Jetson:
Jetson Orin NX 16GB
Carrier borad:
Seeedstudio reComputer J4012
kernel version:
5.15.136-rt-tegra
Im currently in the proces of writing a kernel module for a lan9252 device.
When testing the spi, I see a relative high latency between calling spi_sync to spi CS signal activate.
I measure the latency with using the “gpio_test_out” as the trigger signal for my logic analyser.
The latency is in worst case around 800uS, but normally around 230uS.
Is this the exspected latency on the Jetson, or is it possible to get a lower and more stable latency?
gpiod_set_value(gpio_test_out, 1);
ret = spi_sync(spi_lan9252, &m);
Changes to tegra234-p3768-0000+p3767-xxxx-nv-common.dtsi:
spi@3210000{
status = "okay";
lan9252_spi: lan9252_spi@0 {
compatible = "MICROCHIP,LAN9252_SPI";
reg = <0x0>;
spi-max-frequency = <3000000>;
controller-data {
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x0>;
nvidia,tx-clk-tap-delay = <0x0>;
nvidia,polling-mode;
nvidia,disable-runtime-pm;
spi@1 {
compatible = "tegra-spidev";
reg = <0x1>;
controller-data {
nvidia,rx-clk-tap-delay = <0x10>;
lan9252_irq_device {
compatible = "MICROCHIP,LAN9252";
status = "okay";
label = "LAN9252_IRQ";
lan9252_irq_value = <12>;
lan9252-irq-gpio = <&gpio TEGRA234_MAIN_GPIO(AC, 6) 0>;
lan9252-sync0-gpio = <&gpio TEGRA234_MAIN_GPIO(N, 1) 0>;
lan9252-sync1-gpio = <&gpio TEGRA234_MAIN_GPIO(I, 1) 0>;
lan9252-test-out-gpio = <&gpio TEGRA234_MAIN_GPIO(H, 0) 0>;
lan_spi = <&lan9252_spi>;
kernel module:
#include <linux/module.h>
#include <linux/init.h>
#include <linux/mod_devicetable.h>
#include <linux/property.h>
#include <linux/platform_device.h>
#include <linux/of_device.h>
#include <linux/gpio/consumer.h>
#include <linux/proc_fs.h>
#include <linux/interrupt.h>
#include <linux/delay.h>
#include <linux/spi/spi.h>
unsigned int irq_number, sync0_number, sync1_number;
/* Declate the probe and remove functions */
static int dt_probe(struct platform_device *pdev);
static int dt_remove(struct platform_device *pdev);
static struct of_device_id lan9252_driver_ids[] = {
.compatible = "MICROCHIP,LAN9252",
}, { /* sentinel */ }
MODULE_DEVICE_TABLE(of, lan9252_driver_ids);
static struct platform_driver lan9252_driver = {
.probe = dt_probe,
.remove = dt_remove,
.driver = {
.name = "lan9252_device_driver",
.of_match_table = lan9252_driver_ids,
/* GPIO variable */
static struct gpio_desc *lan9252_irq = NULL;
static struct gpio_desc *lan9252_sync0 = NULL;
static struct gpio_desc *lan9252_sync1 = NULL;
static struct gpio_desc *gpio_test_out = NULL;
static struct proc_dir_entry *proc_file;
struct device_node *spi_np;
struct spi_device *spi_lan9252;
static irqreturn_t gpio_irq_handler(int irq, void *dev_id)
struct spi_message m;
int ret;
u8 tx_buf[3];
u8 rx_buf[4];
u16 id;
//struct spi_transfer t[];
struct spi_transfer t[] = {
.tx_buf = tx_buf,
.len = 3,
.rx_buf = rx_buf,
.len = 4,
// Prepare the SPI command to read from register 0x0050
tx_buf[0] = 0x03; // Instruction
tx_buf[1] = (0x0050 >> 8) & 0xFF; // MSB of the address
tx_buf[2] = 0x0050 & 0xFF; // LSB of the address
t[0].tx_buf = tx_buf;
t[0].len = 3;
spi_message_init(&m);
spi_message_add_tail(&t[0], &m);
spi_message_add_tail(&t[1], &m);
if (ret < 0) {
printk("lan9252 - Error! SPI transfer failed\n");
return ret;
// Combine the 4 bytes received into a 32-bit ID
id = (rx_buf[3] << 8) | rx_buf[2];
printk("lan9252 - Device ID: 0x%04x\n", id);
gpiod_set_value(gpio_test_out, 0);
return IRQ_HANDLED;
static irqreturn_t gpio_sync0_handler(int irq, void *dev_id)
udelay(200);
return IRQ_HANDLED;
static irqreturn_t gpio_sync1_handler(int irq, void *dev_id)
udelay(300);
return IRQ_HANDLED;
static int dt_probe(struct platform_device *pdev) {
int lan9252_irq_value, ret;
struct device *dev = &pdev->dev;
const char *label;
u8 tx_buf[3];
u8 rx_buf[4];
u16 id;
.tx_buf = tx_buf,
.len = 3,
.rx_buf = rx_buf,
.len = 4,
printk("LAN9252_IRQ - In the probe function!\n");
/* Check for device properties */
if(!device_property_present(dev, "lan_spi")) {
printk("LAN9252_IRQ - Error! Device property 'lan_spi' not found!\n");
return -1;
spi_np = of_parse_phandle(pdev->dev.of_node, "lan_spi", 0);
if (!spi_np) {
dev_err(&pdev->dev, "Failed to find SPI device node\n");
