return seq;
