Hi
I have questions about HDMI
As per P63 of DG10931-001_v1.0, HDMI was connected as hardware.
- DP differential signal and HDMI differential signal input to SoM are shared as per P56 of DG10931-001_v1.0, which one works by default with Jetpack 5.1 or later?
- Is it possible to operate HDMI with Jetpack 5.1 or later only with the following command settings?
Common Display configurations for all Platforms — Jetson Linux Developer Guide documentation - Do I need to change the device tree or other software to change the default behavior of “1.”?
