This might sound a bit too basic but I need some clarification about the specific behavior in my system for -fast. The command nvfortran -help -fast
is returning:
Reading rcfile /opt/nvidia/hpc_sdk/Linux_x86_64/20.9/compilers/bin/.nvfortranrc -fast Common optimizations; includes -O2 -Munroll=c:1 -Mlre -Mautoinline == -Mvect=simd -Mflushz -Mcache_align -M[no]vect[=[no]altcode|[no]assoc|cachesize:<c>|[no]fuse|[no]gather|[no]idiom|levels:<n>|nocond|[no]partial|prefetch|[no]short|[no]simd[:{128|256}]|[no]simdresidual|[no]sizelimit[:n]|[no]sse|[no]tile] Control automatic vector pipelining [no]altcode Generate appropriate alternative code for vectorized loops [no]assoc Allow [disallow] reassociation cachesize:<c> Optimize for cache size c [no]fuse Enable [disable] loop fusion [no]gather Enable [disable] vectorization of indirect array references [no]idiom Enable [disable] idiom recognition levels:<n> Maximum nest level of loops to optimize nocond Disable vectorization of loops with conditionals [no]partial Enable [disable] partial loop vectorization via inner loop distribution prefetch Generate prefetch instructions [no]short Enable [disable] short vector operations [no]simd[:{128|256}] Generate [don't generate] SIMD instructions 128 Use 128-bit SIMD instructions 256 Use 256-bit SIMD instructions 512 Use 512-bit SIMD instructions [no]simdresidual Enable [disable] vectorization of the residual loop of a vectorized loop [no]sizelimit[:n] Limit size of vectorized loops [no]sse The [no]sse option is deprecated, use [no]simd instead. [no]tile Enable [disable] loop tiling -M[no]flushz Set SSE to flush-to-zero mode -Mcache_align Align large objects on cache-line boundaries
The use of the brackets is somewhat confusing and I need to know what is active and what is not active when -fast is invoked. Are level-2 optimization, unrolling loops, loop-carried redundancy elimination, inlining, cache aligning and prefetching enabled, whereas association, fusing, vectorization and others are disabled? Or is everything enabled and I’m just reading too much into the brackets?
