I’m using the production Nano module on a custom carrier, and I see this message repeated a number of times during boot/while running
Can anyone tell me what it means?
Please do share the full boot up log from UART serial console.
syslog here: Jan 6 16:58:53 localhost systemd-modules-load[1983]: Inserted module 'bluedroid - Pastebin.com
Somehow pastebin is blocked by my network. Could you directly attach it?
Could you try to share boot up log instead of syslog?
Jetson Nano Style - Serial Console - JetsonHacks
Hi, dump from serial console is below:
S³&§Hø[0000.289] Last reboot was clean, booting normally!
[0000.294] Sdram initialization is successful
[0000.298] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.304] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.310] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.316] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.321] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.327] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.333] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.339] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.355] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.361] Platform-DebugCarveout: 0
[0000.364] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.370] Non secure mode, and RB not enabled.
[0000.387] Csd NumOfBlocks=0
[0000.579] *** Booting BFS0.
[0000.585] Using BFS PT to query partitions
[0001.169] *** Booting KFS0.
[0001.173] Using GPT Primary to query partitions
[0001.178] Loading Tboot-CPU binary
[0001.185] Verifying TBC in OdmNonSecureSBK mode
[0001.195] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0001.202] Bootloader downloaded successfully.
[0001.206] Downloaded Tboot-CPU binary to 0xa0000258
[0001.211] MAX77620_GPIO5 configured
[0001.214] CPU power rail is up
[0001.217] CPU clock enabled
[0001.221] Performing RAM repair
[0001.224] Updating A64 Warmreset Address to 0xa00002e9
[0001.229] Loading NvTbootBootloaderDTB
[0001.246] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0001.312] Bootloader DTB Load Address: 0x83000000
[0001.316] Loading NvTbootKernelDTB
[0001.333] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0001.398] Kernel DTB Load Address: 0x83100000
[0001.403] Loading cboot binary
[0001.414] Verifying EBT in OdmNonSecureSBK mode
[0001.456] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.463] Bootloader downloaded successfully.
[0001.467] Next binary entry address: 0x92c00258
[0001.472] BoardId: 3448
[0001.476] Overriding pmu board id with proc board id
[0001.481] Display board id is not available
[0001.493] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.545] /bpmp deleted
[0001.547] SC7EntryFw header found loaded at 0xff700000
[0001.736] OVR2 PMIC
[0001.738] Bpmp FW successfully loaded
[0001.743] WB0 init successfully at 0xff780000
[0001.747] Set NvDecSticky Bits
[0001.750] GSC2 address ff53fffc value c0edbbcc
[0001.757] GSC MC Settings done
[0001.760] TOS Image length 53680
[0001.763] Monitor size 53680
[0001.766] OS size 0
[0001.771] Secure Os AES-CMAC Verification Success!
[0001.775] TOS image cipher info: plaintext
[0001.779] Loading and Validation of Secure OS Successful
[0001.795] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.800] NvTbootPackSdramParams: start.
[0001.805] NvTbootPackSdramParams: done.
[0001.809] Tegraboot started after 159685 us
[0001.813] Basic modules init took 1362241 us
[0001.817] Sec Bootdevice Read Time = 542 ms, Read Size = 14457 KB
[0001.823] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.828] Next stage binary read took 7384 us
[0001.832] Carveout took -19260 us
[0001.835] CPU initialization took 342293 us
[0001.839] Total time taken by TegraBoot 1692658 us
[0001.844] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 22:39:57, Dec 9 2019
ERROR: Error initializing runtime service trusty_fast
[0001.966] RamCode = 0
[0001.971] LPDDR4 Training: Read DT: Number of tables = 2
[0001.976] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.989] EMC Training Successful
[0001.992] 408000 not found in DVFS table
[0001.998] RamCode = 0
[0002.002] DT Write: emc-table@204000 succeeded
[0002.007] DT Write: emc-table@1600000 succeeded
[0002.011] LPDDR4 Training: Write DT: Number of tables = 2
[0002.069]
[0002.070] Debug Init done
[0002.073] Marked DTB cacheable
[0002.076] Bootloader DTB loaded at 0x83000000
[0002.080] Marked DTB cacheable
[0002.083] Kernel DTB loaded at 0x83100000
[0002.087] DeviceTree Init done
[0002.103] Pinmux applied successfully
[0002.107] gicd_base: 0x50041000
[0002.111] gicc_base: 0x50042000
[0002.114] Interrupts Init done
[0002.118] Using base:0x60005090 & irq:208 for tick-timer
[0002.123] Using base:0x60005098 for delay-timer
[0002.127] platform_init_timer: DONE
[0002.131] Timer(tick) Init done
[0002.135] osc freq = 38400 khz
[0002.139]
[0002.140] Welcome to L4T Cboot
[0002.143]
[0002.144] Cboot Version: 00.00.2018.01-t210-40c3ff9c
[0002.149] calling constructors
[0002.152] initializing heap
[0002.155] initializing threads
[0002.157] initializing timers
[0002.160] creating bootstrap completion thread
[0002.165] top of bootstrap2()
[0002.168] CPU: ARM Cortex A57
[0002.170] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0002.175] initializing platform
[0002.229] Config for emmc ddr50 mode completed
[0002.234] sdmmc bdev is already initialized
[0002.238] Enable APE clock
[0002.240] Un-powergate APE partition
