I’ve seen it mentioned in response to other threads, so for clarity, if your setup is:
WIP: 21364.co_release.210416-1504
WSL2 Linux Ubuntu20.04 5.4.72-microsoft-standard-WSL2 #1 SMP Wed Oct 28 23:40:43 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Nvidia Driver 470.14
cuda-toolkit-11-0 version 11.0.3-1
WSL2 nvidia-container-toolkit 1.4.2-1
WSL2 Docker-ce 5:20.10.6~3-0~ubuntu-focal
Which would mean you’re on the latest of each component, it’s broken right now?
I don’t mean this to sound glib, I am seeking clarity and confirmation here only.
Same issue here, with the same versions installed. I’m using a GeForce GTX 1060.
I’m trying it on kali-linux (which is not supported), but it fails to detect the GPU. Instead, glxinfo reports mesa drivers with vendor LLVM (which might not be the issue, but I’ve read it’s supposed to report nvidia as the vendor).
Also tried on the latest Ubuntu, which is supposed to be supported, but same result… :/
Is this the same issue reported here or is it separate?
I need to install WSL2 to work with CUDA but I’m hesitant in case I break something that’s hard to fix. I’m on Windows 10 Pro Build 21364.co_release.210416-1504 (freshly updated from a non-insider version).
I am running nbody on Docker Desktop without problem in build 21364. Just make sure:
You are passing the parameter --env NVIDIA_DISABLE_REQUIRE=1 to docker to avoid this bug.
Your GPU is available in WSL2. That happens if /dev/dxg device exists and also if your gpu name appears at the output of glxinfo -B after installing latest mesa on Ubuntu:
Try installing latest mesa 21.0.3 following the steps from my previous post.
I forgot to say that I got Nvidia driver version 27.21.14.7025 from Windows Update the same day I upgraded to build 21364. Maybe it’s what’s making it work for me in my GT 710.
For some reason I can’t edit the original post anymore, but here’s an update:
WIP updated to 21370.co_release.210424-1611
Nvidia Driver updated to 470.25
WSL2 nvidia-container-toolkit updated to 1.5.0-1
-I managed to find older driver 465.21
-I also succeeded in upgrading mesa to 21.1.0 (21.0.3 was old)
(although I had to type sudo apt upgrade, sudo apt --fix-broken install and sudo apt upgrade again)
So that glxinfo -B finally was reporting me the GPU Name (NVIDIA GEFORCE RTX 2060 Super …)
I also run the basic docker gpu with --env NVIDIA_DISABLE_REQUIRE=1
$ sudo docker run --gpus all --env NVIDIA_DISABLE_REQUIRE=1 nvcr.io/nvidia/k8s/cuda-sample:nbody nbody -gpu -benchmark
But no way, it says that :
Error: only 0 Devices available, 1 requested. Exiting.
