I have Openpose’s Tensorflow graph https://www.dropbox.com/s/he172yau97rcrop/graph_opt.pb?dl=0.
The graph is converted to uff format using convert-to-uff command.
The output is
NOTE: UFF has been tested with TensorFlow 1.12.0. Other versions are not guaranteed to work
UFF Version 0.6.3
=== Automatically deduced input nodes ===
[name: "image"
op: "Placeholder"
attr {
key: "dtype"
value {
type: DT_FLOAT
attr {
key: "shape"
value {
shape {
dim {
dim {
dim {
dim {
=== Automatically deduced output nodes ===
[name: "Openpose/concat_stage7"
op: "ConcatV2"
input: "Mconv7_stage6_L2/BiasAdd"
input: "Mconv7_stage6_L1/BiasAdd"
input: "Openpose/concat_stage7/axis"
attr {
key: "N"
value {
i: 2
attr {
key: "T"
value {
type: DT_FLOAT
attr {
key: "Tidx"
value {
type: DT_INT32
Using output node Openpose/concat_stage7
Converting to UFF graph
No. nodes: 463
UFF Output written to cmu/cmu_openpose.uff
How do I know the conversion is correct and all nodes are converted?
The problem is speed has no improvement in running Tensorrt engine/
I used Tensorrt 5.1.5 GA.
GPU is Quardro P4000.
