**SOLVED** Nvidia-settings -a [gpu:1]/GPUMemoryTransferRateOffset[3]=2000 doesn't take effect
as you read from the title when i run:
nvidia-settings -a [gpu:1]/GPUMemoryTransferRateOffset[3]=2000
i get this output:
Attribute ‘GPUMemoryTransferRateOffset’ (og:1[gpu:1]) assigned value 2000
However it doesn’t seem to have taken affect when i run:
nvidia-settings -q [gpu:1]/GPUPerfModes
it still says:
memTransferRate=13602
which is the default value on perf level 3. So basically when i run the command it doesn’t change the memory offset it does nothing but says that it has assigned 2000 mhz in offset
any help will be higly appriciated, i can give more information if needed thanks!
try it as:
nvidia-settings -a [gpu:1]/GPUMemoryTransferRateOffsetAllPerformanceLevels=2000
and if you want something like “max performance” in windows try
nvidia-settings -1 [gpu:1]/GPUPowerMizerMode=1
Thank you so much didn’t know that was why! Thanks!