[0002.244] of_register: registering tegra_udc to of_hal
[0002.249] of_register: registering inv20628-driver to of_hal
[0002.254] of_register: registering ads1015-driver to of_hal
[0002.260] of_register: registering lp8557-bl-driver to of_hal
[0002.266] of_register: registering bq2419x_charger to of_hal
[0002.271] of_register: registering bq27441_fuel_gauge to of_hal
[0002.283] gpio framework initialized
[0002.286] of_register: registering tca9539_gpio to of_hal
[0002.292] of_register: registering tca9539_gpio to of_hal
[0002.297] of_register: registering i2c_bus_driver to of_hal
[0002.303] of_register: registering i2c_bus_driver to of_hal
[0002.308] of_register: registering i2c_bus_driver to of_hal
[0002.314] pmic framework initialized
[0002.317] of_register: registering max77620_pmic to of_hal
[0002.323] regulator framework initialized
[0002.327] of_register: registering tps65132_bl_driver to of_hal
[0002.333] initializing target
[0002.338] gpio_driver_register: register 'tegra_gpio_driver' driver
[0002.349] fixed regulator driver initialized
[0002.366] initializing OF layer
[0002.369] NCK carveout not present
[0002.373] Skipping dts_overrides
[0002.377] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.394] I2C Bus Init done
[0002.396] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.407] I2C Bus Init done
[0002.409] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.420] I2C Bus Init done
[0002.422] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.433] I2C Bus Init done
[0002.435] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.446] I2C Bus Init done
[0002.448] of_children_init: Ops found for compatible string maxim,max77620
[0002.459] max77620_init using irq 118
[0002.464] register 'maxim,max77620' pmic
[0002.468] gpio_driver_register: register 'max77620-gpio' driver
[0002.474] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.484] I2C Bus Init done
[0002.488] NCK carveout not present
[0002.498] Find /i2c@7000c000's alias i2c0
[0002.502] get eeprom at 1-a0, size 256, type 0
[0002.511] Find /i2c@7000c500's alias i2c2
[0002.515] get eeprom at 3-a0, size 256, type 0
[0002.519] get eeprom at 3-ae, size 256, type 0
[0002.523] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.529] I2C slave not started
[0002.532] I2C write failed
[0002.534] Writing offset failed
[0002.537] eeprom_init: EEPROM read failed
[0002.541] pm_ids_update: eeprom init failed
[0002.545] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.575] pm_ids_update: The pm board id is 3448-0002-400
[0002.582] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.590] pm_ids_update: pm id update successful
[0002.594] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.600] I2C slave not started
[0002.603] I2C write failed
[0002.605] Writing offset failed
[0002.609] eeprom_init: EEPROM read failed
[0002.612] pm_ids_update: eeprom init failed
[0002.643] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.649] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.657] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.663] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.671] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:db:f2
[0002.678] Plugin Manager: Parse ODM data 0x00094000
[0002.688] shim_cmdline_install: /chosen/bootargs: root=PARTUUID=9589ea9c-91c2-45b9-a833-abe1663c1613 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0002.715] Find /i2c@7000c000's alias i2c0
[0002.719] get eeprom at 1-a0, size 256, type 0
[0002.728] Find /i2c@7000c500's alias i2c2
[0002.732] get eeprom at 3-a0, size 256, type 0
[0002.736] get eeprom at 3-ae, size 256, type 0
[0002.740] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.746] I2C slave not started
[0002.749] I2C write failed
[0002.751] Writing offset failed
[0002.754] eeprom_init: EEPROM read failed
[0002.758] pm_ids_update: eeprom init failed
[0002.762] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.792] pm_ids_update: The pm board id is 3448-0002-400
[0002.799] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.806] pm_ids_update: pm id update successful
[0002.810] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.816] I2C slave not started
[0002.819] I2C write failed
[0002.821] Writing offset failed
[0002.824] eeprom_init: EEPROM read failed
[0002.828] pm_ids_update: eeprom init failed
[0002.859] Add serial number:1422819017966 as DT property
[0002.866] Applying platform configs
[0002.873] platform-init is not present. Skipping
[0002.878] calling apps_init()
[0002.893] Found 17 GPT partitions in "sdmmc3_user"
[0002.898] Proceeding to Cold Boot
[0002.901] starting app android_boot_app
[0002.905] Device state: unlocked
[0002.908] display console init
[0002.917] could not find regulator
[0002.920] hdmi cable connected
[0002.954] DT entry for leds-pwm not found
[0004.930] I2C transfer timeout
[0004.933] I2C write failed
[0004.936] Writing offset failed
[0004.939] could not read edid
[0004.943] tmds-config node not found
[0004.948] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0004.962] setting 'vdd-1v8' regulator to 1800000 micro volts
[0004.970] could not find regulator
[0004.973] could not find regulator
[0004.976] could not find regulator
[0005.005] using default cmu settings
[0005.009] dc_hdmi_enable, starting HDMI initialisation
[0005.015] dc_hdmi_enable, HDMI initialisation complete
[0005.020] list and configure display window
[0005.025] display console init completed
[0005.032] subnode volume_up is not found !