return -ENODEV;
spi_lan9252 = of_find_spi_device_by_node(spi_np);
//spi_dev->rt = 1;
if (!spi_lan9252) {
dev_err(&pdev->dev, "Failed to find SPI device\n");
of_node_put(spi_np);
return -EPROBE_DEFER;
if(!device_property_present(dev, "label")) {
printk("LAN9252_IRQ - Error! Device property 'label' not found!\n");
return -1;
if(!device_property_present(dev, "lan9252_irq_value")) {
printk("LAN9252_IRQ - Error! Device property 'lan9252_irq_value' not found!\n");
return -1;
if(!device_property_present(dev, "lan9252-irq-gpio")) {
printk("LAN9252_IRQ - Error! Device property 'lan9252-irq-gpio' not found!\n");
return -1;
if(!device_property_present(dev, "lan9252-sync0-gpio")) {
printk("LAN9252_IRQ - Error! Device property 'lan9252-sync0-gpio' not found!\n");
return -1;
if(!device_property_present(dev, "lan9252-sync1-gpio")) {
printk("LAN9252_IRQ - Error! Device property 'lan9252-sync1-gpio' not found!\n");
return -1;
if(!device_property_present(dev, "lan9252-test-out-gpio")) {
printk("LAN9252_IRQ - Error! Device property 'lan9252-test-out-gpio' not found!\n");
return -1;
/* Read device properties */
ret = device_property_read_string(dev, "label", &label);
if(ret) {
printk("LAN9252_IRQ - Error! Could not read 'label'\n");
return -1;
printk("LAN9252_IRQ - label: %s\n", label);
ret = device_property_read_u32(dev, "lan9252_irq_value", &lan9252_irq_value);
if(ret) {
printk("LAN9252_IRQ - Error! Could not read 'lan9252_irq_value'\n");
return -1;
printk("LAN9252_IRQ - lan9252_irq_value: %d\n", lan9252_irq_value);
/* Init IRQ */
lan9252_irq = gpiod_get(dev, "lan9252-irq", GPIOD_IN);
if(IS_ERR(lan9252_irq)) {
printk("LAN9252_IRQ - Error! Could not setup the GPIO\n");
return -1 * IS_ERR(lan9252_irq);
/* Setup the interrupt */
irq_number = gpiod_to_irq(lan9252_irq);
if(request_irq(irq_number, gpio_irq_handler, IRQF_TRIGGER_RISING, "lan9252_gpio_irq", NULL) != 0){
printk("Error!\nCan not request interrupt nr.: %d\n", irq_number);
return -1;
printk("LAN9252_IRQ is mapped to IRQ Nr.: %d\n", irq_number);
/* Init SYNC0 */
lan9252_sync0 = gpiod_get(dev, "lan9252-sync0", GPIOD_IN);
if(IS_ERR(lan9252_sync0)) {
printk("LAN9252_SYNC0 - Error! Could not setup the GPIO\n");
return -1 * IS_ERR(lan9252_sync0);
sync0_number = gpiod_to_irq(lan9252_sync0);
if(request_irq(sync0_number , gpio_sync0_handler, IRQF_TRIGGER_RISING, "lan9252_sync0", NULL) != 0){
printk("Error!\nCan not request interrupt nr.: %d\n", sync0_number);
return -1;
printk("LAN9252_SYNC0 is mapped to IRQ Nr.: %d\n", sync0_number);
/* Init SYNC1 */
lan9252_sync1 = gpiod_get(dev, "lan9252-sync1", GPIOD_IN);
if(IS_ERR(lan9252_sync1)) {
printk("LAN9252_SYNC1 - Error! Could not setup the GPIO\n");
return -1 * IS_ERR(lan9252_sync1);
sync1_number = gpiod_to_irq(lan9252_sync1);
if(request_irq(sync1_number , gpio_sync1_handler, IRQF_TRIGGER_RISING, "lan9252_sync1", NULL) != 0){
printk("Error!\nCan not request interrupt nr.: %d\n", sync1_number);
return -1;
printk("LAN9252_SYNC1 is mapped to IRQ Nr.: %d\n", sync1_number);
/* Init GPIO */
gpio_test_out = gpiod_get(dev, "lan9252-test-out", GPIOD_OUT_LOW);
if(IS_ERR(gpio_test_out)) {
printk("LAN9252_TEST_OUT - Error! Could not setup the GPIO\n");
return -1 * IS_ERR(gpio_test_out);
/* test spi */
t[0].len = 3;
if (ret < 0) {
return ret;
if (id != 0x9252) {
printk("lan9252 - Device ID not correct");
return -1;
return 0;
static int dt_remove(struct platform_device *pdev) {
printk("LAN9252 - In the remove function\n");
free_irq(sync1_number, NULL);
free_irq(sync0_number, NULL);
free_irq(irq_number, NULL);
gpiod_put(lan9252_irq);
gpiod_put(lan9252_sync0);
gpiod_put(lan9252_sync1);
gpiod_put(gpio_test_out);
proc_remove(proc_file);
return 0;
static int __init lan9252_init(void) {
printk("LAN9252 - Loading the driver...\n");
if(platform_driver_register(&lan9252_driver)) {
printk("LAN9252 - Error! Could not load driver\n");
return -1;
return 0;
static void __exit lan9252_exit(void) {
printk("LAN9252 - Unload driver");
platform_driver_unregister(&lan9252_driver);
module_init(lan9252_init);
module_exit(lan9252_exit);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("MKN");
MODULE_DESCRIPTION("LKM for LAN9252 ethercat controller");
