Hello.
I followed the Jetson Sensor Processing Engine (SPE) Developer Guide (r36.3 Release) and flashed the SPE firmware successfully. Then to test the IVC App, I made the necessary changes/additions to the Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public/nv-platform/tegra234-p3737-0000+p3701-xxxx-nv-common.dtsi file and recompiled it and flashed the whole device as instructed.
When i run $ sudo su -c ‘echo tegra > /sys/devices/platform/bus@0/bus@0:aon_echo/data_channel’, i am getting Permission denied .
Please guide me on this.
In device side, install two modules.
tegra234-aon.ko
tegra-aon-ivc-echo.ko
Update the kernel DTB as you’ve done.
Re-build the SPE firmware in spe-freertos-bsp.tbz2
Re-flash the device with above changes.
Then you can test AON IVC.
root@tegra-ubuntu:/sys/devices/platform/bus@0/bus@0:aon_echo# echo test >data_channel
root@tegra-ubuntu:/sys/devices/platform/bus@0/bus@0:aon_echo# cat data_channel
test
root@tegra-ubuntu:/sys/devices/platform/bus@0/bus@0:aon_echo# echo tegra >data_channel
tegra
Hello, abelamge:
I don’t get your point.
Those two modules are in kernel_oot_modules_src.tbz2. Just follow the instructions in (Kernel Customization — NVIDIA Jetson Linux Developer Guide 1 documentation ) for OOT building.
It should be located at
kernel-source/nvidia-oot/drivers/platform/tegra/aon/tegra234-aon.ko
kernel-source/nvidia-oot/drivers/platform/tegra/aon/tegra-aon-ivc-echo.ko
Hello ChenJian.
This works, thank you for the support!
It would be good if installing the tegra234-aon.ko and tegra-aon-ivc-echo.ko modules is given as a step in the Jetson Sensor Processing Engine (SPE) Developer Guide.
Hello, abelamge:
Thanks for pointing out that.
We have checked internally and module installation issue is fixed. And the two modules involved will be included in future release.
