Some quesion about the unstability of Jetson nano
I run the open source code of jetbot,and find the following question.
I had a Raspberry pi camera V2 working on a Jetson Nano, and I make sure the camera without any damage.
1.The running speed of Jetson nano sometimes very slow, even a reboot won’t fix the problem. Turn off for half an hour won’t work too, but it returned to normal the next day.
2.The camera sometimes can’t starting properly.
3.The camera sometimes can starting properly, but there is a delay of tens of seconds of the image.
4.When the jetson nano doesn’t run any other programs, I run the same code through jupyter notebook, There’s a big difference in velocity.
Hi 1162632920,
Can this issue be reproduced with the pure Nano SW? I mean to flash with the latest release R32.2, can still reproduce this issue or just with the JetBot image?
Hi ,kayccc.Thank you for your reply.
I think the issue not be reproduced with the pure Nano SW. Because every time when such issue happen, all code’s running speed become slow, no just about camera.
example: When issue cause, the pure function definition cell or the pure ‘import’ cell cost a long time, which just finish immediately when the Jetson Nano is normal.
