Anyone know how to figure out this problems?
If i remove “-DN=1024” , it compile correctly.
Compiling error:
usr/local/cuda/bin/../targets/x86_64-linux/include/cuda.h(6121): error: expected a ")"
/usr/local/cuda/bin/../targets/x86_64-linux/include/cuda.h(6155): error: expected a ")"
/usr/local/cuda/bin/../targets/x86_64-linux/include/cuda.h(6189): error: expected a ")"
/usr/local/cuda/bin/../targets/x86_64-linux/include/cuda.h(6344): error: expected a ")"
/usr/local/cuda/bin/../targets/x86_64-linux/include/cuda.h(6380): error: expected a ")"
/usr/local/cuda/bin/../targets/x86_64-linux/include/cuda.h(6415): error: expected a ")"
6 errors detected in the compilation of "/tmp/tmpxft_00001279_00000000-9_vd_tex.cpp1.ii".
Makefile:
vd_tex:vd_tex.cu
nvcc -DN=1024 -o vd_tex vd_tex.cu
vd_tex.cu
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <cuda.h>
#ifndef N
#define N (2048)
#endif
texture<float> tex_a;
texture<float> tex_b;
texture<float> tex_c;
// CUDA kernel. Each thread takes care of one element of c
__global__ void vecAdd(float *c)
// Get our global thread ID
int id = blockIdx.x*blockDim.x+threadIdx.x;
// Make sure we do not go out of bounds
// if (id < N) {
c[id] = tex1Dfetch(tex_a,id) + tex1Dfetch(tex_b,id);
int main( int argc, char* argv[] )
// Size of vectors
//int n = 10000;
// Host input vectors
float *h_a;
float *h_b;
//Host output vector
float *h_c;
// Device input vectors
float *d_a;
float *d_b;
//Device output vector
float *d_c;
// Size, in bytes, of each vector
size_t bytes = N*sizeof(float);
// Allocate memory for each vector on host
h_a = (float*)malloc(bytes);
h_b = (float*)malloc(bytes);
h_c = (float*)malloc(bytes);
// Allocate memory for each vector on GPU
cudaMalloc(&d_a, bytes);
cudaMalloc(&d_b, bytes);
cudaMalloc(&d_c, bytes);
int i;
// Initialize vectors on host
for( i = 0; i < N; i++ ) {
h_a[i] = sin(i)*sin(i);
h_b[i] = cos(i)*cos(i);
//h_c[i] = 0.0f;
// bind to texture memory
cudaBindTexture( NULL, tex_a,
d_a,
bytes );
cudaBindTexture( NULL, tex_b,
d_b,
bytes );
cudaBindTexture( NULL, tex_c,
d_c,
bytes );
// Copy host vectors to device
cudaMemcpy( d_a, h_a, bytes, cudaMemcpyHostToDevice);
cudaMemcpy( d_b, h_b, bytes, cudaMemcpyHostToDevice);
int blockSize, gridSize;
// Number of threads in each thread block
blockSize = 1024;
// Number of thread blocks in grid
gridSize = (int)ceil((float)N/blockSize);
// Execute the kernel
vecAdd<<<gridSize, blockSize>>>(d_c);
// Copy array back to host
cudaMemcpy( h_c, d_c, bytes, cudaMemcpyDeviceToHost );
// Sum up vector c and print result divided by n, this should equal 1 within error
float sum = 0;
for(i=0; i<N; i++)
sum += h_c[i];
printf("final result: %f\n", sum/N);
// Release device memory
cudaFree(d_a);
cudaFree(d_b);
cudaFree(d_c);
// Release host memory
free(h_a);
free(h_b);
free(h_c);
return 0;