[0005.036] subnode back is not found !
[0005.040] subnode volume_down is not found !
[0005.044] subnode menu is not found !
[0005.047] Gpio keyboard init success
[0005.095] found decompressor handler: lz4-legacy
[0005.109] decompressing blob (type 1)...
[0005.143] load_bmp_blob: panelresolution=480 type=0
[0005.192] decompressor handler not found
[0005.196] load_firmware_blob: Firmware blob loaded, entries=2
[0005.202] -------> se_aes_verify_sbk_clear: 747
[0005.206] se_aes_verify_sbk_clear: Error
[0005.210] bl_battery_charging: connected to external power supply
[0005.218] xusb is supported
[0005.224] error while finding nvidia,portmap
[0005.728] xusb blob version 0 size 124416
[0005.732] firmware size 124416
[0005.737] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0005.750] xhci0: 64 bytes context size, 32-bit DMA
[0005.790] usbus0: 5.0Gbps Super Speed USB v3.0
[0005.810] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0006.460] uhub0: 9 ports with 9 removable, self powered
[0008.620] failed to get HID devices
[0008.624] failed to init xhci or no usb device attached
[0008.638] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0008.645] MSC Partition not found
[0008.655] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0008.662] USP partition read failed!
[0008.666] blob_init: blob-partition USP header read failed
[0008.671] android_boot Unable to update recovery partition
[0008.676] kfs_getpartname: name = LNX
[0008.680] Loading kernel from LNX
[0008.744] load kernel from storage
[0008.753] decompressor handler not found
[0008.773] Successfully loaded kernel and ramdisk images
[0008.779] load_bmp_blob: panelresolution=480 type=0
[0008.853] display bmp image done
[0008.856] NCK carveout not present
[0008.859] Skipping dts_overrides
[0008.862] NCK carveout not present
[0008.872] Find /i2c@7000c000's alias i2c0
[0008.876] get eeprom at 1-a0, size 256, type 0
[0008.885] Find /i2c@7000c500's alias i2c2
[0008.889] get eeprom at 3-a0, size 256, type 0
[0008.893] get eeprom at 3-ae, size 256, type 0
[0008.898] pm_ids_update: Updating 1,a0, size 256, type 0
[0008.903] I2C slave not started
[0008.906] I2C write failed
[0008.909] Writing offset failed
[0008.912] eeprom_init: EEPROM read failed
[0008.916] pm_ids_update: eeprom init failed
[0008.920] pm_ids_update: Updating 3,a0, size 256, type 0
[0008.950] pm_ids_update: The pm board id is 3448-0002-400
[0008.957] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0008.964] pm_ids_update: pm id update successful
[0008.969] pm_ids_update: Updating 3,ae, size 256, type 0
[0008.974] I2C slave not started
[0008.977] I2C write failed
[0008.980] Writing offset failed
[0008.983] eeprom_init: EEPROM read failed
[0008.987] pm_ids_update: eeprom init failed
[0009.017] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0009.023] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0009.031] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0009.037] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0009.046] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:db:f2
[0009.052] Plugin Manager: Parse ODM data 0x00094000
[0009.062] shim_cmdline_install: /chosen/bootargs: root=PARTUUID=9589ea9c-91c2-45b9-a833-abe1663c1613 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0009.083] Add serial number:1422819017966 as DT property
[0009.092] "bpmp" doesn't exist, creating
[0009.097] Updated bpmp info to DTB
[0009.102] Updated initrd info to DTB
[0009.106] "proc-board" doesn't exist, creating
[0009.111] Updated board info to DTB
[0009.115] "pmu-board" doesn't exist, creating
[0009.120] Updated board info to DTB
[0009.123] "display-board" doesn't exist, creating
[0009.129] Updated board info to DTB
[0009.132] "reset" doesn't exist, creating
[0009.137] Updated reset info to DTB
[0009.140] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb0000 is_hdmi_initialised=1
[0009.179] DTB cmdline: root=PARTUUID=9589ea9c-91c2-45b9-a833-abe1663c1613 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0009.197] boot image cmdline: root=PARTUUID=9589ea9c-91c2-45b9-a833-abe1663c1613 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0009.216] Updated bootarg info to DTB
[0009.220] Adding uuid 00000001644495881c00000011fe8100 to DT
[0009.226] Adding eks info 0 to DT
[0009.231] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0009.237] Updated memory info to DTB
[0009.246] set vdd_core voltage to 1075 mv
[0009.250] setting 'vdd-core' regulator to 1075000 micro volts
[0009.270] Found secure-pmc; disable BPMP
U-Boot 2016.07-g0536cf2a27 (Dec 09 2019 - 22:40:32 -0800)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Failed to get idcodes
*** Warning - spi_flash_probe() failed, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Card did not respond to voltage select!
