I connected Jetson AGX Orin with an ADS1299 board to obtain data via SPI. I tried spi_sync_transfer function to transfer data.
What confused me most is that I used the same codes on Jetson Nano and Jetson AGX Orin, but the time cost for spi_sync_transfer is quite different. The time cost using spi_sync_transferon Jetson Nano is less than 0.4ms, while the time cost on Jetson AGX Orin is more than 7ms.
I know that the Linux kernel version is different on these machines, but is this the reason why their time cost is different? Or did I miss anything else? I expected that the time cost would be similar on these two machines.
On Jetson AGX Orin, I changed device tree file and flash the machine:
My codes look like:
int drdy_init(struct ads1299_dev *dev) {
// other codes...
int ret = request_threaded_irq(dev->drdy_irq.irqnum, t_top_handler, t_bottom_handler, IRQF_TRIGGER_FALLING, dev->drdy_irq.name, &ads1299);
return ret;
static irqreturn_t t_top_handler(int irq, void *dev_id) {
return IRQ_WAKE_THREAD;
static irqreturn_t t_bottom_handler (int irq, void *dev_id) {
gpio_set_value(ADS1299_CS_PIN, 0);
time1 = ktime_get();
int ret = spi_sync_transfer(ads1299.spi, &tr, 1);
time2 = ktime_get();
gpio_set_value(ADS1299_CS_PIN, 1);
delta = ktime_sub(time2, time1);
duration = (unsigned long long)ktime_to_ms(delta);
// ... other codes