** Bad device mmc 1 **
Hit any key to stop autoboot: 1 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 104 ms (6.8 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5487751 bytes read in 200 ms (26.2 MiB/s)
Retrieving file: /boot/Image
34191368 bytes read in 807 ms (40.4 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb0000 is_hdmi_initialised=1 root=PARTUUID=9589ea9c-91c2-45b9-a833-abe1663c1613 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 root=PARTUUID=9589ea9c-91c2-45b9-a833-abe1663c1613 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet
## Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 000000008317771e
Starting kernel ...
<hit enter to activate fiq debugger>
[ 1.230736] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.238320] imx219 7-0010: board setup failed
[ 1.266718] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.274255] imx219 8-0010: board setup failed
[ 11.121963] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 11.128414] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 11.135113] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 11.140250] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 11.146946] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 11.152515] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 11.158344] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 11.163566] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 11.168901] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 11.176737] tegradc tegradc.1: dpd enable lookup fail:-19
[ 11.740367] cgroup: cgroup2: unknown option "nsdelegate"
[ 11.793186] soctherm: OC ALARM 0x00000001
[ 12.796007] soctherm: OC ALARM 0x00000001
[ 12.992965] using random self ethernet address
[ 13.001090] using random host ethernet address
[ 13.491973] random: crng init done
[ 13.495381] random: 7 urandom warning(s) missed due to ratelimiting
[ 13.610715] using random self ethernet address
[ 13.615200] using random host ethernet address
[ 13.798345] soctherm: OC ALARM 0x00000001
[ 14.803004] soctherm: OC ALARM 0x00000001
[ 15.071980] edid invalid
[ 21.362685] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 21.362723] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 21.362763] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 21.362797] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 21.362830] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 21.362862] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 21.362896] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 21.362927] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 21.363010] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 31.602750] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 31.602787] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 31.602827] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 31.602860] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 31.602892] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 31.602925] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 31.602957] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 31.602987] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 31.603071] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 31.748200] soctherm: OC ALARM 0x00000001
Ubuntu 18.04.3 LTS localhost ttyS0
localhost login: [ 32.800083] soctherm: OC ALARM 0x00000001
[ 35.585846] soctherm: OC ALARM 0x00000001
[ 36.876206] soctherm: OC ALARM 0x00000001
[ 38.216203] soctherm: OC ALARM 0x00000001
[ 41.842507] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 41.849530] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 41.857071] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 41.862564] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 41.869394] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 41.875104] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 41.881221] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 41.886830] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 41.892183] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 52.082741] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 52.089806] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 52.097067] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 52.102581] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 52.109498] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 52.115538] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 52.121425] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 52.127486] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 52.133214] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 62.322528] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 62.329865] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 62.336850] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 62.342300] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 62.349088] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 62.354840] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 62.360889] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 62.366150] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 62.371502] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
localhost login: nano
Password: [ 72.562500] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 72.569700] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 72.576675] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 72.581959] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 72.588853] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 72.594808] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 72.600772] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 72.606184] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 72.611547] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
Last login: Mon Jan 6 16:59:40 UTC 2020 from 192.168.1.122 on pts/0
[ 72.874455] soctherm: OC ALARM 0x00000001
Welcome to Ubuntu 18.04.3 LTS (GNU/Linux 4.9.140-tegra aarch64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
231 packages can be updated.
123 updates are security updates.
Failed to connect to https://changelogs.ubuntu.com/meta-release-lts. Check your Internet connection or proxy settings
nano@localhost:~$
Looks that it is indeed an error. I will ask our developer for more detail. Thanks.
btw, what power mode are you using now?
HW throttling (OC alarm) would happen when input voltage drops below safe operating voltage ~4.5V. Please make sure you have a stable input 5V@4A power supply.
Thanks. I am powering from a 10A benchtop supply, but I do see some transients on the 5V rail. I will add more bulk capacitance to the board.
